Google maps funktion för att returnera koordinater
JavaScript
12 svar · 1 953 visningar · startad av Mattias Nordin
Medlem sedan dec. 20051 056 inlägg
Har hittat följande sida som visar koordinater från en adress. Har försökt att göra en funktion av detta skript som enbart returnerar X & Y med en adress som input men det vill sig inte. Någon wiz där ute som kan få till det?
http://gmaps-samples.googlecode.com/svn/trunk/geocoder/singlegeocode.html
html>
<meta name="viewport" content="initial-scale=1.0, user-scalable=no" />
<meta http-equiv="content-type" content="text/html; charset=UTF-8"/>
<title>Google Maps Example</title>
<script type="text/javascript" src="http://maps.google.com/maps/api/js?sensor=false"></script>
var map;
function initialize() {
    geocoder = new google.maps.Geocoder();
    var latlng = new google.maps.LatLng(60.472024, 8.468946);
    var myOptions = {
      zoom: 4,
      center: latlng,
      mapTypeId: google.maps.MapTypeId.ROADMAP
	map = new google.maps.Map(document.getElementById("map_canvas"), myOptions);
	alert("Code address ="  +funReturnCoordFromAddress('Norway'))
var geocoder;
function funReturnCoordFromAddress(iSearchString) {
	var address
    //var address = document.getElementById("address").value;
	address = iSearchString
	if (geocoder) {
		geocoder.geocode(
			{'address': address}, function(results, status){
			if (status == google.maps.GeocoderStatus.OK) {
				map.setCenter(results[0].geometry.location);
				var marker = new google.maps.Marker({
					map: map,
					position: results[0].geometry.location
				document.getElementById("target").value = results[0].geometry.location
				alert("Return this " +results[0].geometry.location)
				return results[0].geometry.location
			}else{
				alert("Geocode was not successful for the following reason: " + status);
<body onload="initialize();">
	<div id="map_canvas" style="width: 320px; height: 480px;"></div>
    <!input id="address" type="textbox" value="Sydney, NSW">
	<input id="target" type="textbox" value="">
    <!input type="button" value="Encode" onclick="codeAddress()">
results[0].geometry.location har två propertys som du kan kolla på:
results[0].geometry.location.b;
och
results[0].geometry.location.c;
enligt firebug.
redigerad: missförstod frågan ;) förlåt
Edit #2:
<html>
var map;
    var myOptions = {
      zoom: 4,
      center: latlng,
function codeAddress() {
	var searchText = document.getElementById("target").value;
	funReturnCoordFromAddress(searchText);
var geocoder;
function funReturnCoordFromAddress(address) {
	if (geocoder) {
		geocoder.geocode(
					map: map,
			}else{
	<input id="target" type="textbox" value="Stockholm, Sweden">
    <input type="button" value="Encode" onclick="codeAddress()">
den hämtar texten ifrån #target när du trycker på knappen
Hej =)
Att sätta ut nya flaggor går bra men att returnera koordinaten får jag inte till. Förstår inte koden till hundra om jag ska vara ärlig.
Alerten inuti funktionen returnerar rätt värde men den första alerten returnerar Undefined.
Det borde väl gå att få ut det första alert värdet?
SIDAN = http://www.filmsnutt.se/test2.asp
<html>
var map;
    var myOptions = {
      zoom: 4,
      center: latlng,
	[FONT="Arial Black"]alert(funReturnCoordFromAddress("Stockholm"))[/FONT]
var geocoder;
	if (geocoder) {
		geocoder.geocode(
					map: map,
				[FONT="Arial Black"]alert(results[0].geometry.location)[/FONT]
			}else{
results[0].geometry.location som din funktion retunera har två propertys en b och en c som retunera koordinaterna till dig.
Förstår inte riktigt. Nedan returnerar rätt...
men den andra alerten returnerar undefined. Funktionen verkar exekveras i en lustig ordning också.
Märkligt. Det jag försöker åstakomma är att alert(funReturnCoordFromAddress("Stockholm")) ska returnera (60.4545454, 8.453353).
Förvirrad...
funReturnCoordFromAddress sker inte direkt, det kan ta ett tag innan du få en response:
<html>
var map, geocoder;
    var myOptions = {
      zoom: 4,
      center: latlng,
function findLocation() {
	var re = funReturnCoordFromAddress(searchText, successFind);
function successFind(location) {
	var l = location.geometry.location;
	map.setCenter(l);
		map: map,
		position: l
	document.getElementById("x").value = l.b;
	document.getElementById("y").value = l.c;
function funReturnCoordFromAddress(address, fn) {
	if (geocoder) {
		geocoder.geocode(
				fn(results[0]);
			}else{
	<input type="text" id="x" />
	<input type="text" id="y" />
    <input type="button" value="Encode" onclick="findLocation()">
hoppas du förstå mer av denna kod, tagit bort mycket och skapat en funktion som man ta med i funReturnCoordFromAddress som man vill köra OM det bli en matchning av kartan.
Har en annan sida som jag labbar med som gör nästan samma sak: http://www.filmsnutt.se/test3.asp
<html>
var map;
    var myOptions = {
      zoom: 4,
      center: latlng,
	alert("4) Run function and return value = " +funReturnCoordFromAddress('Norway'))
	//funReturnCoordFromAddress('Finland')
var geocoder;
	alert("1) Inside function...")
	var address
	var varReturnThisValue
	if (geocoder) {
		geocoder.geocode(
				//document.getElementById("target").value = results[0].geometry.location
				varReturnThisValue = results[0].geometry.location
				alert("2) Return this value " +varReturnThisValue)
				//return results[0].geometry.location
			}else{
    }else{
	alert("not true")
alert("3) return varReturnThisValue = " +varReturnThisValue)
Kör man sidan så får jag följande output:
  1. Inside function...
  2. return varReturnThisValue = undefined
  3. run function and return value = undefined
  4. Return this value (60.472024, 8.468946)
Hur kan det komma sig att "2 Return this value (60.472024, 8.468946)" körs efter "4) run function and return value = undefined"
och hur kan det komma sig att "4) run function and return value = undefined" = undefined?
Hmmm...
Ahhh... ska testa din kod.
För anropet till google görs Asynchronous (är i princip som ett AJAX anrop), datan körs först när den den fått ett resultat.
Anledningen till att jag skull vilja ha en funktion som returnerade koordinaterna är att kunna få kartan mer dynamisk. Jag vill tex att default zoom och position ska vara på ett specifikt land beroende på parametrar från en databas.
var map, geocoder;
    var latlng = new google.maps.LatLng( [B][I]funReturnCoordFromAddress(<%=Russia%>) [/I][/B]);
    var myOptions = {
      zoom: 4,
      center: latlng,
Att behöva känna till alla koordinater statiskt känns bakvänt.
:stud
kör samma kod:
    var myOptions = {
      zoom: 4,
	funReturnCoordFromAddress("Stockholm, Sweden", center); //change Stockholm, Sweden to whatever you want to center by default.
Och infoga koden för funktionen center:
function center(location) {
	map.setCenter(location.geometry.location);
Så länge du inte sparar ner kordinaterna i en databas eller liknande så måste du hitta kordinaterna, så det kan bli lite fördröjning där.
Tackar för snabbkursen. Uppskattas =)
Börjar förstå konceptet lite mer nu tror jag ;)
var latlng = new google.maps.LatLng( funReturnCoordFromAddress(<%=Russia%>) );
Notera att Russia måste se ut som en sträng (javascript sträng) eller koordinater
263 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
126 ms — deklarationer (db)
124 ms — ändringar (db)
