fade image till fade div?
0 svar · 449 visningar · startad av clacke
clackeMedlem sedan feb. 2003234 inlägg
Hej
Har ett mycket bra script som fade:ar bilder mycket snyggt, nu undrar jag om man kan göra om det så man kan fade en div med 2st bildknappar i utan att det hoppar när man har mouseover på bildknappen.
Js koden:
/****** User may alter these to change the fade effect ********/
var FadeInStep 	= 10;
var FadeOutStep 	= 10;
/****** Don't alter anything else **************/
if(!window.JSFX)
	JSFX=new Object();
JSFX.RolloverObjects=new Array();
JSFX.Rollover = function(name, img)
	JSFX.RolloverObjects[name]=new Image();
	JSFX.RolloverObjects[name].img_src = img;
	if(!JSFX.Rollover.postLoad)
		JSFX.RolloverObjects[name].src = img;
JSFX.Rollover.postLoad = false;
JSFX.Rollover.loadImages = function()
	var i;
	for(i in JSFX.RolloverObjects)
		r=JSFX.RolloverObjects[i];
		r.src=r.img_src;
JSFX.Rollover.error = function(n)
		alert("JSFX.Rollover - An Error has been detected\n"
			+ "----------------------------------\n"
			+ "You must define a JSFX.Rollover in your document\n"
			+ "JSFX.Rollover(\""+n+"\",\"your_on_img.gif\")\n"
			+ "(check the spelling of your JSFX.Rollovers)");
* Function    : findImg
* Description : In Netscape 4 images could be in layers so we might
*		    have to recurse the layers to find the image
JSFX.findImg = function(n, d)
	var img = d.images[n];
	if(!img && d.layers)
		for(var i=0 ; !img && i<d.layers.length ; i++)
			img=JSFX.findImg(n,d.layers[i].document);
	/*** Stop emails because the image was named incorrectly ***/
	if(!img)
		alert("JSFX.findImg - An Error has been detected\n"
			+ "You must define an image in your document\n"
			+ "<IMG SRC=\"your_image.ext\" NAME=\""+n+"\">\n"
			+ "(check the NAME= attribute of your images)");
		return(new Image());
	return img;
JSFX.ImageFadeRunning=false;
JSFX.ImageFadeInterval=30;
* Function    : imgFadeIn
* Description : This function is based on the turn_on() function
*		      of animate2.js (animated rollovers from [url]www.roy.whittle.com)[/url].
*		      Each image object is given a state.
*			OnMouseOver the state is switched depending on the current state.
*			Current state -> Switch to
*			null		->	OFF.
*			OFF		->	FADE_IN
*			FADE_OUT	->	FADE_IN
*			FADE_OUT	->	FADE_OUT_IN (if the new image is different)
*			FADE_IN_OUT->	FADE_IN (if the image is the same)
JSFX.imgFadeIn = function(img, imgSrc)
	if(img)
		if(img.state == null)
			img.state = "OFF";
			img.index = 0;
			img.next_on    = null;
		if(img.state == "OFF")
			img.src=imgSrc;
			img.currSrc = imgSrc;
			img.state = "FADE_IN";
			JSFX.startFading();
		else if( img.state == "FADE_IN_OUT"
			|| img.state == "FADE_OUT_IN"
			|| img.state == "FADE_OUT")
			if(img.currSrc == imgSrc)
				img.next_on = imgSrc;
				img.state="FADE_OUT_IN";
* Function    : imgFadeOut
* Description : This function is based on the turn_off function
*			OnMouseOut the state is switched depending on the current state.
*			ON		->	FADE_OUT.
*			FADE_IN	->	FADE_IN_OUT.
*			FADE_OUT_IN	->	FADE_IN. (after swapping to the next image)
JSFX.imgFadeOut = function(img)
	if(img)
		if(img.state=="ON")
			img.state="FADE_OUT";
			JSFX.startFading();
		else if(img.state == "FADE_IN")
			img.state="FADE_IN_OUT";
		else if(img.state=="FADE_OUT_IN")
			img.next_on == null;
			img.state = "FADE_OUT";
* Function    : startFading
* Description : This function is based on the start_animating() function
*			If the timer is not currently running, it is started.
*			Only 1 timer is used for all objects
JSFX.startFading = function()
	if(!JSFX.ImageFadeRunning)
		JSFX.ImageFadeAnimation();
* Function    : ImageFadeAnimation
* Description : This function is based on the Animate function
*		    Each image object has a state. This function
*		    modifies each object and (possibly) changes its state.
JSFX.ImageFadeAnimation = function()
	JSFX.ImageFadeRunning = false;
	for(i=0 ; i<document.images.length ; i++)
		var img = document.images[i];
		if(img.state)
				if(img.index < 100)
					img.index+=FadeInStep;
					img.index = 100;
				if(img.filters)
					img.filters.alpha.opacity = img.index;
					img.style.MozOpacity = img.index + "%"
				if(img.index == 100)
					img.state="ON";
					JSFX.ImageFadeRunning = true;
			else if(img.state == "FADE_IN_OUT")
				if(img.index < 100)
					img.index = 100;
				if(img.filters)
					img.style.MozOpacity = img.index + "%";
			else if(img.state == "FADE_OUT")
				if(img.index > 0)
					img.index-=FadeOutStep;
					img.index = 0;
				if(img.filters)
				if(img.index == 0)
					img.state="OFF";
			else if(img.state == "FADE_OUT_IN")
				if(img.index > 0)
					img.index = 0;
				if(img.filters)
				if(img.index == 0)
					img.src = img.next_on;
					img.currSrc = img.next_on;
					img.state="FADE_IN";
	/*** Check to see if we need to animate any more frames. ***/
	if(JSFX.ImageFadeRunning)
		setTimeout("JSFX.ImageFadeAnimation()", JSFX.ImageFadeInterval);
* Function    : hasOpacity
* Description : Tests if the browser allows Opacity
JSFX.hasOpacity = function(obj)
	if(document.layers)
		return false;
	if(window.opera)
		return false;
	return true;
* Function    : fadeIn /fadeOut
* Description : Detects browser that can do opacity and fades the images
*		    For browsers that do not support opacity it just does an image swap.
*		    (I only know about NS4 but maybe IE on a Mac also ?)
*		    For these functions to work you need to name the image
*			e.g. for an image named "home" you need
*			<IMG .... NAME="home">
*		    and you need 2 images, the on and the off image
JSFX.fadeIn = function(imgName, rollName)
	if(rollName == null)
		rollName=imgName;
	/*** Stop emails because the rollover was named incorrectly ***/
	if(!JSFX.RolloverObjects[rollName])
		JSFX.Rollover.error(rollName);
		return;
	var img = JSFX.findImg(imgName, document);
	if(JSFX.hasOpacity(img))
		JSFX.imgFadeIn(img, JSFX.RolloverObjects[rollName].img_src);
		if(img.offSrc==null)
			img.offSrc=img.src;
		img.src=JSFX.RolloverObjects[rollName].img_src;
JSFX.fadeOut = function(imgName)
		JSFX.imgFadeOut(img);
		img.src=img.offSrc;
* Function    : imgOn /imgOff
* Description : Included these functions so you can mix simple and
*		    fading rollovers without having to include 2 ".js" files
JSFX.imgOn = function(imgName, rollName)
		rollName=imgName;
		return;
	var img = JSFX.findImg(imgName,document);
		img.offSrc=img.src;
JSFX.imgOff = function(imgName)
	img.src=img.offSrc;
och html koden
<body onMouseOver="JSFX.fadeIn('home')" onMouseOut="JSFX.fadeOut('home')"><img name="home" class="imgFader">
Eller har du ett färdigt fade script där man fadar en div så vore det ju kanon, har kollat runt och har inte hittat något som funkar tillräckligt bra!
