Tjena hej,
Har ett veckoschema enl. bifogad bild. Formuläret laddas in via Ajax i en jQueryUi Dialog.
När man kryssar i checkboxen tänds alla selectlistor på samma rad upp. Därefter ska de 4 för klockslag populeras. Har nu gjort såhär, vilket fungerar:
function PopulateTimeList(selector) {
var select = $(selector);
var hours, minutes, ampm;
for(var i = 300; i <= 1440; i += 5){
hours = Math.floor(i / 60);
if (hours < 10){
hours = '0' + hours; // adding leading zero
minutes = i % 60;
if (minutes < 10){
minutes = '0' + minutes; // adding leading zero
select.append($('<option></option>')
.attr('value', i)
.text(hours + ':' + minutes));
$(function(){
$('#dialogOccasions').on('change', 'input:checkbox', function(){
var Elem = $(this).closest('tr').find('select');
$(Elem).prop("disabled", !this.checked);
var TimeLists = $(this).closest('tr').find('select.Time');
$(TimeLists).on('mousedown', function(){
PopulateTimeList($(this));
HTML-koden ser ut såhär:
<table style="width: 100%;">
<thead>
<tr>
<th style="width: 40%;">Datum</th>
<th>Startar</th>
<th>Slutar</th>
<th style="width: 20%;">Aktivitet</th>
<th>Startar</th>
<th>Slutar</th>
</tr>
</thead>
<tbody> <tr class="row-odd">
<td><label><input type="checkbox" value="1" name="Data[0][Day]"> måndag</label></td>
<td>
<select style="width: 75px;" class="large Time" name="Data[0][Time][0][Start]">
</select>
</td>
<td>
<select style="width: 75px;" class="large Time" name="Data[0][Time][0][End]">
</select>
</td>
<td>
<select style="width: 100px;" class="large" name="Data[0][Time][0][Activity]">
<option selected="selected" value="1">Träning</option>
<option value="2">Match/Tävling/Cup</option>
</select>
</td>
<td>
<select style="width: 75px;" class="large Time" name="Data[0][Time][1][Start]">
<option selected="selected" value="0">-</option>
</select>
</td>
<td>
<select style="width: 75px;" class="large Time" name="Data[0][Time][1][End]">
</select>
</td>
<td>
<select style="width: 100px;" class="large" name="Data[0][Time][1][Activity]">
</select>
</td>
</tr>
<tr class="row-even">
<td><label><input type="checkbox" value="2" name="Data[1][Day]"> tisdag</label></td>
<td>
<select style="width: 75px;" class="large Time" name="Data[1][Time][0][Start]" disabled="">
</select>
</td>
<td>
<select style="width: 75px;" class="large Time" name="Data[1][Time][0][End]" disabled="">
</select>
</td>
<td>
<select style="width: 100px;" class="large" name="Data[1][Time][0][Activity]" disabled="">
</select>
</td>
<td>
<select style="width: 75px;" class="large Time" name="Data[1][Time][1][Start]" disabled="">
</select>
</td>
<td>
<select style="width: 75px;" class="large Time" name="Data[1][Time][1][End]" disabled="">
</select>
</td>
<td>
<select style="width: 100px;" class="large" name="Data[1][Time][1][Activity]" disabled="">
</select>
</td>
</tr>
</tbody>
</table>
Problemet är att det är otroligt segt, eftersom varje lista populeras varje gång man klickar på en lista. När en lista väl populeras, behöver det (såklart) inte ske igen.
Är det en bättre idé att ha EN statisk lista, som man klonar med hjälp av clone()??
Tack!
