StinaMedlem sedan jan. 200189 inlägg Är det någon som vet hur man ska göra för att denna ska funka även i Netscape.
HTML kod:
<html>
<title>Menu</title>
<script language="Javascript">
var currentTopic = 0;
var originalTopic = 0;
var lonePicks = "#1#"
var loneHeaderVal = "#" + currentTopic + "#";
function reveal(id)
if (ver4Verify)
if (document.all["topic" + id].style.display == "")
// Current topics is visible... turn invisible
document.all["topic" + id].style.display = "none";
currentTopic = 0;
// Current topic is invisible... turn visible... hide all other
if (currentTopic != 0)
// Hide other visible topic
if (lonePicks.indexOf(loneHeaderVal) == -1)
document.all["topic" + currentTopic].style.display = "none";
loneHeaderVal = "#0#";
document.all["topic" + id].style.display = "";
currentTopic = id;
function ver4Verify() {
if (navigator.appVersion.indexOf("4.") != -1) {
return true;
return false;
<body>
<!--Länk 1 -->
<table cellpadding="0" cellspacing="0">
<div id="link1">
<tr>
<td valign="center" height=20><A class="IE4Selectedclass" href="">
<td valign=center><A class="IE4Linkclass" href="javascript:reveal(1)">Länk 1</a></td>
</tr>
</table>
<div id="topic1" style="display: none" class="IE4divMargin">
<A class=IE4subtopicclass href="#">Länk 1.1</a><br>
<A class=IE4subtopicclass href="#">Länk 1.2</a><br>
<A class=IE4subtopicclass href="#">Länk 1.3</a><br>
<A class=IE4subtopicclass href="#">Länk 1.4</a><br>
<A class=IE4subtopicclass href="#">Länk 1.5</a><br>
<A class=IE4subtopicclass href="#">Länk 1.6</a><br>
<!-- Länk 2 -->
<div id="link2">
<tr>
<td valign=center><A class="IE4Linkclass" href="javascript:reveal(2)">Länk 2</a></td>
</tr>
</table>
<div id="topic2" style="display: none" class="IE4divMargin">
<A class=IE4subtopicclass href="#">Länk 2.1</a><br>
<A class=IE4subtopicclass href="#">Länk 2.2</a><br>
<A class=IE4subtopicclass href="#">Länk 2.3</a><br>
<A class=IE4subtopicclass href="#">Länk 2.4</a><br>
<A class=IE4subtopicclass href="#">Länk 2.5</a><br>
<A class=IE4subtopicclass href="#">Länk 2.6</a><br>
</html>
JohnsenMedlem sedan juli 2000836 inlägg Eftersom display är IE-specifikt går det inte att göra på det viset för att flytta lager i andra läsare. Jag gjorde ett litet test på en variant för en tid sedan, du kan ju se om det är något att ha: http://www.host4u.d2g.com/johnsen/tmen.html
- J-O-H-N-S-E-N -
JojoxxMedlem sedan juni 20004 308 inlägg Nja... display ingår faktiskt i CSS-standarden (CSS Level 2 - display), men Netscape 4.x stödjer inte dynamisk rendering (rendera om sidan efter det att den laddats). Men Netscape 6, och andra DOM1 kompatibla läsare kan använda det.
Lite modifikation
<html>
<title>Menu</title>
function reveal(id) {
if (document.all) {
if (document.all["topic" + id].style.display == "") {
currentTopic = 0;
} else {
if (currentTopic != 0) {
if (lonePicks.indexOf(loneHeaderVal) == -1) {
} else {
currentTopic = id;
} else if (document.getElementById) {
if (document.getElementById("topic" + id).style.display == "") {
document.getElementById("topic" + id).style.display = "none";
currentTopic = 0;
} else {
document.getElementById("topic" + currentTopic).style.display = "none";
} else {
document.getElementById("topic" + id).style.display = "";
currentTopic = id;
<body>
<!--Länk 1 -->
<div id="link1">
<tr>
</tr>
</table>
<!-- Länk 2 -->
<div id="link2">
<tr>
</tr>
</table>
</html>
/ J
JohnsenMedlem sedan juli 2000836 inlägg Trevligt, man lär sig något nytt varje dag. Inget verkar funka i Opera dock.
nakozMedlem sedan dec. 1999653 inlägg stina:
kan bara tipsa om en grej som gör din kod lite mer lättläst här på webforum...
spana in denna: http://cgi.webforum.nu/wf/ubbcode.html
mvh.
void[]
stash/$gu&-public(querystring)/n int{}bind "2" "say i own!" :)
StinaMedlem sedan jan. 200189 inlägg Är hemskt tacksam för alla era svar.
