Varför fungerar detta i Explorer men inte i Firefox
5 svar · 294 visningar · startad av kicki_an
kicki_anMedlem sedan jan. 200556 inlägg
Fäljande kod, en drop-down fungerar ypperligt i Explorer men inte i Firefox.
I Firefox ligger inte menyn kvar tillräckligt länge för att man ska kunna välja en länk i menyn.
Vet inte om det har med <iframe>:n att göra.
<html>
<title>Dropdown</title>
<style type="text/css">
body {
	font-family: arial, helvetica, serif; font-size:11px;
a						{
	font-family: Arial, Helvetica, sans-serif;
	color:#000000;
	text-decoration:none;
	font-weight: normal;
	font-size: 11px;
a:hover 				{
	color:#ED1B23;
	font-size: 11px;
	text-decoration: none;
a:visited 				{
	font-size: 11px;
	color: #000000;
a:active 				{
	font-size: 11px;
	color: #ED1B23;
ul { /* all lists */
	padding: 0;
	margin: 0;
	list-style: none;
li { /* all list items */
	float: left;
	position: relative;
	width: 10em;
	text-align: left;
	cursor: default;
	/*background-color: #EFF0F3;*/
li ul { /* second-level lists */
	display: none;
	position: absolute;
	top: 1em;
	left: 0;
	border-bottom:1px solid #9E9FA3;
	border-left:1px solid #9E9FA3;
	border-right:1px solid #9E9FA3;
	/*border: 1px solid #7d6340;
	border-width: 1px 0;
	margin-top:4px*/
li>ul { /* to override top and left in browsers other than IE, which will position to the top right of the containing li, rather than bottom left */
	top: auto;
	left: auto;
li:hover ul, li.over ul { /* lists nested under hovered list items */
	display: block;
#content {
	clear: left;
</style>
<script type="text/javascript"><!--//--><![CDATA[//><!--
startList = function() {
	if (document.all&&document.getElementById) {
		navRoot = document.getElementById("nav");
		for (i=0; i<navRoot.childNodes.length; i++) {
			node = navRoot.childNodes[i];
			if (node.nodeName=="LI") {
				node.onmouseover=function() {
					this.className+=" over";
				node.onmouseout=function() {
					this.className=this.className.replace(" over", "");
window.onload=startList;
//--><!]]></script>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"></head>
<body>
<table>
<tr>
<td>
<ul id="nav">
	<li>&nbsp; Våra resor
		<ul><div style="margin-top:4px; margin-left:4px; margin-bottom:4px; margin-right:4px;">
		<li><a href="#">Länk nummer 1</a></li>
        <li><a href="#">Länk nummer 2</a></li>
        <li><a href="#">Länk nummer 3</a></li>
        <li><a href="#">Länk nummer 4</a></li>
        <li><a href="#">Länk nummer 5</a></li>
        <li><a href="#">Länk nummer 6</a></li>
        <li><a href="#">Länk nummer 7</a></li>
        <li><a href="#">Länk nummer 8</a></li>
        <li><a href="#">Länk nummer 9</a></li>
 		</div></ul>
	</li>
</ul>
</td></tr>
<tr><td>
<iframe src="" width="550" height="400">
</iframe>
</td>
</tr>
</table>
</html>
Det har med iframen att göra och det beror på att du får en onmouseout när du går över i den.
Finns det något msn kan göra åt det?
Tryckfels-Nisse var framme...
Finns det något man kan göra för att komma runt det så att det inte blir "onmouseout"?
Tryckfelsnisse är välkommen att använda länken "redigera" högst upp till höger i aktuellt inlägg. ;)
Tack så mycket för tipset @nders. Ska tänka på det i fortsättningen.
