Jag försöker få till ett XMLHttpRequest.open kall mot en annan domän (utvecklar lokalt nu men vill även att det i produktion skall gå mot annan domän än skriptet kör på). Det funkar i IE men i FF får jag "Permission denied to call method XMLHttpRequest.open".
Finns det ett sätt att komma runt detta? Och vad beror det på?
Tack.
Richard
Kod:
// global flag
var isIE = false;
// global request and XML document objects
var req;
// retrieve XML document (reusable generic function);
// parameter is URL string (relative or complete) to
// an .xml file whose Content-Type is a valid XML
// type, such as text/xml; XML source must be from
// same domain as HTML file
function loadXMLDoc(url) {
alert(url)
// branch for native XMLHttpRequest object
if (window.XMLHttpRequest) {
req = new XMLHttpRequest();
req.onreadystatechange = processReqChange;
req.open("GET", url, true);
req.send(null);
// branch for IE/Windows ActiveX version
} else if (window.ActiveXObject) {
isIE = true;
req = new ActiveXObject("Microsoft.XMLHTTP");
if (req) {
req.send();
// handle onreadystatechange event of req object
function processReqChange() {
// only if req shows "loaded"
if (req.readyState == 4) {
// only if "OK"
if (req.status == 200) {
alert(req.responseText);
} else {
alert("There was a problem retrieving the XML data:\n" +
req.statusText);
// invoked by "Category" select element change;
// loads chosen XML document, clears Topics select
// element, loads new items into Topics select element
function loadDoc(evt) {
// equalize W3C/IE event models to get event object
evt = (evt) ? evt : ((window.event) ? window.event : null);
if (evt) {
// equalize W3C/IE models to get event target reference
var elem = (evt.target) ? evt.target : ((evt.srcElement) ? evt.srcElement : null);
if (elem) {
try {
if (elem.selectedIndex > 0) {
loadXMLDoc(elem.options[elem.selectedIndex].value);
catch(e) {
var msg = (typeof e == "string") ? e : ((e.message) ? e.message : "Unknown Error");
alert("Unable to get XML data:\n" + msg);
return;
