Kan nån hjälpa mig att skriva om detta en aning så att jag kan placera scrollen "relative" istället för "absolute"? :q
Tack på förhand!
<style type="text/css">
#divControl {position:absolute; left:230px; top:23px; width:250px; font-size:10pt; font-family:arial,helvetica,sans-serif; visibility:hidden;}
#divCont {position:absolute; left:15px;top:18px; width:150px; height:160px; clip:rect(0px 250px 160px 0px);}
.clScroll {position:absolute; font-size:10pt; font-family:arial,helvetica,sans-serif; visibility:hidden;}
</style>
PageScroll
* Copyright (C) 2001 <a href="/dhtmlcentral/thomas_brattli.asp">Thomas Brattli</a>
* This script was released at DHTMLCentral.com
* Visit for more great scripts!
* This may be used and changed freely as long as this msg is intact!
* We will also appreciate any links you could give us.
* Made by <a href="/dhtmlcentral/thomas_brattli.asp">Thomas Brattli</a>
function lib_bwcheck(){ //Browsercheck (needed)
this.ver=navigator.appVersion
this.agent=navigator.userAgent
this.dom=document.getElementById?1:0
this.opera5=(navigator.userAgent.indexOf("Opera")>-1 && document.getElementById)?1:0
this.ie5=(this.ver.indexOf("MSIE 5")>-1 && this.dom && !this.opera5)?1:0;
this.ie6=(this.ver.indexOf("MSIE 6")>-1 && this.dom && !this.opera5)?1:0;
this.ie4=(document.all && !this.dom && !this.opera5)?1:0;
this.ie=this.ie4||this.ie5||this.ie6
this.mac=this.agent.indexOf("Mac")>-1
this.ns6=(this.dom && parseInt(this.ver) >= 5) ?1:0;
this.ns4=(document.layers && !this.dom)?1:0;
this.bw=(this.ie6 || this.ie5 || this.ie4 || this.ns4 || this.ns6 || this.opera5)
return this
var bw=new lib_bwcheck()
These are the variables you have to set:
//The speed of the timeout between each scroll.
timSpeed = 30
//The height of the container (change this when it scrolls to much or to little)
contHeight = 100
This is the object constructor function, which applies
methods and properties to the Cross-browser layer object
function makeScrollObj(obj,nest){
nest=(!nest) ? "":'document.'+nest+'.'
this.el=bw.dom?document.getElementById(obj):bw.ie4?document.all[obj]:bw.ns4?eval(nest+'document.'+obj):0;
this.css=bw.dom?document.getElementById(obj).style:bw.ie4?document.all[obj].style:bw.ns4?eval(nest+'document.'+obj):0;
this.height=bw.ns4?this.css.document.height:this.el.offsetHeight
this.top=b_gettop
return this
// A unit of measure that will be added when setting the position of a layer.
var px = bw.ns4||window.opera?"":"px";
//Getting the top for the top method
function b_gettop(){
var gleft=(bw.ns4 || bw.ns6)?parseInt(this.css.top):eval(this.css.pixelTop);
return gleft;
//Variables
var scrollTim = 1;
var active = 0;
The scroll function. Checks what way to scroll and checks if the
layer is not already on top or bottom.
function scroll(speed){
clearTimeout(scrollTim)
way = speed>0?1:0
if ((!way && oScroll[active].top()>-oScroll[active].height+contHeight) || (oScroll[active].top()<0 && way)){
oScroll[active].css.top = (oScroll[active].top()+speed)+px
scrollTim = setTimeout("scroll("+speed+")",timSpeed)
//Clears the timeout so the scroll stops, this is called onmouseout.
function noScroll(){
Changes the active layer. Hides the one that's visible and
shows the "new" one. Also set's the new layers top to
0 so it starts at top.
function changeActive(num){
oScroll[active].css.visibility = "hidden"
active = num
oScroll[active].css.top = 0+px
oScroll[active].css.visibility = "visible"
Initilizes the page, makes a oScroll Array and calls the object constructor.
Here you can add as many scrollObjects as you want
function scrollInit(){
oScroll = new Array()
// You can add and remove scrollObjects here.
oScroll[0] = new makeScrollObj('divScroll1','divCont')
oScroll[1] = new makeScrollObj('divScroll2','divCont')
oScroll[2] = new makeScrollObj('divScroll3','divCont')
oScroll[3] = new makeScrollObj('divScroll4','divCont')
oScroll[0].css.left = 0+px
oScroll[0].css.top = 0+px
oScroll[0].css.visibility = "visible"
oControl = new makeScrollObj('divControl')
oControl.css.visibility = "visible"
Executes the scrollInit function on pageload.
onload = scrollInit;
Multiple Scripts
If you have two or more scripts that use the onload event, probably only one will run (the last one).
Here is a solution for starting multiple scripts onload:
1. Delete or comment out all the onload assignments, onload=initScroll and things like that.
2. Put the onload assignments in the body tag like in this example, note that they must have braces ().
Example: <body onload="initScroll(); initTooltips(); initMenu();">
div:ar:
<div id="divControl">
<a href="#" onMouseDown="scroll(5)" onmouseup="noScroll()" onclick="return false"><img src="/gfx/pil_upp.gif" border="0"></a><br><br><br><br><br><br><br><br><br>
<a href="#" onMouseDown="scroll(-5)" onmouseup="noScroll()" onclick="return false"><img src="/gfx/pil_ner.gif" border="0"></a>
<div id="divCont">
<div id="divScroll1" class="clScroll">
BLAHAHAHAHAHAA<br><br><br>
BLAHAHAHAHAHAA<br><br><br><br>
Red:) Usch vad mycket det blev ;)
Jag är skum
[Redigerat av OveRRidE den 22 nov 2001]
