Men MoreOver har en kod som fungerar både NS och i IE. Jag har försökt ändra koden till mina behov men det fungerar inte för jag kan knappt ngt javascript:
Här är deras Kod:
<!-- Start Of Moreover.com News Javascript Code -->
<SCRIPT LANGUAGE="Javascript">
// the array global_article is used to allow multiple categories
var global_article = new Array();
var global_article_counter = 0;
var article = null;
var early_exit = 1;
var moreover_text = 0;
function load_wizard()
var newwin = window.open("","clone","resizable,scrollbars,width=500");
document.forms.moreover_clone.submit();
return true;
</SCRIPT>
<SCRIPT LANGUAGE="Javascript" SRC="http://p.moreover.com/cgi-local/page?c=Sports: golf news&o=js&n=5">
</SCRIPT>
// load global_article array with articles from category
if (article != null)
early_exit = 0;
for (var article_counter = 0; article_counter < article.length; article_counter++)
global_article[global_article_counter] = article[article_counter];
global_article\[global_article_counter\].url += "' TARGET='\_blank";
global_article\[global_article_counter\].document_url += "' TARGET='\_blank";
global_article_counter++;
</SCRIPT>
if (global_article.length == 0)
if (early_exit)
document.writeln("<CENTER>Please reload this page to view the headlines</CENTER>");
document.writeln("<CENTER>Sorry, no articles matched your search criteria</CENTER>");
early_exit = 1;
</SCRIPT>
<SCRIPT LANGUAGE="Javascript" SRC="http://p.moreover.com/dr/wizard_text.js"></SCRIPT>
if (!early_exit)
var webfeed_heading = "";
var width = "400";
var numberofarticles = global_article.length;
var item_spacing = "5";
var cluster_bgcolor = "ffffff";
var cluster_border = "0";
var heading_display = "Yes";
var time_display = "Yes";
var cell_spacing = "0";
var cell_padding = "1";
var heading_bgcolor = "ffffff";
var heading_font = "Verdana, Arial,Helvetica, sans-serif";
var heading_font_size = "-1";
var heading_fgcolor = "333333";
var headline_bgcolor = "ffffff";
var headline_font = "Verdana, Arial,Helvetica, sans-serif";
var headline_font_size = "-1";
var headline_fgcolor = "333333";
var source_font = "Verdana, Arial,Helvetica, sans-serif";
var source_font_size = "-2";
var source_fgcolor = "ff6600";
var access_font = "Verdana, Arial,Helvetica, sans-serif";
var access_font_size = "-2";
var access_fgcolor = "ff6600";
var time_font = "Verdana, Arial,Helvetica, sans-serif";
var time_font_size = "-2";
var time_fgcolor = "ff6600";
var time = new Array(global_article.length);
// Print out the table containing the headlines
document.writeln("<CENTER><TABLE BORDER="+cluster_border+" BGCOLOR='#"+cluster_bgcolor+"' WIDTH='"+width+"' CELLPADDING=2 CELLSPACING=0>");
document.writeln("<tr><td align='center'><img src='http://i.moreover.com/images/moreover_wizard_link.gif' border='0'></td></tr>")
document.writeln("<TR><TD><CENTER><TABLE BGCOLOR='#"+cluster_bgcolor+"' CELLPADDING="+cell_padding+" CELLSPACING="+cell_spacing+" WIDTH='100%'>");
if (heading_display == "Yes")
// Print a new category heading
document.writeln("<TR BGCOLOR='#"+heading_bgcolor+"'><TD>");
document.writeln("<FONT SIZE="+heading_font_size+" FACE="+heading_font+" COLOR='#"+heading_fgcolor+"'>");
document.writeln("<B>"+webfeed_heading+"</B></FONT></TD></TR>");
// Start loop for articles
for (var counter=0; counter < numberofarticles; counter++)
if ((counter == (global_article.length - 1)) && moreover_text == 1)
headline_fgcolor = source_fgcolor;
time_display = "No";
// Print out the headline
document.writeln("\<TR BGCOLOR='#"+headline_bgcolor+"'\>\<TD\>\<A HREF='"+global_article\[counter\].url+"' \>");
document.writeln("\<FONT SIZE="+headline_font_size+" FACE="+headline_font+" COLOR='#"+headline_fgcolor+"'");
document.writeln("\>"+global_article\[counter\].headline_text+"...\</FONT\>\</A\>\<br\>");
// Print out the source
if ((counter != (global_article.length - 1)) || moreover_text != 1)
document.writeln("\<A HREF='"+global_article\[counter\].document_url+"' \>");
document.writeln("\<FONT FACE="+source_font+" SIZE="+source_font_size+" COLOR='#"+source_fgcolor+"'\>");
document.writeln(""+global_article\[counter\].source+"\</FONT\>\</A\> ");
// Print out reg/sub if appropriate
if (global_article\[counter\].access_status == "sub" || global_article\[counter\].access_status == "reg")
document.writeln(" \<A HREF='"+global_article\[counter\].access_registration+"'\>");
document.writeln("\<FONT FACE="+access_font+" SIZE="+access_font_size);
document.writeln(" COLOR='#"+access_fgcolor+"'\>"+global_article\[counter\].access_status+"\</FONT\>\</A\> ");
// Print out the harvest time
if (time_display == "Yes")
// Make a new date object
time\[counter\] = new Date(global_article\[counter\].harvest_time);
time\[counter\].setHours(time\[counter\].getHours() - (time\[counter\].getTimezoneOffset() / 60 )); // adjust the time to local
document.writeln("\<FONT FACE="+time_font+" SIZE="+time_font_size+" COLOR='#"+time_fgcolor+"'\>");
document.writeln(""+time\[counter\].toString()+"\</FONT\>");
document.writeln("\</TD\>\</TR\>\<TR BGCOLOR='#"+headline_bgcolor+"'\>\<TD BGCOLOR='#"+headline_bgcolor+"' HEIGHT="+item_spacing+"\>\</TD\>\</TR\>");
} // End of article loop
// Start of clone button code //
// NOTE: DO NOT REMOVE any of the code in this section //
document.writeln("<FORM METHOD='POST' ACTION='http://www.moreover.com/cgi-local/wizard_clone.pl' target='clone' name='moreover_clone'>");
document.writeln("<INPUT TYPE='hidden' NAME='heading_font_size' VALUE='-1'><INPUT TYPE='hidden' NAME='source_font_size' VALUE='-2'>")
document.writeln("<INPUT TYPE='hidden' NAME='cluster_width' VALUE='400'><INPUT TYPE='hidden' NAME='time_display' VALUE='Yes'>")
document.writeln("<INPUT TYPE='hidden' NAME='time_font' VALUE='Verdana, Arial,Helvetica, sans-serif'><INPUT TYPE='hidden' NAME='cluster_cellspacing' VALUE='0'>")
document.writeln("<INPUT TYPE='hidden' NAME='heading_font' VALUE='Verdana, Arial,Helvetica, sans-serif'><INPUT TYPE='hidden' NAME='number_of_headlines' VALUE='5'>")
document.writeln("<INPUT TYPE='hidden' NAME='cluster_bgcolor' VALUE='ffffff'><INPUT TYPE='hidden' NAME='search_keywords' VALUE=''>")
document.writeln("<INPUT TYPE='hidden' NAME='refine_category' VALUE=''><INPUT TYPE='hidden' NAME='time_fgcolor' VALUE='ff6600'>")
document.writeln("<INPUT TYPE='hidden' NAME='access_fgcolor' VALUE='ff6600'><INPUT TYPE='hidden' NAME='time_font_size' VALUE='-2'>")
document.writeln("<INPUT TYPE='hidden' NAME='headline_bgcolor' VALUE='ffffff'><INPUT TYPE='hidden' NAME='cluster_name' VALUE='c=Sports:%20golf%20news&o=js'>")
document.writeln("<INPUT TYPE='hidden' NAME='access_font_size' VALUE='-2'><INPUT TYPE='hidden' NAME='heading_display' VALUE='Yes'>")
document.writeln("<INPUT TYPE='hidden' NAME='headline_fgcolor' VALUE='333333'><INPUT TYPE='hidden' NAME='source_font' VALUE='Verdana, Arial,Helvetica, sans-serif'>")
document.writeln("<INPUT TYPE='hidden' NAME='access_font' VALUE='Verdana, Arial,Helvetica, sans-serif'><INPUT TYPE='hidden' NAME='headline_font_size' VALUE='-1'>")
document.writeln("<INPUT TYPE='hidden' NAME='headline_font' VALUE='Verdana, Arial,Helvetica, sans-serif'><INPUT TYPE='hidden' NAME='heading_bold' VALUE='Yes'>")
document.writeln("<INPUT TYPE='hidden' NAME='item_spacing' VALUE='5'><INPUT TYPE='hidden' NAME='wizard_brand' VALUE='moreover_new'>")
document.writeln("<INPUT TYPE='hidden' NAME='heading_bgcolor' VALUE='ffffff'><INPUT TYPE='hidden' NAME='cluster_cellpadding' VALUE='1'>")
document.writeln("<INPUT TYPE='hidden' NAME='heading_fgcolor' VALUE='333333'><INPUT TYPE='hidden' NAME='source_fgcolor' VALUE='ff6600'>")
document.writeln("<INPUT TYPE='hidden' NAME='cluster_border' VALUE='0'><INPUT TYPE='hidden' NAME='cluster_layout' VALUE='<br>'>")
document.writeln("</FORM>");
// End of clone button code //
document.writeln("</TABLE></CENTER></TD></TR></TABLE></CENTER>");
// This code is subject to the copyright and warranty restrictions detailed at
// http://www.moreover.com/wizard_copyright.html
// Copyright 2000 Moreover.com Inc. All rights reserved.
</SCRIPT>
<A HREF="http://www.moreover.com"><IMG SRC="http://i.moreover.com/images/moreover_link.gif" BORDER="0" HEIGHT="1" WIDTH="1" alt="news headlines"></A>
<!-- End Of Moreover.com News Javascript Code -->
Vore mycket tacksam för om någon kunde ändra koden så att man kan ändra url och ta bort allt onödigt.
//Mikael
//Mikael
