javascript som inte funkar på Mac???
2 svar · 189 visningar · startad av timedia
timediaMedlem sedan maj 2001420 inlägg
Detta script funkar (enligt uppgift)inte på mac. (Det blir page not found) Någon duktig som hittar felet?
<script  language="JavaScript">
/* Note that screen height and screen width refers to the size of the
   monitor (as opposed to the browser window). */
var screen_width = null;
var screen_height = null;
var resolution = null;
<script language="JavaScript1.2">
screen_width = screen.width;
screen_height = screen.height;
<script language="JavaScript1.1">
if (navigator.appName == "Netscape" && navigator.javaEnabled()) {
 var toolkit = java.awt.Toolkit.getDefaultToolkit();
 if (!screen_width) {
  var screen_size = toolkit.getScreenSize();
  screen_width = screen_size.width;
  screen_height = screen_size.height;
 resolution = toolkit.getScreenResolution();
if (screen_width && screen_height) {
 if (!resolution) {
  // Screen width and height have been calculated.
  // You may do whatever you wish with the three calculations here.
  // The example below transfers to another page based on the
  // width of the screen:
  if (screen_width < 700)
   location.href = "big/index.htm";
  else if (screen_width < 900)
   location.href = "small/index.htm";
 } else {
  // Screen width, height, AND resolution have been calculated.
  if (resolution < 80)
   location.href = "page4.htm";
   location.href = "page5.htm";
} else {
 // screen width, height, or resolution could not be calculated
 // default action goes here
 document.write("<table width=486><tr><td><font color='red'>"
  + "You do not have Java properly installed in order to facilitate "
  + "parsing your screen size and resolution."
  + "</font></td></tr></table>");
www.moviemix.nu
[Redigerat av timedia den 09 okt 2001]
g33kMedlem sedan okt. 200116 inlägg
Det scriptet fungerar alldeles utmärkt på min Mac.
Meningen med scriptet är juh att skicka besökaren till olika sidor beroende på skärmupploösning.
Det kan inte vara så att det är sidan besökaren blir skickad till som inte existerar och det är därför du får ett 404 error?
I am not 3vil, I am r00t
ChainsawMedlem sedan sep. 20001 124 inlägg
Dessutom gör du ju amatörmisstaget att kolla vilken upplösning användaren har, inte hur stort fönstret är.
Hollowhead - levererar din dagliga dos av nyttig hårdrock!
130 ms totalt · 3 externa anrop · v20260731065814-full.b943c234
