Slideshow och Explorer
6 svar · 1 518 visningar · startad av Pelletsteknik
PelletsteknikMedlem sedan feb. 200844 inlägg
Jag använder "slideshow" på min sida och och det verkar inte fungera med alla webläsare.
Den stänger igen direkt, så att jag kan inte klicka vidare.
<!-- ========== CSS ========== -->
<style type="text/css">
#shipping-estimate-module {
	margin-left: auto;
	margin-right: auto;
#location-fields, #shipping-quotes { /* Needed to display next to each other for content modules in 1.5.0.x */
	display: inline-block;
	vertical-align: top;
#location-fields {
	margin-right: 25px;
#shipping-estimate-module select {
	width: 160px;
#shipping-estimate-module input {
	width: 155px;
#estimate-button {
	margin: 5px 0 5px 42px;
#estimate-button span {
	height: 15px; /* To the make loading gif the same height as "Estimate" */
#estimate-button img {
	padding: 0 17px 0 16px; /* To the make loading gif the same size as "Estimate" */
#quotetable {
	background: #F8F8F8;
	border: 1px solid #DDD;
	margin: 0;
	padding: 0 !important;
	width: 100%;
#quotetable td, #quotetable a {
	font-size: 11px;
.leftpadded {
	padding-left: 15px;
</style>
<!-- ========== HTML ========== -->
<div id="shipping-estimate-module" class="box"<?php if (!defined('VERSION') || VERSION < 1.5) { echo ' style="width: 180px"'; } ?>>
	<div class="top box-heading">
		<?php if (!defined('VERSION') || VERSION < 1.5) { ?><img src="catalog/view/theme/default/image/shipping.png" alt="" /><?php } ?>
		<?php echo $heading_shippingestimate; ?>
	<div class="middle box-content">
		<div id="location-fields">
			<div<?php if ($this->config->get('shippingestimate_hide_country')) echo ' style="display: none"'; ?>>
				<strong><?php echo $entry_country; ?></strong>
				<select id="shipest_country_id" name="shipest_country_id" onchange="loadzones(this.value)">
					<option value="FALSE"><?php echo $text_select; ?></option>
					<?php foreach ($countries as $country) { ?>
						<option value="<?php echo $country['country_id']; ?>"><?php echo $country['name']; ?></option>
					<?php } ?>
				</select>
			<div<?php if ($this->config->get('shippingestimate_hide_zone')) echo ' style="display: none"'; ?>>
				<strong><?php echo $entry_zone; ?></strong>
				<select id="shipest_zone_id" name="shipest_zone_id"></select>
			<div<?php if ($this->config->get('shippingestimate_hide_postcode')) echo ' style="display: none"'; ?>>
				<strong><?php echo $entry_postcode; ?></strong>
				<input type="text" id="shipest_postcode" name="shipest_postcode" onkeydown="if (event.keyCode == 13 || event.which == 13) getquote();" />
			<div id="estimate-button">
				<a onclick="getquote()" class="button"><span><?php echo $button_estimate; ?></span></a>
		<div id="shipping-quotes">
			<!-- shipping quotes table goes here -->
	<?php if (!defined('VERSION') || VERSION < 1.5) { ?><div class="bottom">&nbsp;</div><?php } ?>
<!-- ========== Javascript ========== -->
<script type="text/javascript"><!--
	$('#shipping-quotes').hide();
	var moduleWidth = $('#shipping-estimate-module').width();
	if (moduleWidth > 800) {
		$('#shipping-quotes').width('70%');
	} else if (moduleWidth > 600) {
		$('#shipping-quotes').width('60%');
	} else if (moduleWidth > 200) {
		$('#shipping-quotes').width('50%');
	function loadzones(country_id) {
		$('#shipest_zone_id').load('index.php?route=checkout/address/zone&country_id=' + country_id + '&zone_id=', function() {
			$('#shipest_zone_id').val('<?php echo $default_zone; ?>');
			<?php if ($this->config->get('shippingestimate_hide_zone')) { ?>
				if ($('#shipest_zone_id').val() == 'FALSE') {
					$('#shipest_zone_id').val($('#shipest_zone_id option:selected').next().val());
			<?php } ?>
	function getquote() {
		$('#estimate-button span').html('<img src="catalog/view/theme/default/image/ajax_shipping.gif" />');
		$('#shipping-quotes').slideUp('slow', function() {
			$.post(
				"index.php?route=module/shippingestimate/estimate",
				{country_id: $('#shipest_country_id').val(), zone_id: $('#shipest_zone_id').val(), postcode: $('#shipest_postcode').val(), route: '<?php echo $this->request->get['route']; ?>'},
				function(data) {
					$('#shipping-quotes').html(data);
					$('#shipping-quotes').slideDown('slow', function() {
						$('#estimate-button span').html('<?php echo $button_estimate; ?>');
	function applyshipping(quote_id) {
			$.post(
				"index.php?route=module/shippingestimate/apply",
				{shipping_method: quote_id},
				function(data) {
					$('#shipping-quotes').slideDown('slow');
	$('#shipest_country_id').val('<?php echo $default_country; ?>');
	loadzones(<?php echo $default_country; ?>);
	$('#shipest_postcode').val('<?php echo $default_postcode; ?>');
//--></script>
Visa hur den färdiga koden som skickas till webbläsaren ser ut. Vi har inte inbyggda php-tolkar i våra hjärnor.
Ge oss gärna URL också så vi kan se hur det beter sig.
http://shop.pelletsteknik.se/index.php
Hur vet jag vilken kod det är som skickas till webläsaren?
Det fungerar ej med Explorer.
Högerklicka i webbläsaren och välj "Visa källa".
Från webläsaren.
				<a onclick="getquote()" class="button"><span>Beräkna</span></a>
Från webläsaren.
			$.post(
				{country_id: $('#shipest_country_id').val(), zone_id: $('#shipest_zone_id').val(), postcode: $('#shipest_postcode').val(), route: '<b>Notice</b>:
Detta är ajax_add.js
$(document).ready(function () {
	$('#add_to_cart').removeAttr('onclick');
	$('#add_to_cart').click(function () {
		$.ajax({
			type: 'post',
			url: 'index.php?route=module/cart/callback',
			dataType: 'html',
			data: $('#product :input'),
			success: function (html) {
				$('#module_cart .middle').html(html);
			complete: function () {
				var image = $('#image').offset();
				var cart  = $('#module_cart').offset();
				$('#image').before('<img src="' + $('#image').attr('src') + '" id="temp" style="position: absolute; top: ' + image.top + 'px; left: ' + image.left + 'px;" />');
				params = {
					top : cart.top + 'px',
					left : cart.left + 'px',
					opacity : 0.0,
					width : $('#module_cart').width(),
					height : $('#module_cart').height()
				$('#temp').animate(params, 'slow', false, function () {
					$('#temp').remove();
