Ej skrivbara inputfält i firefox
3 svar · 226 visningar · startad av kolas
kolasMedlem sedan mars 2001142 inlägg
Är det nå´n som kan säga varför det inte går att skriva i formuläret på denna sida i Firefox?
<html>
  <title>Insert Image</title>
<script type="text/javascript" src="popup.js"></script>
window.resizeTo(400, 100);
function Init() {
  __dlg_init();
  var param = window.dialogArguments;
  if (param) {
      document.getElementById("f_url").value = param["f_url"];
      document.getElementById("f_alt").value = param["f_alt"];
      document.getElementById("f_border").value = param["f_border"];
      document.getElementById("f_align").value = param["f_align"];
      document.getElementById("f_vert").value = param["f_vert"];
      document.getElementById("f_horiz").value = param["f_horiz"];
      window.ipreview.location.replace(param.f_url);
  document.getElementById("f_url").focus();
function onOK() {
  var required = {
    "f_url": "You must enter the URL"
  for (var i in required) {
    var el = document.getElementById(i);
    if (!el.value) {
      alert(required[i]);
      el.focus();
      return false;
  // pass data back to the calling window
  var fields = ["f_url", "f_alt", "f_align", "f_border",
                "f_horiz", "f_vert"];
  var param = new Object();
  for (var i in fields) {
    var id = fields[i];
    var el = document.getElementById(id);
    param[id] = el.value;
  __dlg_close(param);
  return false;
function onCancel() {
  __dlg_close(null);
  return false;
function onPreview() {
  var f_url = document.getElementById("f_url");
  var url = f_url.value;
  if (!url) {
    alert("You have to enter an URL first");
    f_url.focus();
    return false;
  window.ipreview.location.replace(url);
  return false;
<body onload="Init()">
<div class="title">Insert Image</div>
<!--- new stuff --->
<form action="" method="get">
<table border="0" width="100%" style="padding: 0px; margin: 0px">
  <tbody>
  <tr>
    <td style="width: 7em; text-align: right">Image URL:</td>
    <td><input type="text" name="url" id="f_url" style="width:75%"
      title="Enter the image URL here" value="pics/" />
      <button name="preview" onclick="return onPreview();"
      title="Preview the image in a new window">Preview</button>
    </td>
  </tr>
  <tr>
    <td style="width: 7em; text-align: right">Alternate text:</td>
    <td><input type="text" name="alt" id="f_alt" style="width:100%"
      title="For browsers that don't support images" /></td>
  </tr>
  </tbody>
</table>
<p />
<fieldset style="float: left; margin-left: 5px;">
<legend>Layout</legend>
<div class="space"></div>
<div class="fl">Alignment:</div>
<select size="1" name="align" id="f_align"
  title="Positioning of this image">
  <option value=""                             >Not set</option>
  <option value="left"                         >Left</option>
  <option value="right"                        >Right</option>
  <option value="texttop"                      >Texttop</option>
  <option value="absmiddle"                    >Absmiddle</option>
  <option value="baseline" selected="1"        >Baseline</option>
  <option value="absbottom"                    >Absbottom</option>
  <option value="bottom"                       >Bottom</option>
  <option value="middle"                       >Middle</option>
  <option value="top"                          >Top</option>
</select>
<p />
<div class="fl">Border thickness:</div>
<input type="text" name="border" id="f_border" size="5"
title="Leave empty for no border" />
</fieldset>
<fieldset style="float:right; margin-right: 5px;">
<legend>Spacing</legend>
<div class="fr">Horizontal:</div>
<input type="text" name="horiz" id="f_horiz" size="5"
title="Horizontal padding" />
<p />
<div class="fr">Vertical:</div>
<input type="text" name="vert" id="f_vert" size="5"
title="Vertical padding" />
</fieldset>
<br clear="all" />
<table width="100%" style="margin-bottom: 0.2em">
 <tr>
  <td valign="bottom">
    Image Preview:<br />
    <iframe name="ipreview" id="ipreview" frameborder="0" style="border : 1px solid gray;" height="200" width="300" src=""></iframe>
  </td>
  <td valign="bottom" style="text-align: right">
    <button type="button" name="ok" onclick="return onOK();">OK</button><br>
    <button type="button" name="cancel" onclick="return onCancel();">Cancel</button>
  </td>
 </tr>
</table>
</html>
nitro2k01Medlem sedan aug. 20037 630 inlägg
Det går väl visst att skriva i dem? Värdena verkar dock inte "ta", men det gäller väl även IE?
OJ, testade nu efteråt att bara testa koden jag skrev här i inlägget och då fungerade det även för mig, felet kanske ligger i filen popup.js?
function getAbsolutePos(el) {
	var r = { x: el.offsetLeft, y: el.offsetTop };
	if (el.offsetParent) {
		var tmp = getAbsolutePos(el.offsetParent);
		r.x += tmp.x;
		r.y += tmp.y;
	return r;
function comboSelectValue(c, val) {
	var ops = c.getElementsByTagName("option");
	for (var i = ops.length; --i >= 0;) {
		var op = ops[i];
		op.selected = (op.value == val);
	c.value = val;
function __dlg_onclose() {
	opener.Dialog._return(null);
function __dlg_init(bottom) {
	var body = document.body;
	var body_height = 0;
	if (typeof bottom == "undefined") {
		var div = document.createElement("div");
		body.appendChild(div);
		var pos = getAbsolutePos(div);
		body_height = pos.y;
	} else {
		var pos = getAbsolutePos(bottom);
		body_height = pos.y + bottom.offsetHeight;
	window.dialogArguments = opener.Dialog._arguments;
	if (!document.all) {
		window.sizeToContent();
		window.sizeToContent();	// for reasons beyond understanding,
					// only if we call it twice we get the
					// correct size.
		window.addEventListener("unload", __dlg_onclose, true);
		// center on parent
		var x = opener.screenX + (opener.outerWidth - window.outerWidth) / 2;
		var y = opener.screenY + (opener.outerHeight - window.outerHeight) / 2;
		window.moveTo(x, y);
		window.innerWidth = body.offsetWidth + 5;
		window.innerHeight = body_height + 2;
	} else {
		// window.dialogHeight = body.offsetHeight + 50 + "px";
		// window.dialogWidth = body.offsetWidth + "px";
		window.resizeTo(body.offsetWidth, body_height);
		var ch = body.clientHeight;
		var cw = body.clientWidth;
		window.resizeBy(body.offsetWidth - cw, body_height - ch);
		var W = body.offsetWidth;
		var H = 2 * body_height - ch;
		var x = (screen.availWidth - W) / 2;
		var y = (screen.availHeight - H) / 2;
	document.body.onkeypress = __dlg_close_on_esc;
function __dlg_translate(i18n) {
	var types = ["span", "option", "td", "button", "div"];
	for (var type in types) {
		var spans = document.getElementsByTagName(types[type]);
		for (var i = spans.length; --i >= 0;) {
			var span = spans[i];
			if (span.firstChild && span.firstChild.data) {
				var txt = i18n[span.firstChild.data];
				if (txt)
					span.firstChild.data = txt;
	var txt = i18n[document.title];
	if (txt)
		document.title = txt;
// closes the dialog and passes the return info upper.
function __dlg_close(val) {
	opener.Dialog._return(val);
	window.close();
function __dlg_close_on_esc(ev) {
	ev || (ev = window.event);
	if (ev.keyCode == 27) {
		window.close();
		return false;
	return true;
Är det nå´t fel med denna, jag är usel på javascript själv så i mina ögon är det bara bokstäver
Vadå är sidan alltså helt fryst?
Pröva att uppdatera till firefox 1.0 skarp version, så kanske det löser sig.
Men jag får det inte att funka alls (Alltså att man kan ändra formateringen på bilden). Dock så kan jag skriva i alla fält och ändra dropdown-lådan utan problem.
Genererad på 385 ms · cache AV · v20260730165559-full.f96bc7eb
