Längst ner i processChange vill jag skriva ut värdet som kommer tillbaka från sendToServer i footext fältet..men det enda jag får ut är 'undefined'. (skriver jag ut det i sendToServer precis innan jag returnerar det så funkar det finfint). någon som förstår sånt här?
<html>
function processChange(currentform, act, noden, funkt) {
var url = "http://x.x.x.x/cgi-bin/ajaxmain";
/* Temperature(1) and Dim(3) functionalities */
if(funkt == 1 || funkt == 3){
var inputStr = currentform.datafield.value;
if(act == 'byfield'){
url += "?node=" + noden + "&function=" + funkt + "&action=" + act + "&val=" + inputStr;
} else {
url += "?node=" + noden + "&function=" + funkt + "&action=" + act;
var inputInt = parseInt(inputStr);
/* Plus button */
if(act == 'plus'){
inputInt++;
/* Minus button */
if(act == 'minus'){
inputInt--;
/* Typed in text field */
if(act == 'byfield'){}
/* ..And show the user.*/
currentform.datafield.value = inputInt;
} //end temperature-dim functionality
/* ON/OFF(4) functionality */
if(funkt == 4){
var status = currentform.onoffstatus.value;
url += "?node=" + noden + "&function=" + funkt + "&val=" + status;
if(currentform.onoffstatus.value == 'ON'){
currentform.onoff.value = "Turn on";
currentform.onoffstatus.value = "OFF";
} else {
currentform.onoff.value = "Turn off";
currentform.onoffstatus.value = "ON";
} //end ON/OFF functionality
document.fooform.footext.value = sendToServer(url);
} //end processChange
function sendToServer(url){
var xmlObj = null;
if(window.XMLHttpRequest){ /* The rest.. */
xmlObj = new XMLHttpRequest();
} else if(window.ActiveXObject){ /* M$IE */
xmlObj = new ActiveXObject("Microsoft.XMLHTTP");
} else {
return -1; /* No AJAX support */
xmlObj.onreadystatechange = function(){
/* Process the server response */
if(xmlObj.readyState == 4){
var str = xmlObj.responseXML.getElementsByTagName('data')[0].firstChild.data;
return str;
} //end readystate == 4
} //end onreadystatechange-function
xmlObj.open("GET", url, true);
xmlObj.setRequestHeader( "Content-Type" , "application/x-www-form-urlencoded; charset=iso-8859-1" );
xmlObj.send("");
}// end sendToServer(url)
<body>
<form name="fooform">
<input type="text" name="footext" size="100" value="foo">
<form>
<input type="text" name="onoffstatus" value="ON" size="1" disabled>
<input id="xmlObjbuttononoff" type="button" name="onoff" value="Turn off" onClick="processChange(this.form, 'onoffchange', '1', '4')">
<form>
<input id="xmlObjbuttontempminus" type="button" name="temp" value="-" onClick="processChange(this.form, 'minus', '2', '1')">
<input type="text" name="datafield" value="23" size="1" onChange="processChange(this.form, 'byfield', '2', '1')">
<input id="xmlObjbuttontempplus" type="button" name="temp" value="+" onClick="processChange(this.form, 'plus', '2', '1')">
</html>
