Bildbytes skript (onmouseover) sökes
1 svar · 199 visningar · startad av richardjoha
richardjohaMedlem sedan okt. 2005747 inlägg
Ska använda det i en meny där bild 1 byts mot bild 2..
enkelt men hittar inget bra någonstanns..
bossseMedlem sedan juni 2003718 inlägg
Kanske nåt i denna stilen då?
Omarbetat från exempel som finns här
http://www.dyn-web.com/dhtml/show-hide/
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<title>Show/Hide Layers</title>
<style type="text/css">
body { font: 12px/1.3 Verdana, arial, helvetica, sans-serif }
h1 { font-size: 16px;	}
h2 { font-size: 14px;	}
a:link { color:#33c }
a:visited { color:#339 }
#lnks { position:absolute; left:10px; top:60px; width:100px }
/* Include id's for all your layers here, with commas between.
	 Set width, left and top */
#lyr1, #lyr2, #lyr3, #lyr4 {
	position:absolute; visibility:hidden; z-index:100;
	left:110px; top:60px; width:300px;
</style>
  This code is from Dynamic Web Coding at http://www.dyn-web.com/
  Copyright 2001-3 by Sharon Paine
  See Terms of Use at http://www.dyn-web.com/bus/terms.html
  regarding conditions under which you may use this code.
  This notice must be retained in the code as is!
// set these variables equal to the original top and left of layers
var orig_x=150;  // layers' left
var orig_y=50;	// layers' top
// onresize for ns4
var origWidth, origHeight;
if (document.layers) {
	origWidth = window.innerWidth; origHeight = window.innerHeight;
	window.onresize = function() { if (window.innerWidth != origWidth || window.innerHeight != origHeight) history.go(0); }
var cur_lyr;	// holds id of currently visible layer
function swapLayers(id) {
  if (cur_lyr) hideLayer(cur_lyr);
  shiftLayerTo( id, orig_x, orig_y + getScrollY() );
  showLayer(id);
  cur_lyr = id;
function showLayer(id) {
  var lyr = getElemRefs(id);
  if (lyr && lyr.css) lyr.css.visibility = "visible";
function hideLayer(id) {
  if (lyr && lyr.css) lyr.css.visibility = "hidden";
function shiftLayerTo(id,x,y) {
  var px = document.layers? 0: "px";
  if (lyr && lyr.css) {
    lyr.css.top = y + px;
    lyr.css.left = x + px;
function getElemRefs(id) {
	var el = (document.getElementById)? document.getElementById(id): (document.all)? document.all[id]: (document.layers)? document.layers[id]: null;
	if (el) el.css = (el.style)? el.style: el;
	return el;
// credit to http://www.13thparallel.org for the following function
// returns amount of vertical scroll
function getScrollY() {
	var sy = 0;
	if (document.documentElement && document.documentElement.scrollTop)
		sy = document.documentElement.scrollTop;
	else if (document.body && document.body.scrollTop)
		sy = document.body.scrollTop;
	else if (window.pageYOffset)
		sy = window.pageYOffset;
	else if (window.scrollY)
		sy = window.scrollY;
	return sy;
<body onload="swapLayers('lyr1')">
<div id="lnks">
<!-- Links for showing/hiding can include status bar message,
		 as first link demonstrates. -->
<a href="javascript://" onmouseover="swapLayers('lyr2'); return false" onmouseover="window.status='Show Intro layer'; return true" onmouseout="window.status=''"><img src=001.jpg width=50 height=50></a>
<br><br>
<a href="javascript://" onmouseover="swapLayers('lyr3'); return false"><img src=002.jpg width=50 height=50 ></a>
<br><br>
<a href="javascript://" onmouseover="swapLayers('lyr4'); return false"><img src=003.jpg width=50 height=50 ></a>
<div id="lyr1">
<div id="lyr2">
<img src=001.jpg >
<div id="lyr3">
<img src=002.jpg >
<div id="lyr4">
<img src=003.jpg >
</html>
125 ms totalt · 3 externa anrop · cache AV · v20260731051352-full.56cc9887
