Hej
Jag använder detta script för flytta options mellan 1 par selectboxar. Om du tittar på funtionen "allSelect()" så selectar den alla options i angiven selectbox vid submit. Detta funkar ju bra när jag bara har 1 par select boxar. Hur kan få detta dynamiskt så att jag kan aävända flere par select boxar?
function copyToList(from,to)
fromList = eval('document.forms[0].' + from);
toList = eval('document.forms[0].' + to);
if (toList.options.length > 0 && toList.options[0].value == 'temp')
toList.options.length = 0;
var sel = false;
for (i=0;i<fromList.options.length;i++)
var current = fromList.options[i];
if (current.selected)
sel = true;
if (current.value == 'temp')
alert ('You cannot move this text!');
return;
txt = current.text;
val = current.value;
toList.options[toList.length] = new Option(txt,val);
fromList.options[i] = null;
i--;
if (!sel) alert ('You haven\'t selected any options!');
function allSelect()
List = document.forms[0].chosen;
if (List.length && List.options[0].value == 'temp') return;
for (i=0;i<List.length;i++)
List.options[i].selected = true;
</SCRIPT>
Formuläret (med två par selectboxar)
<FORM onSubmit="allSelect(); return false">
<TABLE CELLPADDING=10 CELLSPACING=0 BORDER=1>
<TR><TD><P>Possible options:<BR>
<SELECT NAME="possible" SIZE="4" MULTIPLE WIDTH=200 STYLE="width: 200px">
<OPTION VALUE="1">Option 1: House</OPTION>
<OPTION VALUE="2">Option 2: Chamber</OPTION>
<OPTION VALUE="3">Option 3: Kitchen</OPTION>
<OPTION VALUE="4">Option 4: Garden</OPTION>
</SELECT></TD>
<TD><A HREF="javascript:copyToList('possible','chosen')">--></A><BR>
<A HREF="javascript:copyToList('chosen','possible')"><--</A></TD>
<TD><P>Chosen options:<BR>
<SELECT NAME="chosen" SIZE="4" MULTIPLE WIDTH=200 STYLE="width: 200px">
<OPTION VALUE="temp">Make your choice on the left
</SELECT></TD></TR>
<TR><TD COLSPAN=3 ALIGn=center></TD></TR>
</TABLE>
<SELECT NAME="possible2" SIZE="4" MULTIPLE WIDTH=200 STYLE="width: 200px">
</SELECT></TD>
<TD><A HREF="javascript:copyToList('possible2','chosen2')">--></A><BR>
<A HREF="javascript:copyToList('chosen2','possible2')"><--</A></TD>
<SELECT NAME="chosen2" SIZE="4" MULTIPLE WIDTH=200 STYLE="width: 200px">
</SELECT></TD></TR>
<TR><TD COLSPAN=3 ALIGn=center><INPUT TYPE=submit VALUE="submit"></TD></TR>
</TABLE>
</FORM>
Mvh Jimpa
