Jag försöker att lägga in en slideshow. Orginalet(som jag hittade på internet)
fungerade perfekt, men den var gjort utan masterpage(om det nu har någon
betydelse), men jag har masterpage.
Felet uppkommer när nästa bild skall visas:
var c_interval = 5000;
window.setTimeout("getNextImage()", c_interval);
function getNextImage()
//Send the request to server with the current image url as the argument
CallServer(document.getElementById("photo").src, "");
function ReceiveServerData(rValue)
//Receive server's response of a string rValue, which is prepared in
the server's function
//GetCallbackResult()
var wds = rValue.split(";");
//Assign the transition effect
document.getElementById("photo").style.filter = wds[1];
//Preload the image file from server. When finishing download,
imageLoaded function will be called
//with the img object as the argument
var img = new Image();
img.onload = function(){ imageLoaded(this); }
img.onerror = function(){ imageError(this); }
img.onabort = function(){ imageError(this); }
img.src = wds[0];
function imageError(img)
//If image download errors occur, this function will be called.
window.setTimeout("getNextImage()", 1000);
function imageLoaded(img)
var photo = document.getElementById("photo");
//Find the image control object
photo.filters[0].apply();
//Apply the transition effect
photo.filters[0].play();
//Play the effect and display the new image
photo.src = img.src;
//Assign the image to the image control
//Initiate the next request
Error:
Rad: 18
Tecken: 13
Fel: object krävs
Kod: 0
Url: http://localhost:3195/willyes/
Jag skickade bara med javascriptet här jag tror inte att de andra behövs.
Scriptet ligger i headern i masterpagen.
Några förslag?
