Vad är problemet? Du bygger ju bara ut HTML och se till att dom är unika:
<title>JavaScript Dropdown Menu Demo</title>
<style type="text/css">
body {margin:25px; font:12px Verdana, Arial, Helvetica}
* {padding:0; margin:0}
.dropdown {float:left; padding-right:5px}
.dropdown dt {width:188px; border:2px solid #9ac1c9; padding:8px; font-weight:bold; cursor:pointer; background:url(images/header.gif)}
.dropdown dt:hover {background:url(images/header_over.gif)}
.dropdown dd {position:absolute; overflow:hidden; width:208px; display:none; background:#fff; z-index:200; opacity:0}
.dropdown ul {width:204px; border:2px solid #9ac1c9; list-style:none; border-top:none}
.dropdown li {display:inline}
.dropdown a, .dropdown a:active, .dropdown a:visited {display:block; padding:5px; color:#333; text-decoration:none; background:#eaf0f2; width:194px}
.dropdown a:hover {background:#d9e1e4; color:#000}
.dropdown .underline {border-bottom:1px solid #b9d6dc}
</style>
<script type="text/javascript" </script>
var DDSPEED = 10;
var DDTIMER = 15;
// main function to handle the mouse events //
function ddMenu(id,d){
var h = document.getElementById(id + '-ddheader');
var c = document.getElementById(id + '-ddcontent');
clearInterval(c.timer);
if(d == 1){
clearTimeout(h.timer);
if(c.maxh && c.maxh <= c.offsetHeight){return}
else if(!c.maxh){
c.style.display = 'block';
c.style.height = 'auto';
c.maxh = c.offsetHeight;
c.style.height = '0px';
c.timer = setInterval(function(){ddSlide(c,1)},DDTIMER);
}else{
h.timer = setTimeout(function(){ddCollapse(c)},50);
// collapse the menu //
function ddCollapse(c){
c.timer = setInterval(function(){ddSlide(c,-1)},DDTIMER);
// cancel the collapse if a user rolls over the dropdown //
function cancelHide(id){
if(c.offsetHeight < c.maxh){
// incrementally expand/contract the dropdown and change the opacity //
function ddSlide(c,d){
var currh = c.offsetHeight;
var dist;
if(d == 1){
dist = (Math.round((c.maxh - currh) / DDSPEED));
}else{
dist = (Math.round(currh / DDSPEED));
if(dist <= 1 && d == 1){
dist = 1;
c.style.height = currh + (dist * d) + 'px';
c.style.opacity = currh / c.maxh;
c.style.filter = 'alpha(opacity=' + (currh * 100 / c.maxh) + ')';
if((currh < 2 && d != 1) || (currh > (c.maxh - 2) && d == 1)){
<body>
<dl class="dropdown">
<dt id="one-ddheader" onmouseover="ddMenu('one',1)" onmouseout="ddMenu('one',-1)">Dropdown One</dt>
<dd id="one-ddcontent" onmouseover="cancelHide('one')" onmouseout="ddMenu('one',-1)">
<ul>
<li><a href="#" class="underline">Navigation Item 1</a></li>
<li><a href="#" class="underline">Navigation Item 2</a></li>
<li><a href="#" class="underline">Navigation Item 3</a></li>
<li><a href="#" class="underline">Navigation Item 4</a></li>
<li><a href="#">Navigation Item 5</a></li>
</ul>
</dd>
</dl>
<dt id="two-ddheader" onmouseover="ddMenu('two',1)" onmouseout="ddMenu('two',-1)">Dropdown Two</dt>
<dd id="two-ddcontent" onmouseover="cancelHide('two')" onmouseout="ddMenu('two',-1)">
<ul>
</ul>
</dd>
</dl>
<dt id="three-ddheader" onmouseover="ddMenu('three',1)" onmouseout="ddMenu('three',-1)">Dropdown three</dt>
<dd id="three-ddcontent" onmouseover="cancelHide('three')" onmouseout="ddMenu('three',-1)">
<ul>
</ul>
</dd>
</dl>
<div style="clear:both" />
</html>
Tack! Jag lyckades lösa det på det sättet du sa.
</style>
var DDSPEED = 10;
var DDTIMER = 15;
if(d == 1){
else if(!c.maxh){
}else{
var dist;
if(d == 1){
}else{
dist = 1;
<body>
<ul>
</ul>
</dd>
</dl>
<ul>
</ul>
</dd>
</dl>
<ul>
</ul>
</dd>
</dl>
</html>
TTobiasNMedlem sedan juni 20115 inlägg Utan att ha läst hela koden så skulle jag rekommendera dig att inte använda javascript för dropdown menyer. Det gynnar inte din sökmotoroptimering. Gör en meny som Google förstår i stället. Använd CSS.
Behöver du hjälp så kan du kolla in detta wordpress plugin.
