På följande script från JavascriptKit.com skulle jag vilja att det öppnar ett nytt fönster. Vad ska jag ändra?
// Menu script created by Kari Hollo, Finland
// Wish I got a job :(
// Use these files "as is". You may modify them freely.
// Modified by JavaScript Kit (http://www.javascriptkit.com)
// constants ********
//default/required menu images:
var myi=new Image; myi.src="icons/arrow__r.gif"; //submenu arrow
var myiw=new Image; myiw.src="icons/arrow__rw.gif"; //same as white
var myie=new Image; myie.src="icons/arrow__e.gif"; //empty pic
var myis=new Image; myis.src="icons/spacer.gif"; //spacer
var myisb=new Image; myisb.src="icons/spacer__b.gif"; //enpty end pic left to spacer
var kto=2000; //killTimeout [ms]
var mymenuwidth="160px" //menu width
var bg_color="#D6D6D6"; //colors...
var bg_color_hl="navy"; //syncronize with css file!!
var fg_color="black";
var fg_color_hl="white";
var spc="#SPACER#"; //spaser sign
var arr="#ARROW#"; //submenu sign
// caption/spacer,icon,gimmick/submenu
// MAIN MENU, DO NOT REMOVE, EDIT ONLY *********
var m1=new Array;
m1[0]=new Array("");
m1[1]=new Array("JavaScript Kit","icons/telkku.gif","goto('http://www.javascriptkit.com')");
m1[2]=new Array(spc); //add divider
m1[3]=new Array("Freewarejava"+arr,"icons/pelle.gif",11); //denote sub menu (using "arr")
m1[4]=new Array("Dynamic Drive","icons/pelle.gif","goto('http://www.dynamicdrive.com')");
m1[5]=new Array("Coding Forums","icons/pelle.gif","goto('http://www.codingforums.com')");
m1[6]=new Array("Technology Sites"+arr,"icons/pelle.gif",12); //denote sub menu (using "arr")
// name submenus reasonable!
// m1## 1.level, m2## 2.level and so on...
// 1ST SUB MENU
var m11=new Array;
m11[0]=new Array("");
m11[1]=new Array("Java Applets","icons/putki.gif","goto('http://freewarejava.com/applets/')");
m11[2]=new Array("Tutorials"+arr,"icons/pelle.gif",21);
m11[3]=new Array("Java Sites","icons/telkku.gif","goto('http://freewarejava.com/javasites/')");
m11[4]=new Array("Java Books","icons/telkku.gif","goto('http://freewarejava.com/books/')");
m11[5]=new Array("JSP and Servlets","icons/telkku.gif","goto('http://freewarejava.com/jsp/')");
// 1ST SUB MENU's SUB MENU
var m21=new Array;
m21[0]=new Array("");
m21[1]=new Array("Java Tutorials","icons/telkku.gif","goto('http://freewarejava.com/tutorials/')");
m21[2]=new Array("JavaScript Tutorials","icons/telkku.gif","goto('http://www.javascriptkit.com/javaindex.shtml')");
// 2ND SUB MENU
var m12=new Array;
m12[0]=new Array("");
m12[1]=new Array("News.com","icons/telkku.gif","window.open('http://www.news.com')");
m12[2]=new Array("Wired News","icons/putki.gif","window.open('http://wired.com')");
m12[3]=new Array("SlashDot","icons/telkku.gif","window.open('http://slashdot.org')");
//ENTER MENU IDs of above. UPDATE IF ADD/REMOVE MENUS!
var mvect=new Array(1,11,12,21);
// END OF EDITTING. variables ********
var th; //menu height
var tw; //menu width
var vas=0; //on left flag
var llv=false; //menu visible flag
var tid; //timeout id
var ksm=0; //known sub sub menu id
//************** FUNCTIONS
//******** base function to create menus
// error handler ***************
function stoperror(){
return true;
window.onerror=stoperror; //suppress potential JS errors. Comment line if you need to debug page.
function createMenus(){
for(xyzzy=0;xyzzy<mvect.length;xyzzy++){
document.write("<DIV id='teva"+mvect[xyzzy]+"' class='men'>");
document.write("<TABLE WIDTH='100%' BORDER=0 CELLSPACING=0 CELLPADDING=0>");
initMenu(mvect[xyzzy]);
document.write("</TABLE></DIV>");
//******** initialization
function initMenu(t){
var obj=eval("teva"+t); //container
var vect=eval("m"+t); //menu
var ve1; //caption
var ve2; //picture
var ve3; //trick/no of submenu
var spacers=0; //spacer counter
obj.style.height=(vect.length-1)*16+"px";
obj.style.width=mymenuwidth;
if(t==1){
th=obj.style.height.substr(0,obj.style.height.length-2);
tw=obj.style.width.substr(0,obj.style.width.length-2);
for(i=1;i<vect.length;i++){
ve1=eval("vect["+i+"][0]");
document.write("<TR>");
if(ve1==spc){
spacers++;
document.write("<TD colspan=3 style='height:8px;'>"+
"<img src='"+myisb.src+"' style='width:3px;height:2px;'>"+
"<img src='"+myis.src+"' style='width:95%;height:2px;'></TD>");
}else{
ve2=eval("vect["+i+"][1]");
ve3=eval("vect["+i+"][2]");
if(ve1.match(arr)){
var oy=16*(i-1)-spacers*8;
document.write("<TD class='imgtd' style='border:1px solid "+bg_color+";' "+
"id='m_"+t+"_"+i+"a' onmouseover='act_td("+t+","+i+");showSubMenu("+t+","+ve3+","+oy+");' "+
"onmouseout='nonact_td("+t+","+i+");'>"+
"<img id='m_"+t+"_"+i+"ap' src='"+ve2+"' class='icondimensions'></TD>");
document.write("<TD onmouseover='act_td("+t+","+i+");showSubMenu("+t+","+ve3+","+oy+");' "+
"onmouseout='nonact_td("+t+","+i+");' class='tdmenu' "+
"id='m_"+t+"_"+i+"'> "+ve1.substr(0,ve1.length-7)+"</TD>");
document.write("<td class='imgtd' id='m_"+t+"_"+i+"b' "+
"onmouseover='act_td("+t+","+i+");showSubMenu("+t+","+ve3+","+oy+");' "+
"<img class='arr' id='m_"+t+"_"+i+"bp' src='"+myi.src+"'></td>");
}else{
"id='m_"+t+"_"+i+"a' onmouseover='act_td("+t+","+i+");' "+
"onmouseout='nonact_td("+t+","+i+");' "+
"onclick='eval(m"+t+"["+i+"][2]);'>"+
document.write("<TD onmouseover='act_td("+t+","+i+");' "+
"onmouseout='nonact_td("+t+","+i+");' onclick='eval(m"+t+"["+i+"][2]);' "+
"class='tdmenu' id='m_"+t+"_"+i+"'> "+ve1+"</TD>");
document.write( "<td class='imgtd' id='m_"+t+"_"+i+"b' "+
"onmouseover='act_td("+t+","+i+");' "+
"<img class='emp' id='m_"+t+"_"+i+"bp' src='' width='12px' height='12px'></td>");
document.write("</TR>");
if(t==1){
obj.style.height=(vect.length-1)*16-spacers*8+"px";
// on hover **********
function act_td(t,i){
window.clearTimeout(tid);
var obj=eval("m_"+t+"_"+i);
if(t==1)
hideSubMenu();
hideKnownSubMenu(t);
obj.style.backgroundColor=bg_color_hl;
obj.style.color=fg_color_hl;
act1_td(eval(obj.id+"a")); //send cell id
act2_td(eval(obj.id+"b"));
// on mouse out *********
function nonact_td(t,i){
obj.style.backgroundColor=bg_color;
obj.style.color=fg_color;
nonact1_td(eval(obj.id+"a"));
nonact2_td(eval(obj.id+"b"));
tid=setTimeout('showMenu("mousedown")',kto);
//******** left=icon cell hover...
function act1_td(t){
var cel=eval(t);
var pix=eval(t.id+"p");
if(pix.src!=myie.src)
cel.style.border='1px outset';
else{
cel.style.border="1px solid "+bg_color_hl;
cel.style.backgroundColor=bg_color_hl;
// icon cell on mouse out *********
function nonact1_td(t){
var cel=eval(t);
cel.style.border="1px solid "+bg_color;
else{
cel.style.backgroundColor=bg_color;
//******** right cell for submenu arrow on hover
function act2_td(t){
var cel=eval(t);
if(cel.className!="emp") pix.src=myiw.src;
//********** same onmouseout........
function nonact2_td(t){
var cel=eval(t);
cel.style.color=fg_color;
if(cel.className!="emp") pix.src=myi.src;
// needs explanations?
function showMenu(e){
if(llv==true)
hideMenu();
else{
clearTimeout(tid);
var ah=document.body.clientHeight-th;
var aw=document.body.clientWidth-tw;
if(e.clientY \< ah) teva1.style.top=e.clientY;
else teva1.style.top=e.clientY-th;
if(e.clientX \< aw) {teva1.style.left=e.clientX;vas=0;}
else {teva1.style.left=e.clientX-tw;vas=1;}
teva1.style.visibility='visible';
llv=true;
tid=window.setTimeout("hideMenu()",kto);
function showSubMenu(c,t,y){
clearTimeout(tid);
var tobj=eval("teva"+c);
var ox=tobj.style.left.substr(0,tobj.style.left.length-2);
var oy=tobj.style.top.substr(0,tobj.style.top.length-2);
var oh=obj.style.height.substr(0,obj.style.height.length-2);
var ow=obj.style.width.substr(0,obj.style.width.length-2);
if(vas==0){
if(Math.round(ox) > Math.round(document.body.clientWidth)-Math.round(ow)*2-10)
obj.style.left=Math.round(ox)-Math.round(ow)+2;
obj.style.left=Math.round(ox)+Math.round(ow)-5;
}else
if(Math.round(oy)+Math.round(y) < Math.round(document.body.clientHeight)-Math.round(oh))
obj.style.top=Math.round(oy)+Math.round(y);
obj.style.top=Math.round(oy)+Math.round(y)-Math.round(oh);
obj.style.visibility='visible';
ksm=t;
function hideMenu(){
clearTimeout(tid);
teva1.style.visibility='hidden';
hideSubMenu();
llv=false;
function hideSubMenu(){
var obj;
for(j=1;j<mvect.length;j++){
obj=eval("teva"+mvect[j]);
obj.style.visibility='hidden';
function hideKnownSubMenu(t){
if(ksm>0 && ksm!=t){
var obj;
if(mvect[j]>t){
ksm=0;
function goto(url){
window.location=url
