Vad gör denna kod? [JS]
3 svar · 302 visningar · startad av M.Cheraghi
M.CheraghiMedlem sedan juli 20013 362 inlägg
Va gör egentligen detta kodstycke?
Vad kan dra för nytta utav koden, vore kul att se användningsområdet, då det är ganska mycket kod, och jag begriper inget utav koden. :)
//  jsrsClient.js - javascript remote scripting client include
//  Author:  Brent Ashley [jsrs@megahuge.com]
//  make asynchronous remote calls to server without client page refresh
//  see license.txt for copyright and license information
see history.txt for full history
2.0  26 Jul 2001 - added POST capability for IE/MOZ
// callback pool needs global scope
var jsrsContextPoolSize = 0;
var jsrsContextMaxPool = 10;
var jsrsContextPool = new Array();
var jsrsBrowser = jsrsBrowserSniff();
var jsrsPOST = true;
// constructor for context object
function jsrsContextObj( contextID ){
  // properties
  this.id = contextID;
  this.busy = true;
  this.callback = null;
  this.container = contextCreateContainer( contextID );
  // methods
  this.GET = contextGET;
  this.POST = contextPOST;
  this.getPayload = contextGetPayload;
  this.setVisibility = contextSetVisibility;
//  method functions are not privately scoped
//  because Netscape's debugger chokes on private functions
function contextCreateContainer( containerName ){
  // creates hidden container to receive server data
  var container;
  switch( jsrsBrowser ) {
    case 'NS':
      container = new Layer(100);
      container.name = containerName;
      container.visibility = 'hidden';
      container.clip.width = 100;
      container.clip.height = 100;
      break;
    case 'IE':
      document.body.insertAdjacentHTML( "afterBegin", '<span id="SPAN' + containerName + '"></span>' );
      var span = document.all( "SPAN" + containerName );
      var html = '<iframe name="' + containerName + '" src=""></iframe>';
      span.innerHTML = html;
      span.style.display = 'none';
      container = window.frames[ containerName ];
      break;
    case 'MOZ':
      var span = document.createElement('SPAN');
      span.id = "SPAN" + containerName;
      document.body.appendChild( span );
      var iframe = document.createElement('IFRAME');
      iframe.name = containerName;
      span.appendChild( iframe );
      container = iframe;
      break;
  return container;
function contextPOST( rsPage, func, parms ){
  var d = new Date();
  var unique = d.getTime() + '' + Math.floor(1000 * Math.random());
  var doc = (jsrsBrowser == "IE" ) ? this.container.document : this.container.contentDocument;
  doc.open();
  doc.write('<html><body>');
  doc.write('<form name="jsrsForm" method="post" target="" ');
  doc.write(' action="' + rsPage + '?U=' + unique + '">');
  doc.write('<input type="hidden" name="C" value="' + this.id + '">');
  // func and parms are optional
  if (func != null){
  doc.write('<input type="hidden" name="F" value="' + func + '">');
    if (parms != null){
      if (typeof(parms) == "string"){
        // single parameter
        doc.write( '<input type="hidden" name="P0" '
                 + 'value="[' + jsrsEscapeQQ(parms) + ']">');
      } else {
        // assume parms is array of strings
        for( var i=0; i < parms.length; i++ ){
          doc.write( '<input type="hidden" name="P' + i + '" '
                   + 'value="[' + jsrsEscapeQQ(parms[i]) + ']">');
      } // parm type
    } // parms
  } // func
  doc.write('</form></body></html>');
  doc.close();
  doc.forms['jsrsForm'].submit();
function contextGET( rsPage, func, parms ){
  // build URL to call
  var URL = rsPage;
  // always send context
  URL += "?C=" + this.id;
  if (func != null){
    URL += "&F=" + escape(func);
    if (parms != null){
        // single parameter
        URL += "&P0=[" + escape(parms+'') + "]";
      } else {
          URL += "&P" + i + "=[" + escape(parms[i]+'') + "]";
      } // parm type
    } // parms
  } // func
  // unique string to defeat cache
  var d = new Date();
  URL += "&U=" + d.getTime();
  // make the call
    case 'NS':
      this.container.src = URL;
      break;
    case 'IE':
      this.container.document.location.replace(URL);
      break;
    case 'MOZ':
      this.container.src = '';
      break;
function contextGetPayload(){
    case 'NS':
      return this.container.document.forms['jsrs_Form'].elements['jsrs_Payload'].value;
    case 'IE':
      return this.container.document.forms['jsrs_Form']['jsrs_Payload'].value;
    case 'MOZ':
      return window.frames[this.container.name].document.forms['jsrs_Form']['jsrs_Payload'].value;
function contextSetVisibility( vis ){
    case 'NS':
      this.container.visibility = (vis)? 'show' : 'hidden';
      break;
    case 'IE':
      document.all("SPAN" + this.id ).style.display = (vis)? '' : 'none';
      break;
    case 'MOZ':
      document.getElementById("SPAN" + this.id).style.visibility = (vis)? '' : 'hidden';
      this.container.width = (vis)? 250 : 0;
      this.container.height = (vis)? 100 : 0;
      break;
// end of context constructor
function jsrsGetContextID(){
  var contextObj;
  for (var i = 1; i <= jsrsContextPoolSize; i++){
    contextObj = jsrsContextPool[ 'jsrs' + i ];
    if ( !contextObj.busy ){
      contextObj.busy = true;
      return contextObj.id;
  // if we got here, there are no existing free contexts
  if ( jsrsContextPoolSize <= jsrsContextMaxPool ){
    // create new context
    var contextID = "jsrs" + (jsrsContextPoolSize + 1);
    jsrsContextPool[ contextID ] = new jsrsContextObj( contextID );
    jsrsContextPoolSize++;
    return contextID;
  } else {
    alert( "jsrs Error:  context pool full" );
    return null;
function jsrsExecute( rspage, callback, func, parms, visibility ){
  // call a server routine from client code
  // rspage      - href to asp file
  // callback    - function to call on return
  //               or null if no return needed
  //               (passes returned string to callback)
  // func        - sub or function name  to call
  // parm        - string parameter to function
  //               or array of string parameters if more than one
  // visibility  - optional boolean to make container visible for debugging
  // get context
  var contextObj = jsrsContextPool[ jsrsGetContextID() ];
  contextObj.callback = callback;
  var vis = (visibility == null)? false : visibility;
  contextObj.setVisibility( vis );
  if ( jsrsPOST && ((jsrsBrowser == 'IE') || (jsrsBrowser == 'MOZ'))){
    contextObj.POST( rspage, func, parms );
  } else {
    contextObj.GET( rspage, func, parms );
function jsrsLoaded( contextID ){
  // get context object and invoke callback
  var contextObj = jsrsContextPool[ contextID ];
  if( contextObj.callback != null){
    contextObj.callback( jsrsUnescape( contextObj.getPayload() ), contextID );
  // clean up and return context to pool
  contextObj.callback = null;
  contextObj.busy = false;
function jsrsError( contextID, str ){
  alert( unescape(str) );
  jsrsContextPool[ contextID ].busy = false
function jsrsEscapeQQ( thing ){
  return thing.replace(/'"'/g, '\\"');
function jsrsUnescape( str ){
  // payload has slashes escaped with whacks
  return str.replace( /\\\//g, "/" );
function jsrsBrowserSniff(){
  if (document.layers) return "NS";
  if (document.all) return "IE";
  if (document.getElementById) return "MOZ";
  return "OTHER";
// user functions
function jsrsArrayFromString( s, delim ){
  // rebuild an array returned from server as string
  // optional delimiter defaults to ~
  var d = (delim == null)? '~' : delim;
  return s.split(d);
function jsrsDebugInfo(){
  // use for debugging by attaching to f1 (works with IE)
  // with onHelp = "return jsrsDebugInfo();" in the body tag
  var doc = window.open().document;
  doc.open;
  doc.write( 'Pool Size: ' + jsrsContextPoolSize + '<br><font face="arial" size="2"><b>' );
  for( var i in jsrsContextPool ){
    var contextObj = jsrsContextPool[i];
    doc.write( '<hr>' + contextObj.id + ' : ' + (contextObj.busy ? 'busy' : 'available') + '<br>');
    doc.write( contextObj.container.document.location.pathname + '<br>');
    doc.write( contextObj.container.document.location.search + '<br>');
    doc.write( '<table border="1"><tr><td>' + contextObj.container.document.body.innerHTML + '</td></tr></table>' );
  doc.write('</table>');
  doc.close();
  return false;
tydalMedlem sedan juni 20033 788 inlägg
Istället för att som i normalfallet klicka på en länk och låta webbläsaren gå till den adressen så är man kvar på samma adress, men javaskriptet byter sida i en iframe.
PersianBulldogMedlem sedan aug. 20022 380 inlägg
Tydal, behöver man verkligen ett javaskript för att åstadkomma det? Kan man inte bara välja target med vanlig HTML?
okej, jag har ett ASP dokument som hämtar 5 senaste posterna ur databasen, om jag använder den där koden för att presentera dom 5 senaste, och den uppdaterar självmant, utan att reloada hela framen? dvs att den sköter uppdateringen lite snyggt själv.
Om jag förstått det rätt?
man skulle juhe självklart kunna få det gjort genom att reloada hela sidan, men det ser lite fult ut om sidan är belastad att frejmen blir vit undertiden datan hämtas, jag vill att det på nått sätt ska vara dynamiskt att den hämtar information från ett ASP dokument och skriver ut det på sidan, utan att frejmen uppdateras och blir blank i nån sekund.
Genererad på 373 ms · cache AV · v20260730165559-full.f96bc7eb
