Validering av datum i formulär
6 svar · 450 visningar · startad av devotion
Har hittat nedanstående kod för validering av datum. Mitt problem är att den är skriven för amerikanskt datumformat. Dvs mm-dd-yyyy.
Finns det någon vänlig själ som kan hjälpa mig så det blir svenskt format. Dvs åååå-mm-dd?
Tack på förhand!
<html>
<title>Untitled Document</title>
<script language = "Javascript">
 * DHTML date validation script. Courtesy of SmartWebby.com ([url]http://www.smartwebby.com/dhtml/[/url])
// Declaring valid date character, minimum year and maximum year
var dtCh= "-";
var minYear=1900;
var maxYear=2100;
function isInteger(s){
	var i;
    for (i = 0; i < s.length; i++){
        // Check that current character is number.
        var c = s.charAt(i);
        if (((c < "0") || (c > "9"))) return false;
    // All characters are numbers.
    return true;
function stripCharsInBag(s, bag){
	var i;
    var returnString = "";
    // Search through string's characters one by one.
    // If character is not in bag, append to returnString.
        if (bag.indexOf(c) == -1) returnString += c;
    return returnString;
function daysInFebruary (year){
	// February has 29 days in any year evenly divisible by four,
    // EXCEPT for centurial years which are not also divisible by 400.
    return (((year % 4 == 0) && ( (!(year % 100 == 0)) || (year % 400 == 0))) ? 29 : 28 );
function DaysArray(n) {
	for (var i = 1; i <= n; i++) {
		this[i] = 31
		if (i==4 || i==6 || i==9 || i==11) {this[i] = 30}
		if (i==2) {this[i] = 29}
   return this
function isDate(dtStr){
	var daysInMonth = DaysArray(12)
	var pos1=dtStr.indexOf(dtCh)
	var pos2=dtStr.indexOf(dtCh,pos1+1)
	var strMonth=dtStr.substring(0,pos1)
	var strDay=dtStr.substring(pos1+1,pos2)
	var strYear=dtStr.substring(pos2+1)
	strYr=strYear
	if (strDay.charAt(0)=="0" && strDay.length>1) strDay=strDay.substring(1)
	if (strMonth.charAt(0)=="0" && strMonth.length>1) strMonth=strMonth.substring(1)
	for (var i = 1; i <= 3; i++) {
		if (strYr.charAt(0)=="0" && strYr.length>1) strYr=strYr.substring(1)
	month=parseInt(strMonth)
	day=parseInt(strDay)
	year=parseInt(strYr)
	if (pos1==-1 || pos2==-1){
		alert("Datumet skall ha formatet : mm-dd-yyyy")
		return false
	if (strMonth.length<1 || month<1 || month>12){
		alert("Fyll i en giltig månad")
		return false
	if (strDay.length<1 || day<1 || day>31 || (month==2 && day>daysInFebruary(year)) || day > daysInMonth[month]){
		alert("fyll i en giltig dag")
		return false
	if (strYear.length != 4 || year==0 || year<minYear || year>maxYear){
		alert("Fyll i ett giltigt fyrsiffrigt år "+minYear+" and "+maxYear)
		return false
	if (dtStr.indexOf(dtCh,pos2+1)!=-1 || isInteger(stripCharsInBag(dtStr, dtCh))==false){
		alert("Fyll i ett giltigt datum")
		return false
return true
function ValidateForm(){
	var dt=document.frmSample.txtDate
	if (isDate(dt.value)==false){
		dt.focus()
		return false
    return true
<body>
<form name="frmSample" method="post" action="" onSubmit="return ValidateForm()">
                <p>Enter a Date <font color="#CC0000"><b>(mm-dd-yyyy)</b></font>
                  <input type="text" name="txtDate" maxlength="10" size="15">
                </p>
                <p>
                  <input type="submit" name="Submit" value="Submit">
                </p>
</html>
JohnsenMedlem sedan juli 2000836 inlägg
Oj, det var mycket väsen för ingenting...
Prova detta: http://www.webforum.nu/showthread.php?s=&postid=380665#post380665
HEJ!
Håller med, jag har tre dd-rutor med år-månad-dag, som sätts ihop till en datumstäng med JavaScript.
pa = new Date(form.pa_ar.value, form.pa_man.value-1, form.pa_dag.value);
form.hid_pa.value = form.pa_ar.value + "-" + form.pa_man.value + "-" + form.pa_dag.value;
Detta behandlas (i mitt fall) med VBScript så att exempelvis 31/11 räknas om till 1/12.
hid_pa = Request.Form("hid_pa")
array1 = split(hid_pa,"-")
'DS fixar 31/11 till 1/12
datumpa = DateValue(DateSerial(array1(0),array1(1),array1(2)))
Ja, den koden var ju lite enklare... ;)
Har fått det att fungera med ETT datumfält. Hur modifierar jag koden till att innehålla TVÅ datumfält som båda ska valideras??
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<html>
<script LANGUAGE="javascript">
function validateDate(frm)
var datum    = frm.datum_start.value
var ar       = datum.substr(0,4);
var manad    = datum.substr(5,2);
var dag      = datum.substr(8,2);
var nytDatum = new Date(ar,manad-1,dag);
var msg = "Du måste skriva ett datum enligt: ÅÅÅÅ-MM-DD."
if(
 datum.length>10              ||
 datum.charAt(4)!="-"         ||
 datum.charAt(7)!="-"         ||
 nytDatum.getFullYear()!=ar   ||
 nytDatum.getMonth()+1!=manad ||
 nytDatum.getDate()!=dag
 ){alert(msg); return false;}
return true;
<body>
<form name="form1" method="post" action="insert.asp" onsubmit="return validateDate(this);">
  <p>&nbsp;  </p>
  <p>
    <input name="datum_start" type="text" id="datum_start">
</p>
  <p>
</p>
</html>
Ingen som kan hjälpa till lite???
<html>
function validateDate(datum)
var nyttDatum = new Date(ar,manad-1,dag);
if(
 datum.length>10              ||
 nyttDatum.getFullYear()!=ar   ||
 nyttDatum.getMonth()+1!=manad ||
 nyttDatum.getDate()!=dag
return true;
<body>
      onsubmit="return (validateDate(this.datum_start.value) && validateDate(this.datum_slut.value));">
  <p>
    <input name="datum_start" type="text">
  </p>
  <p>
    <input name="datum_slut" type="text">
  </p>
  <p>
</p>
</html>
Tack :f
144 ms totalt · 3 externa anrop · v20260731065814-full.30151723
