Validering fungerar men ändå inte
1 svar · 362 visningar · startad av jonne
jonneMedlem sedan jan. 20011 154 inlägg
Har ett valideringsscript som ser ut enligt följande:
function validateFormOnSubmit(theForm) {
	var reason = "";
	reason += validateEmpty(theForm.ffTelefon)
	reason += validateEmpty(theForm.ffOrt)
	reason += validateEmpty(theForm.ffpostnr)
	reason += validateEmpty(theForm.ffAdress)
	reason += validateEmpty(theForm.ffKontaktperson)
	reason += validateEmpty(theForm.ffOrgnr)
	reason += validateEmpty(theForm.ffForetagsnamn)
	reason += validateEmail(theForm.ffEmail)
	if (reason != "") {
		alert("Some fields need correction:\n" + reason);
		return false;
  return true;
// Empty
function validateEmpty(fld) {
    var error = "";
    if (fld.value.length == 0) {
        fld.style.background = '#f0cece';
        error = "Alla uppgifter ska vara ifyllda.\n"
    } else {
        fld.style.background = 'White';
    return error;
vilket fungerar på nedanstående som jag vill
<form action="?p=13" method="post" onsubmit="return validateFormOnSubmit(this)">
<label class="formfield_label">Företagsnamn <input type="text" name="ffForetagsnamn" id="ffForetagsnamn" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<label class="formfield_label">Organisationsnr <input type="text" name="ffOrgnr" id="ffOrgnr" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<label class="formfield_label">Kontaktperson <input type="text" name="ffKontaktperson" id="ffKontaktperson" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<label class="formfield_label">Adress <input type="text" name="ffAdress" id="ffAdress" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<label class="formfield_label">Postnummer <input type="text" name="ffpostnr" id="ffpostnr" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<label class="formfield_label">Ort <input type="text" name="ffOrt" id="ffOrt" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<label class="formfield_label">E-mail <input type="text" name="ffEmail" id="ffEmail" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<label class="formfield_label">Telefonnummer <input type="text" name="ffTelefon" id="ffTelefon" class="formfield_order" onfocus="this.className='form_focused formfield_order'" onblur="this.className='formfield_order'" /></label>
<br>
<br>
<input name="submit" type="submit" value="Skicka" />
MEN om jag lägger till ett fält som jag väljer att INTE validera då skickas formuläret iväg och det förekommer ingen validering.
Idéer någon?
Jag hatar javascript. Hittat felet. Hade med id:na på formulärfälten att göra. ID't för emailfältet hade kommit med på ett annat fält vilket gjorde att det spårade ur.
131 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
