Detta script funkar (enligt uppgift)inte på mac. (Det blir page not found) Någon duktig som hittar felet?
/* Note that screen height and screen width refers to the size of the
monitor (as opposed to the browser window). */
var screen_width = null;
var screen_height = null;
var resolution = null;
<script language="JavaScript1.2">
screen_width = screen.width;
screen_height = screen.height;
<script language="JavaScript1.1">
if (navigator.appName == "Netscape" && navigator.javaEnabled()) {
var toolkit = java.awt.Toolkit.getDefaultToolkit();
if (!screen_width) {
var screen_size = toolkit.getScreenSize();
screen_width = screen_size.width;
screen_height = screen_size.height;
resolution = toolkit.getScreenResolution();
if (screen_width && screen_height) {
if (!resolution) {
// Screen width and height have been calculated.
// You may do whatever you wish with the three calculations here.
// The example below transfers to another page based on the
// width of the screen:
if (screen_width < 700)
location.href = "big/index.htm";
else if (screen_width < 900)
location.href = "small/index.htm";
} else {
// Screen width, height, AND resolution have been calculated.
if (resolution < 80)
location.href = "page4.htm";
location.href = "page5.htm";
} else {
// screen width, height, or resolution could not be calculated
// default action goes here
document.write("<table width=486><tr><td><font color='red'>"
+ "You do not have Java properly installed in order to facilitate "
+ "parsing your screen size and resolution."
+ "</font></td></tr></table>");
www.moviemix.nu
[Redigerat av timedia den 09 okt 2001]
