Är det någon som kan hjälpa mig att få dessa script att funka ihop?
<script language="JavaScript1.2">
Cross browser Marquee script- © Dynamic Drive (www.dynamicdrive.com)
For full source code, 100's more DHTML scripts, and Terms Of Use, visit http://www.dynamicdrive.com
Credit MUST stay intact
//Specify the marquee's width (in pixels)
var marqueewidth="300px"
//Specify the marquee's height
var marqueeheight="25px"
//Specify the marquee's marquee speed (larger is faster 1-10)
var marqueespeed=2
//configure background color:
var marqueebgcolor="#DEFDD9"
//Pause marquee onMousever (0=no. 1=yes)?
var pauseit=1
//Specify the marquee's content (don't delete <nobr> tag)
//Keep all content on ONE line, and backslash any single quotations (ie: that\'s great):
var marqueecontent='<nobr><font face="Arial">Thank you for visiting <a href="http://www.dynamicdrive.com">Dynamic Drive.</a> If you find this script useful, please consider linking to us by <a href="../link.htm">click here.</a> Enjoy your stay!</font></nobr>'
////NO NEED TO EDIT BELOW THIS LINE////////////
marqueespeed=(document.all)? marqueespeed : Math.max(1, marqueespeed-1) //slow speed down by 1 for NS
var copyspeed=marqueespeed
var pausespeed=(pauseit==0)? copyspeed: 0
var iedom=document.all||document.getElementById
if (iedom)
document.write('<span id="temp" style="visibility:hidden;position:absolute;top:-100px;left:-9000px">'+marqueecontent+'</span>')
var actualwidth=''
var cross_marquee, ns_marquee
function populate(){
if (iedom){
cross_marquee=document.getElementById? document.getElementById("iemarquee") : document.all.iemarquee
cross_marquee.style.left=parseInt(marqueewidth)+8+"px"
cross_marquee.innerHTML=marqueecontent
actualwidth=document.all? temp.offsetWidth : document.getElementById("temp").offsetWidth
else if (document.layers){
ns_marquee=document.ns_marquee.document.ns_marquee2
ns_marquee.left=parseInt(marqueewidth)+8
ns_marquee.document.write(marqueecontent)
ns_marquee.document.close()
actualwidth=ns_marquee.document.width
lefttime=setInterval("scrollmarquee()",20)
window.onload=populate
function scrollmarquee(){
if (iedom){
if (parseInt(cross_marquee.style.left)>(actualwidth*(-1)+8))
cross_marquee.style.left=parseInt(cross_marquee.style.left)-copyspeed+"px"
if (ns_marquee.left>(actualwidth*(-1)+8))
ns_marquee.left-=copyspeed
if (iedom||document.layers){
with (document){
document.write('<table border="0" cellspacing="0" cellpadding="0"><td>')
if (iedom){
write('<div style="position:relative;width:'+marqueewidth+';height:'+marqueeheight+';overflow:hidden">')
write('<div style="position:absolute;width:'+marqueewidth+';height:'+marqueeheight+';background-color:'+marqueebgcolor+'" onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed">')
write('<div id="iemarquee" style="position:absolute;left:0px;top:0px"></div>')
write('</div></div>')
write('<ilayer width='+marqueewidth+' height='+marqueeheight+' name="ns_marquee" bgColor='+marqueebgcolor+'>')
write('<layer name="ns_marquee2" left=0 top=0 onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed"></layer>')
write('</ilayer>')
document.write('</td></table>')
<h4> </h4>
<table border="0" cellpadding="0" cellspacing="0"><tr><td width="600">
<!-- Här börjar exemplet -->
window.onload=function(){
initmenu();
var currentMenu=false;
var menues=new Array('sub1','sub2','sub3');
function sw(mnu,mode){
if(mode){
if(currentMenu){
if(currentMenu==mnu){changeStyle(mnu,'display','none');currentMenu=false;}else{changeStyle(currentMenu,'display','none');changeStyle(mnu,'display','block');currentMenu=mnu;}
} else {
} else if (document.getElementById) {
document.getElementById(mnu).style.display=(document.getElementById(mnu).style.display=='block')?'none':'block';
function changeStyle(Id,Property,Value){
if (document.all){
eval('document.all[Id].style.'+Property+'="'+Value+'"');
} else if (document.layers){
eval('document.layers[Id].'+Property+'="'+Value+'"');
} else if (document.getElementById){
eval('document.getElementById(Id).style.'+Property+'="'+Value+'"');
function initmenu(){
for(var n=0;n<menues.length;n++){
changeStyle(menues[n],'display','none');
<div onClick="sw('sub1');" style="width:100px;cursor:default;border:solid black 1 px;background-color:rgb(180,180,180);">Menu 1</div>
<div id="sub1" style="width:100px;border:solid black 1 px;background-color:rgb(220,220,220);"><a href="#">Val 1</a><br><a href="#">Val 2</a><br><a href="#">Val 3</a></div>
<div onClick="sw('sub2');" style="width:100px;cursor:default;border:solid black 1 px;background-color:rgb(180,180,180);">Menu 2</div>
<div id="sub2" style="width:100px;border:solid black 1 px;background-color:rgb(220,220,220);"><a href="#">Val 1</a><br><a href="#">Val 2</a><br><a href="#">Val 3</a></div>
<div onClick="sw('sub3');" style="width:100px;cursor:default;border:solid black 1 px;background-color:rgb(180,180,180);">Menu 3</div>
<div id="sub3" style="width:100px;border:solid black 1 px;background-color:rgb(220,220,220);"><a href="#">Val 1</a><br><a href="#">Val 2</a><br><a href="#">Val 3</a></div>
<!-- Här slutar exemplet -->
</td></tr></table>
