Är det nå´n som kan säga varför det inte går att skriva i formuläret på denna sida i Firefox?
<html>
<title>Insert Image</title>
<script type="text/javascript" src="popup.js"></script>
window.resizeTo(400, 100);
function Init() {
__dlg_init();
var param = window.dialogArguments;
if (param) {
document.getElementById("f_url").value = param["f_url"];
document.getElementById("f_alt").value = param["f_alt"];
document.getElementById("f_border").value = param["f_border"];
document.getElementById("f_align").value = param["f_align"];
document.getElementById("f_vert").value = param["f_vert"];
document.getElementById("f_horiz").value = param["f_horiz"];
window.ipreview.location.replace(param.f_url);
document.getElementById("f_url").focus();
function onOK() {
var required = {
"f_url": "You must enter the URL"
for (var i in required) {
var el = document.getElementById(i);
if (!el.value) {
alert(required[i]);
el.focus();
return false;
// pass data back to the calling window
var fields = ["f_url", "f_alt", "f_align", "f_border",
"f_horiz", "f_vert"];
var param = new Object();
for (var i in fields) {
var id = fields[i];
var el = document.getElementById(id);
param[id] = el.value;
__dlg_close(param);
return false;
function onCancel() {
__dlg_close(null);
return false;
function onPreview() {
var f_url = document.getElementById("f_url");
var url = f_url.value;
if (!url) {
alert("You have to enter an URL first");
f_url.focus();
return false;
window.ipreview.location.replace(url);
return false;
<body onload="Init()">
<div class="title">Insert Image</div>
<!--- new stuff --->
<form action="" method="get">
<table border="0" width="100%" style="padding: 0px; margin: 0px">
<tbody>
<tr>
<td style="width: 7em; text-align: right">Image URL:</td>
<td><input type="text" name="url" id="f_url" style="width:75%"
title="Enter the image URL here" value="pics/" />
<button name="preview" onclick="return onPreview();"
title="Preview the image in a new window">Preview</button>
</td>
</tr>
<tr>
<td style="width: 7em; text-align: right">Alternate text:</td>
<td><input type="text" name="alt" id="f_alt" style="width:100%"
title="For browsers that don't support images" /></td>
</tr>
</tbody>
</table>
<p />
<fieldset style="float: left; margin-left: 5px;">
<legend>Layout</legend>
<div class="space"></div>
<div class="fl">Alignment:</div>
<select size="1" name="align" id="f_align"
title="Positioning of this image">
<option value="" >Not set</option>
<option value="left" >Left</option>
<option value="right" >Right</option>
<option value="texttop" >Texttop</option>
<option value="absmiddle" >Absmiddle</option>
<option value="baseline" selected="1" >Baseline</option>
<option value="absbottom" >Absbottom</option>
<option value="bottom" >Bottom</option>
<option value="middle" >Middle</option>
<option value="top" >Top</option>
</select>
<p />
<div class="fl">Border thickness:</div>
<input type="text" name="border" id="f_border" size="5"
title="Leave empty for no border" />
</fieldset>
<fieldset style="float:right; margin-right: 5px;">
<legend>Spacing</legend>
<div class="fr">Horizontal:</div>
<input type="text" name="horiz" id="f_horiz" size="5"
title="Horizontal padding" />
<p />
<div class="fr">Vertical:</div>
<input type="text" name="vert" id="f_vert" size="5"
title="Vertical padding" />
</fieldset>
<br clear="all" />
<table width="100%" style="margin-bottom: 0.2em">
<tr>
<td valign="bottom">
Image Preview:<br />
<iframe name="ipreview" id="ipreview" frameborder="0" style="border : 1px solid gray;" height="200" width="300" src=""></iframe>
</td>
<td valign="bottom" style="text-align: right">
<button type="button" name="ok" onclick="return onOK();">OK</button><br>
<button type="button" name="cancel" onclick="return onCancel();">Cancel</button>
</td>
</tr>
</table>
</html>
