Jag kan typ ingenting om javscript. Men jag vill ändå ha en "preloader" på min sida. Så jag laddade hem ett script. Men jag skulle ville ändra lite på det. Någon som kanske kan hjälpa mig?
1. När den laddat klart vill jag att en "släpp in mig" länk ska komma upp, istället för att skickas vidare automatiskt.
2. Det står "// Color the preloadbar is starting and ending with - enter 1st, 3rd and 5th numbers/letters of color code"
Vad menas med det egentligen? Jag försökte få den helt röd men lyckades inte.
Så här ser koden ut:
<script language="JavaScript1.2">
<!-- begin hiding
// (C) 2000 Marcin P Wojtowicz [one_spook@hotmail.com]. All rights reserved.
// Obtain permission before selling/redistributing in any medium.
startingColor = new Array() // <-- Do not modify!
endingColor = new Array() // <-- Do not modify!
// YOU MAY MODIFY THE FOLLOWING:
var yourImages = new Array("images/bg_pattern.gif","images/diagonal_bg.gif","images/head.jpg")
var locationAfterPreload = "http://www.hemsida.nu"
var preloadbarWidth = 300
var preloadbarHeight = 20
var backgroundOfGradient = "#ffffff"
// Color the preloadbar is starting with - enter 1st, 3rd and 5th numbers/letters of color code
startingColor[0] = "r"
startingColor[1] = "r"
startingColor[2] = "r"
// Color the preloadbar is going to end up with - enter the 1st, 3rd and 5th numbers/letters of color code
endingColor[0] = "r"
endingColor[1] = "r"
endingColor[2] = "r"
var gap = 5
// DO NOT MODIFY ANYTHING BEYOND THIS POINT!!!
if (!document.all) location.replace(locationAfterPreload)
var a = 10, b = 11, c = 12, d = 13, e = 14, f=15, i, j, ones = new Array(), sixteens = new Array(), diff = new Array();
var convert = new Array("0","1","2","3","4","5","6","7","8","9","a","b","c","d","e","f"), imgLen = yourImages.length;
var loaded = new Array(), preImages = new Array(), currCount = 0, pending = 0, h = 0, hilite = new Array(), cover = new Array();
var num = Math.floor(preloadbarWidth/gap);
for (i = 0; i < 3; i++) {
startingColor[i] = startingColor[i].toLowerCase();
endingColor[i] = endingColor[i].toLowerCase();
startingColor[i] = eval(startingColor[i]);
endingColor[i] = eval(endingColor[i]);
diff[i] = (endingColor[i]-startingColor[i])/num;
ones[i] = Math.floor(diff[i]);
sixteens[i] = Math.round((diff[i] - ones[i])*15);
endingColor[0] = 0;
endingColor[1] = 0;
endingColor[2] = 0;
i = 0, j = 0;
while (i <= num) {
hilite[i] = "#";
while (j < 3) {
hilite[i] += convert[startingColor[j]];
hilite[i] += convert[endingColor[j]];
startingColor[j] += ones[j];
endingColor[j] += sixteens[j];
if (endingColor[j] > 15) {
endingColor[j] -= 15;
startingColor[j]++;
j++;
j = 0;
i++;
function loadImages() {
for (i = 0; i < imgLen; i++) {
preImages[i] = new Image();
preImages[i].src = yourImages[i];
loaded[i] = 0;
cover[i] = Math.floor(num/imgLen)*(i+1)
cover[cover.length-1] += num%imgLen
checkLoad();
function checkLoad() {
if (pending) { changeto(); return }
if (currCount == imgLen) { location.replace(locationAfterPreload); return }
if (!loaded[i] && preImages[i].complete) {
loaded[i] = 1; pending++; currCount++;
checkLoad();
return;
setTimeout("checkLoad()",10);
function changeto() {
if (h+1 > cover[currCount-1]) {
var percent = Math.round(100/imgLen)*currCount;
if (percent > 100) while (percent != 100) percent--;
if (currCount == imgLen && percent < 100) percent = 100;
defaultStatus = " [" + percent + "%]";
pending--;
checkLoad();
return;
eval("document.all.cell" + (h+1) + ".style.backgroundColor = hilite[h]");;
h++;
setTimeout("changeto()",1);
defaultStatus = "[0%]."
// end hiding -->
<!-- beging hiding
document.write('<table border="0" cellpadding="0" cellspacing="0" width="' + preloadbarWidth + '"><tr height="' + preloadbarHeight + '" bgcolor="' + backgroundOfGradient + '">');
for (i = 0; i < num; i++) {
document.write('<td width="' + gap + '" id="cell' + (i+1) + '"></td>');
document.write('</tr></table>');
document.write('<p><small><a href="javascript:location.replace(locationAfterPreload)">Jag orkar inte vänta!</a> <a href="http://www.hemsida.nu"></a></small></p></font>')
loadImages();
// end hiding -->
