Här är sidan:
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<title>Startsidan för Internet Explorer</title>
<style type="text/css">
.table { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: normal; font-weight: normal; color: #CCCCCC; text-decoration: none}
body { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: normal; font-weight: normal; color: #CCCCCC; text-decoration: none ; background-color: #336699}
a:link { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: normal; font-weight: normal; color: #000033; text-decoration: none}
a:visited { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: normal; font-weight: normal; color: #000033; text-decoration: none }
a:hover { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: normal; font-weight: bold; color: #9A0000; text-decoration: none }
a:active { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: normal; font-weight: bold; color: #330000; text-decoration: none }
.form {font-family:Verdana, Arial, Helvetica, sans-serif;; font-size: 10px; font-style: normal; line-height: normal; font-weight: normal; color: #CCCCCC; text-decoration: none; background-color: #006699; border: 1px #CCCCCC solid}
.goto { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; font-weight: normal; color: #000033; text-decoration: none; background-color: #336699; border: #99CCFF; border-top-width: 1px; border-right-width: 1px; border-bottom-width: 1px; border-left-width: 1px}
.adressfalt { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; font-weight: normal; color: #000033; text-decoration: none; background-color: #336699; border: #99CCFF solid; border-top-width: 1px; border-right-width: 1px; border-bottom-width: 1px; border-left-width: 1px}
.gotoButton { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; font-weight: bold; color: #000033; background-color: #336699; border: 1px #99CCFF outset}
</style>
<!-- KLOCKAN -->
function show2(){
if (!document.all&&!document.getElementById)
return
thelement=document.getElementById? document.getElementById("tick2"): document.all.tick2
var Digital=new Date()
var year=Digital.getYear()
var month=Digital.getMonth()
var day=Digital.getDay()
var hours=Digital.getHours()
var minutes=Digital.getMinutes()
if (month<=9)
month="0"+month
if (day<=9)
day="0"+day
if (hours<=9)
hours="0"+hours
if (minutes<=9)
minutes="0"+minutes
var ctime=hours+":"+minutes
var cdate=year+"-"+month+"-"+day
thelement.innerHTML=ctime+"<!--<br>"+cdate+"-->"
setTimeout("show2()",1000)
window.onload=show2
function MM_jumpMenu(targ,selObj,restore){ //v3.0
eval(targ+".location='"+selObj.options[selObj.selectedIndex].value+"'");
if (restore) selObj.selectedIndex=0;
function MM_findObj(n, d) { //v4.0
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && document.getElementById) x=document.getElementById(n); return x;
function MM_jumpMenuGo(selName,targ,restore){ //v3.0
var selObj = MM_findObj(selName); if (selObj) MM_jumpMenu(targ,selObj,restore);
function adress() {
if (adressfield.value != "") {
window.status = "Söker efter adressen...";
eval("parent.location='http://"+adressfield.value+"'");
function TeliaLogin(){
var targetURL = 'http://login1.telia.com';
parent.location = targetURL;
function Timer(){
var sekund=7;
var targetURL="http://login1.telia.com";
if (sekund!=1){
sekund-=1
var msgSTATUS='Du är OFFLINE! Om ' + sekund + ' sekunder kommer du att skickas till ' + targetURL;
var msgHTML='<font color="#FF0000" size="2">Du är OFFLINE!!!</font><br><font color="#FF0000" size="1">Om ' + sekund + ' sekunder kommer du att skickas till inloggningssidan.';
document.getElementById('status').innerHTML = msgHTML;
window.status = msgSTATUS;
else{
window.location=targetURL;
return
setTimeout("Timer()",1000)
function checkStatus(){
//Skriver ut på sidan (innan kontrollen görs)
//msgHTML = '<font color="#333333" size=1>Klart...</font>';
//document.getElementById('status').innerHTML = msgHTML;
//kollar om bilden har fel storlek, du har kolla hur stor bilden ska vara
if(document.getElementById('onlinebild').offsetWidth < 40){
msgHTML = '<font color="#FF0000" size="2">Du är OFFLINE!!!</font>';
msgSTATUS = "Du är OFFLINE!";
alert("Du är OFFLINE. För att använda internet måste du logga in på Telia Bredband");
//Timer();
msgHTML +='<br><br><input type=button value="Logga in" onClick="TeliaLogin();" style="font-family:Verdana;font-size:10px;color:#7777FF;">';
//om bilden har rätt storlek betyder det att browsern hittade den på internet
else {
msgHTML = '<font color="#00FF00" size="2">Du är ONLINE.</font>';
//var bredd = document.getElementById('onlinebild').offsetWidth;
//var hojd = document.getElementById('onlinebild').offsetHeight;
//msgHTML +=bredd;
msgSTATUS = "Du är ONLINE.";
//skriver ut meddelandet till en div & till statusfältet
function getHTTPStatus(url) {
if (document.layers && navigator.javaEnabled()){
if ((location.host == '') || (url.indexOf(location.host) == -1)){ netscape.security.PrivilegeManager.enablePrivilege('UniversalConnect'); }
var urlObj = new java.net.URL(url); var port = (urlObj.getPort()>0)?urlObj.getPort():80;
var socket = new java.net.Socket (urlObj.getHost(),port);
var dos = new java.io.DataOutputStream(socket.getOutputStream());
dos.writeBytes('HEAD ' + urlObj.getFile() + ' HTTP/1.0\r\n\r\n');
var dis = new java.io.DataInputStream(socket.getInputStream());
var data = dis.readLine();
dis.close(); dos.close(); socket.close();
var re = /(HTTP\/[\d\.]+) (\d\d\d) ?(.*)$/i;
var match = re.exec(data);
return match[2];
} else if (document.getElementById && window.ActiveXObject) {
var http = new ActiveXObject('Microsoft.XMLHTTP');
http.open('HEAD', url, false);
http.send();
return http.status;
} else {
return false;
<!-- SLUT KLOCKAN-->
<body>
<table width="100%" border="0" cellspacing="0" cellpadding="2" height="100%" name="mainTable" align="center" class="table">
<tr>
<td height="31"><!--VISAR VECKA--><span id=tick2></span><br>
<!--VECKA-skript-->
<SCRIPT Language="JavaScript">
function weekNo() {
var totalDays = 0;
now = new Date();
years=now.getYear()
if (years < 1000)
years+=1900
var days = new Array(12); // Array to hold the total days in a month
days[0] = 31;
days[2] = 31;
days[3] = 30;
days[4] = 31;
days[5] = 30;
days[6] = 31;
days[7] = 31;
days[8] = 30;
days[9] = 31;
days[10] = 30;
days[11] = 31;
// Check to see if this is a leap year
if (Math.round(now.getYear()/4) == now.getYear()/4) {
days[1] = 29
}else{
days[1] = 28
// If this is January no need for any fancy calculation otherwise figure out the
// total number of days to date and then determine what week
if (now.getMonth() == 0) {
totalDays = totalDays + now.getDate();
}else{
var curMonth = now.getMonth();
for (var count = 1; count <= curMonth; count++) {
totalDays = totalDays + days[count - 1];
var week = Math.round(totalDays/7);
//MIN RAD
var week = week + 1;
return week;
document.write("Vecka "+weekNo())
</SCRIPT>
<!--SLUT VECKA-skript-->
</td>
</tr>
<tr>
<td align="center" valign="middle">
<p>Adressfält...<br>
[url]http://[/url]<input name="adressfield" class="adressfalt">
<input type="submit" value="Gå till..." class="gotobutton" onClick="javascript:adress();">
</p>
<p><a href="http://www.altavista.se/">Altavista.se</a><br>
<a href="http://www.google.com/">Google.com</a><br>
<a href="http://www.download.com/">Download.com</a><br>
<a href="http://www.sl.se/">SL</a>br>
<a href="http://www.evighet.net/">evighet.net/</a>
<br>
</p>
<form name="form1" class="goto">
<select name="meny" onChange="MM_jumpMenu('parent',this,1)" class="goto">
<option selected value="#">-Välj adress-</option>
</select>
<input type="button" class="gotoButton" name="gotobutton" value="->" onClick="MM_jumpMenuGo('meny','parent',1)">
<p>
<p>
<table border="0" cellspacing="0" cellpadding="2" width="300">
<tr>
<td valign="middle" align="center">
if(getHTTPStatus('http://www.evighet.net/te2a/public/upload/rad.JPG')=='200'){
// sidan finns/är inline, allt ok
alert("OK!");
} else {
// ... eller inte
alert("Ej OK!");
<div id="Status"><div>
</td>
</tr>
</table>
</p>
</p>
</td>
</tr>
<tr>
<td height="31"> </td>
</tr>
</table></body>
</html>
