slidin meny
2 svar · 181 visningar · startad av Jacob
JacobMedlem sedan dec. 2000503 inlägg
Jag är inte så haj på JavaScript, jag har försökt att ändra lite iett script men det fungerar inte som jag vill.
<html>
<title>Untitled Document</title>
<style>
#divMenu {font-family:arial,helvetica; font-size:12pt; font-weight:bold}
#divMenu a{text-decoration:none;}
#divMenu a:hover{color:red;}
#divMenu2 {font-family:arial,helvetica; font-size:12pt; font-weight:bold}
#divMenu2 a{text-decoration:none;}
#divMenu2 a:hover{color:red;}
</style>
<script language="JavaScript1.2">
Submitted with modifications by Jack Routledge (http://fastway.to/compute) to DynamicDrive.com
Copyright (C) 1999 Thomas Brattli @ [url="http://www.bratta.com"]www.bratta.com[/url]
This script is made by and copyrighted to Thomas Brattli
This may be used freely as long as this msg is intact!
This script has been featured on [url="http://www.dynamicdrive.com"]http://www.dynamicdrive.com[/url]
Browsercheck:*/
ie=document.all?1:0
n=document.layers?1:0
ns6=document.getElementById&&!document.all?1:0
//These are the variables you have to set:
//How much of the layer do you wan't to be visible when it's in the out state?
lshow=60
//How many pixels should it move every step?
var move=10;
//At what speed (in milliseconds, lower value is more speed)
menuSpeed=40
//Do you want it to move with the page if the user scroll the page?
var moveOnScroll=false
You should't have to change anything below this.
//Defining variables
var ltop;
var tim=0;
//Object constructor
function makeMenu(obj,nest){
    nest=(!nest) ? '':'document.'+nest+'.'
    if (n) this.css=eval(nest+'document.'+obj)
    else if (ns6) this.css=document.getElementById(obj).style
    else if (ie) this.css=eval(obj+'.style')
	this.state=1
	this.go=0
	if (n) this.width=this.css.document.width
        else if (ns6) this.width=document.getElementById(obj).offsetWidth
        else if (ie) this.width=eval(obj+'.offsetWidth')
	this.left=b_getleft
    this.obj = obj + "Object"; 	eval(this.obj + "=this")
//Get's the top position.
function b_getleft(){
        if (n&#0124;&#0124;ns6){ gleft=parseInt(this.css.left)}
        else if (ie){ gleft=eval(this.css.pixelLeft)}
	return gleft;
Deciding what way to move the menu (this is called onmouseover, onmouseout or onclick)
function moveMenu(menu){
//		document.write(menu)
	if(!oMenu[menu].state){
		clearTimeout(tim)
		mIn(menu)
	}else{
		clearTimeout(tim)
		mOut(menu)
//Menu in
function mIn(menu){
	if([menu].left()>-oMenu[menu].width+lshow){
		oMenu[menu].go=100
		oMenu[menu].css.left=oMenu[menu].left()-move
		tim=setTimeout("mIn()",menuSpeed)
	}else{
		[menu].go=0
		[menu].state=1
//Menu out
function mOut(menu){
	if(oMenu[menu].left()<0){
		oMenu[menu].go=1
		oMenu[menu].css.left=oMenu[menu].left()+move
		tim=setTimeout("mOut("+menu+")",menuSpeed)
	}else{
		oMenu[menu].go=0
		oMenu[menu].state=0
Checking if the page is scrolled, if it is move the menu after
function checkScrolled(menu){
	if(!menu.go) menu.css.top=eval(scrolled)+parseInt(ltop)
	if(n&#0124;&#0124;ns6) setTimeout('checkScrolled(menu)',30)
Inits the page, makes the menu object, moves it to the right place,
show it
function menuInit(){
	oMenu=new makeMenu('divMenu')
        if (n&#0124;&#0124;ns6) scrolled="window.pageYOffset"
        else if (ie) scrolled="document.body.scrollTop"
	oMenu.css.left=-oMenu.width+lshow
        if (n&#0124;&#0124;ns6) ltop=oMenu.css.top
        else if (ie) ltop=oMenu.css.pixelTop
	oMenu.css.visibility='visible'
	oMenu2=new makeMenu('divMenu2')
	oMenu2.css.left=-oMenu.width+lshow
        if (n&#0124;&#0124;ns6) ltop=oMenu2.css.top
        else if (ie) ltop=oMenu2.css.pixelTop
	oMenu2.css.visibility='visible'
//Initing menu on pageload
window.onload=menuInit;
<body bgcolor="#FFFFFF" text="#000000">
<div id="divMenu" style="position:absolute; top:2; left:30; visibility:hidden; background-color:F0F0F0">
  <nobr> <a href="http://www.dynamicdrive.com">Dynamic Drive</a> - <a href="http://www.freewarejava.com/cgi-bin/Ultimate.cgi">WA
  Help Forum</a> - <a href="http://active-x.com/">Active-X.com</a> - <a href="javascript://" onClick="moveMenu()" style="background-color:yellow;text-decoration:none">MENU</a>
  </nobr> </div>
  <div id="divMenu2" style="position:absolute; top:20; left:30; visibility:hidden; background-color:F0F0F0">
  Help Forum</a> - <a href="http://active-x.com/">Active-X.com</a> - <a href="javascript://" onClick="moveMenu(2)" style="background-color:yellow;text-decoration:none">MENU</a>
  </nobr> </div>
</html>
Jag vill att om man klickar på menu så ska menyn glida ut.
ja©ob
Jag provade med detta
	if(!menu.state){
		clearTimeout(tim)
		mIn(menu)
	}else{
		clearTimeout(tim)
		mOut(menu)
//Menu in
function mIn(menu){
	if(menu.left()>-menu.width+lshow){
		menu.go=100
		menu.css.left=menu.left()-move
		tim=setTimeout(mIn(menu),menuSpeed)
	}else{
		menu.go=0
		menu.state=1
//Menu out
	if(menu.left()<0){
		menu.go=1
		menu.css.left=menu.left()+move
		tim=setTimeout(mOut(menu),menuSpeed)
	}else{
		menu.go=0
		menu.state=0
Då glider dom ut men inte stegat utan direkt + att jag får ett fel mess: "Ogiltligt argument".
Jag provade ärven:
tim=setTimeout('mIn'+menu+')',menuSpeed)
Men då flyttar den sig bara ett steg i taget. :(
HJÄLP
[Redigerat av Jacob den 06 dec 2001]
Någon måste ha en idé
ja©ob
253 ms totalt · 3 externa anrop · v20260731065814-full.ca5a5675
127 ms — hämta forumlista (db)
125 ms — hämta statistik (db)
