Hur ändra teckenstorlek i scriptet?
2 svar · 325 visningar · startad av tuss
tussMedlem sedan aug. 200429 inlägg
Jag vill ha större teckenstorleken på detta rullande script. Jag kopierade hela sidan. Hoppas att nån vänlig själ kan hjälpa mig.
<html>
<title>Untitled Document</title>
<body bgcolor="#B0C4DE" text="#003366">
<script language="JavaScript1.2">
Cross browser Marquee script- © Dynamic Drive (https://www.dynamicdrive.com)
For full source code, 100's more DHTML scripts, and Terms Of Use, visit http://www.dynamicdrive.com
Credit MUST stay intact
//Specify the marquee's width (in pixels)
var marqueewidth="1005px"
//Specify the marquee's height
var marqueeheight="20px"
//Specify the marquee's marquee speed (larger is faster 1-10)
var marqueespeed=1
//configure background color:
var marqueebgcolor="#F1F1EB"
//Pause marquee onMousever (0=no. 1=yes)?
var pauseit=0
//Specify the marquee's content (don't delete <nobr> tag)
//Keep all content on ONE line, and backslash any single quotations (ie: that's great):
var marqueecontent='<nobr><font face="Verdana">Det är den här texten jag vill ska rulla men med ett större typsnitt</font></nobr>'
////NO NEED TO EDIT BELOW THIS LINE////////////
marqueespeed=(document.all)? marqueespeed : Math.max(1, marqueespeed-1) //slow speed down by 1 for NS
var copyspeed=marqueespeed
var pausespeed=(pauseit==0)? copyspeed: 0
var iedom=document.all||document.getElementById
if (iedom)
document.write('<span id="temp" style="visibility:hidden;position:absolute;top:-100px;left:-9000px">'+marqueecontent+'</span>')
var actualwidth=''
var cross_marquee, ns_marquee
function populate(){
if (iedom){
cross_marquee=document.getElementById? document.getElementById("iemarquee") : document.all.iemarquee
cross_marquee.style.left=parseInt(marqueewidth)+8+"px"
cross_marquee.innerHTML=marqueecontent
actualwidth=document.all? temp.offsetWidth : document.getElementById("temp").offsetWidth
else if (document.layers){
ns_marquee=document.ns_marquee.document.ns_marquee2
ns_marquee.left=parseInt(marqueewidth)+8
ns_marquee.document.write(marqueecontent)
ns_marquee.document.close()
actualwidth=ns_marquee.document.width
lefttime=setInterval("scrollmarquee()",20)
window.onload=populate
function scrollmarquee(){
if (iedom){
if (parseInt(cross_marquee.style.left)>(actualwidth*(-1)+8))
cross_marquee.style.left=parseInt(cross_marquee.style.left)-copyspeed+"px"
if (ns_marquee.left>(actualwidth*(-1)+8))
ns_marquee.left-=copyspeed
if (iedom||document.layers){
with (document){
document.write('<table border="0" cellspacing="0" cellpadding="0"><td>')
if (iedom){
write('<div style=" position:relative;width:'+marqueewidth+';height:'+marqueehei
ght+';overflow:hidden">')
write('<div style=" position:absolute;width:'+marqueewidth+';height:'+marqueehei
ght+';background-color:'+marqueebgcolor+'" onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed">')
write('<div id="iemarquee" style="position:absolute;left:0px;top:0px"></div>')
write('</div></div>')
write('<ilayer width='+marqueewidth+' height='+marqueeheight+' name="ns_marquee" bgColor='+marqueebgcolor+'>')
write('<layer name="ns_marquee2" left=0 top=0 onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed"></layer>')
write('</ilayer>')
document.write('</td></table>')
</html>
Tack på förhand! Tuss
Hejsan!
Använd kodtaggarna ([kod]kod här[/kod]) när du postar kod.
Jag har lagt till en variabel fontsze där du anger storleken. Kom ihåg att ändra marqueeheight därefter.
<html>
Cross browser Marquee script- © Dynamic Drive ([url]www.dynamicdrive.com[/url])
For full source code, 100's more DHTML scripts, and Terms Of Use, visit [url]http://www.dynamicdrive.com[/url]
var marqueeheight="30px"
var marqueespeed=1
var pauseit=0
var fontsze = "24px";
var marqueecontent='<span style="font-size:' + fontsze + '"><nobr><font face="Verdana">Det är den här texten jag vill ska rulla men med ett större typsnitt</font></nobr></span>'
if (iedom)
var actualwidth=''
if (iedom){
if (iedom){
with (document){
if (iedom){
write('<div style=" position:relative;width:'+marqueewidth+';height:'+marqueeheight+';overflow:hidden">')
write('<div style=" position:absolute;width:'+marqueewidth+';height:'+marqueeheight+';background-color:'+marqueebgcolor+'" onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed">')
write('</ilayer>')
</html>
Vänligen korsposta inte i flera forum. Tråden låses med hänvisning till wFs förhållningsregler.
