undefined i dhtml-scriptet
12 svar · 236 visningar · startad av WebbisNet
WebbisNetMedlem sedan feb. 20032 182 inlägg
Detta script funkade perfekt med access, nu har jag MySQL och jag får nu undefined istället för meddelandet, alla poster sparas som de ska i databasen
* Memory Ticker script- © Dynamic Drive DHTML code library ([url]www.dynamicdrive.com[/url])
* This notice MUST stay intact for legal use
* Visit Dynamic Drive at [url]http://www.dynamicdrive.com/[/url] for full source code
//configure tickercontents[] to set the messges you wish be displayed (HTML codes accepted)
//Backslash any apostrophes within your text (ie: I\'m the king of the world!)
<%If user.EOF then
	Response.Write "Inga data finns"
Else
	response.write "var tickercontents=new Array()"
i=0
	Do until user.eof
tickercontents[<%=i%>]='<a class="menu" target="_top" href="/view.asp?userID=<%=user("userID")%>"><%=user("username")%>:&nbsp; <%=left(Mid(Server.HTMLEncode(user("message")),15),120)%></a>'
i=i+1
user.MoveNext: Loop
	End If%>
var persistlastviewedmsg=1 //should messages' order persist after users navigate away (1=yes, 0=no)?
var persistmsgbehavior="onload" //set to "onload" or "onclick".
//configure the below variable to determine the delay between ticking of messages (in miliseconds):
var tickdelay=10000
////Do not edit pass this line////////////////
var divonclick=(persistlastviewedmsg && persistmsgbehavior=="onclick")? 'onClick="savelastmsg()" ' : ''
var currentmessage=0
function changetickercontent(){
if (crosstick.filters && crosstick.filters.length>0)
crosstick.filters[0].Apply()
crosstick.innerHTML=tickercontents[currentmessage]
crosstick.filters[0].Play()
currentmessage=(currentmessage==tickercontents.length-1)? currentmessage=0 : currentmessage+1
var filterduration=(crosstick.filters&&crosstick.filters.length>0)? crosstick.filters[0].duration*1000 : 0
setTimeout("changetickercontent()",tickdelay+filterduration)
function beginticker(){
if (persistlastviewedmsg && get_cookie("lastmsgnum")!="")
revivelastmsg()
crosstick=document.getElementById? document.getElementById("memoryticker") : document.all.memoryticker
function get_cookie(Name) {
var search = Name + "="
var returnvalue = ""
if (document.cookie.length > 0) {
offset = document.cookie.indexOf(search)
if (offset != -1) {
offset += search.length
end = document.cookie.indexOf(";", offset)
if (end == -1)
end = document.cookie.length;
returnvalue=unescape(document.cookie.substring(offset, end))
return returnvalue;
function savelastmsg(){
document.cookie="lastmsgnum="+currentmessage
function revivelastmsg(){
currentmessage=parseInt(get_cookie("lastmsgnum"))
currentmessage=(currentmessage==0)? tickercontents.length-1 : currentmessage-1
if (persistlastviewedmsg && persistmsgbehavior=="onload")
window.onunload=savelastmsg
if (document.all||document.getElementById)
document.write('<div id="memoryticker" '+divonclick+'></div>')
if (window.addEventListener)
window.addEventListener("load", beginticker, false)
else if (window.attachEvent)
window.attachEvent("onload", beginticker)
else if (document.all || document.getElementById)
window.onload=beginticker
Peter SMedlem sedan dec. 20025 484 inlägg
Posta koden som den syns i "Visa källa" (eller liknande) i webbläsaren.
<style type="text/css">
#memoryticker{
background-color: lightyellow;
width: 640px;
font: bold 10px Verdana;
/*Tip: add in height attribute here for multiple line scroller*/
border: 1px solid black;
padding: 1px;
/*Change 0.7 below to a different number if desired (0.7=0.7 seconds)*/
/*Remove below line to remove transitional effect in IE. Below line should always appear last within this CSS*/
filter: progid:DXImageTransform.Microsoft.GradientWipe(GradientSize=1.0 Duration=1,5)
</style>
.shadow {
font-size: 10px;
filter: DropShadow(Color=#000000, OffX=1, OffY=1, Positive=1);
width: 100%;
height: 7px;
</style>
<body style="background-color:#D4E6EA;">
<table width="100%" style="margin-left:0px; margin-top:0px; margin-right:0px; margin-bottom:0px;" border="0" cellpadding="0" cellspacing="0">
<tr>
<td valign="top" align="left" style="background-color:#D4E6EA;">
<a class="linkpresentation" href="/smsmessageinfo.asp" target="_top">
<img src="/images/lajvinfo.gif" border="0" /></a>
</td>
<td style="background-color:#D4E6EA;">
tickercontents[0]='<a class="menu" target="_top" href="/view.asp?userID=1">Webbisen:&nbsp; &#229;&#228;&#246;</a>'
tickercontents[1]='<a class="menu" target="_top" href="/view.asp?userID=1">Webbisen:&nbsp; test</a>'
tickercontents[2]='<a class="menu" target="_top" href="/view.asp?userID=1">Webbisen:&nbsp; V&#228;lkomna till lajven p&#229; webbisen</a>'
var tickdelay=10000
revivelastmsg()
if (offset != -1) {
if (end == -1)
return returnvalue;
I Internet Explorer får jag inga felmeddelanden med den koden.
Jag ser iaf undefined trots att jag inte ser ngt fel i koden eller den exekverade koden.
Fält Typ Attribut Null Standard Extra Åtgärd
mCounter int(11) Nej auto_increment
userID int(11) Ja 0
username varchar(50) Ja NULL
message longtext Ja NULL
messageTime varchar(50) Ja NULL
messageDate varchar(50) Ja NULL
Visar tinyint(1) Ja NULL
  1 1 Webbisen webbis04 medd testar 01:20:03 2005-11-14 0
  2 1 Webbisen webbis04 medd Välkomna till lajven på webbisen 01:21:50 2005-11-14 1
  3 1 Webbisen webbis04 medd test 01:24:32 2005-11-14 1
  4 1 Webbisen webbis04 medd åäö 01:32:06 2005-11-14 1
Men om du tar koden du postade senast och klistrar in den i ett nytt dokument; får du då något felmeddelande? Om inte, vad är då för kod som felet uppstår av?
det enda jag gjorde från förra gången då det funkade var att jag bytte från access till mysql och tömde db på alla data och la in nya
funkar här med när jag klistrar in den exekverade koden, frågan är då varför jag får undefined
utskrift av sql-satsen
INSERT INTO tblUsers_messagescroll(userID, username, message, messageTime, messageDate, Visar) VALUES(1,'Webbisen','webbis04 medd nytt test','15:07:37','2005-11-14', 1)
Ligger den där koden innanför <script>-taggar? Om inte, är det inget fel på den.
Kan du lägga upp sidan online, så att man kan ta en titt?
logga in med Demo och Demo på https://www.webbisen.com , det är lajven under menyn
om du klickar på Lajvinfo så ser du att alla meddelanden visas korrekt, det är bara där scriptet körs som jag får felet
Jag upplever inget JS-fel. Däremot får jag på index.asp:
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[MySQL][ODBC 3.51 Driver][mysqld-4.0.25-max]You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
/index.asp, line 17
NU funkar det helt plösligt i IE med Demokontot, men inte i Avant browser och funkar i FF2
Genererad på 378 ms · cache AV · v20260730165559-full.f96bc7eb
