Visa gärna det som kommer till webbläsaren (view source) istället så slipper vi felsöka ASP-koden :)
Någon som förstår varför fadefunktionen på texten försvinner när jag lägger en a href på hela texten i:
fcontent[<%=number%>]="<b><%=result3("pageheadline")%></b><br><%=result3("pageintrob")%> <a target='_top' href='frameset.asp?newsf=true&pageid=<%=result3("pageid")%>&topnumber=3&marketid=<%=request.querystring("marketid")%>&news=true'><% 'Response.Write(result5("value"))%> >></a>"
Sidan i sin helhet: (har klippt bort en del asp)
<html>
function TrackCount(fieldObj,countFieldName,maxChars)
var countField = eval("fieldObj.form."+countFieldName);
var diff = maxChars - fieldObj.value.length;
// Need to check & enforce limit here also in case user pastes data
if (diff < 0)
fieldObj.value = fieldObj.value.substring(0,maxChars);
countField.value = diff;
function LimitText(fieldObj,maxChars)
var result = true;
if (fieldObj.value.length >= maxChars)
result = false;
if (window.event)
window.event.returnValue = result;
return result;
function popup(target)
window.open(target,"popup","scrollbars=0,resizable=0,width=420,height=465");
window.onerror = null;
function popup_se(target, width, height)
window.open(target,"popup_se","scrollbars=1,resizable=0,width="+width+",height="+height);
function popup2()
window.open("popup.htm","popup2","scrollbars=0,resizable=0,width=406,height=554");
function MM_reloadPage(init) { //reloads the window if Nav4 resized
if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) {
document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }}
else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload();
MM_reloadPage(true);
<script language="text/JavaScript">
window.onerror=return true
<style type="text/css">
a.frontpage:link {color: #505050;
text-decoration:none;
a.frontpage:visited {
color: #505050;
text-decoration:none;}
a.frontpage:hover {
color: #505050;
</style>
<link rel="stylesheet" type="text/css" href="../likostyle/main.css">
<body bgcolor="#FFFFFF" text="FFFFFF" marginheight="0" marginwidth="0" leftmargin="0" topmargin="0">
<div id=menu style="position:absolute; left:20px; top:0px; z-index:10" width:764; height:77;">
<img src="<%=result4("value")%>" width="764" height="77" border="0" usemap="#Map">
<map name="Map">
<% If request.QueryString("marketid")="86" then %>
<area shape="rect" coords="468,4,587,73" href="javascript:popup_se('kontakt_se.htm', 560, 580);">
<% ELSE %>
<area shape="rect" coords="468,4,587,73" href="javascript:popup('kontakta_mig.asp?marketid=<%=request.QueryString("marketid")%>');">
<% End If %>
<area shape="rect" coords="13,5,135,73" href="../index.asp" target="_top">
</map>
<br>
</a>
<div id="sok" style="position:absolute; left:630px; top:14px; width:149px; height:45px; z-index:11">
<table cellpadding="0" cellspacing="0" border="0"><tr><td height="14"><b>
<font face="Verdana, Arial, Helvetica, sans-serif" size="1" color="#FFFFFF">
</font><BR></b>
</td></tr><tr><td valign="top">
<tr><td valign="top" width="95">
<form action="frameset.asp?previous=search.asp&topnumber=3&marketid=<%=request.querystring("marketid")%>&top=true" target="_top" method="post">
<input type="text" name="search" size="11">
</td>
<td valign="middle" align="left">
<% set result4 = ExecuteSQL(this,"SELECT * FROM marketobjects WHERE name='okknapp2' and marketid=" & request.QueryString("marketid")) %>
<input type="image" src="<%=result4("value")%>" width="25" height="16"><BR>
</td>
</tr>
</table>
<% SELECT CASE request.QueryString("marketid")
CASE "86"%>
<a href="../sverige/sitemap.asp" target="_top"><img src="images/pil_sitemap.gif" border="0"></a>
<%END SELECT%>
</td>
</tr></table>
<div id=kontakta style="position:absolute; left:14px; top:77px; z-index:10 width:764; height:37; background-color:#FFFFFF; layer-background-color:#FFFFFF;z-index:13">
<table width="764" border="0" cellspacing="3" cellpadding="0">
set result = ExecuteSQL(this,"SELECT * FROM market WHERE marketid=" & Request.Querystring("MarketID"))
<tr>
<td width="473"><font face="Verdana, Arial, Helvetica, sans-serif" size="1"><font color="#999999">
<%=result("address")%> |
Tel: <%=result("phone")%>
<% If Request.QueryString("marketid")="93" then %>
Fax: <%=result("fax")%>
<% End If %>
</font></font></td>
<td width="282"><div align="right"><font face="Verdana, Arial, Helvetica, sans-serif" size="1"><font face="Verdana, Arial, Helvetica, sans-serif" size="1"><font face="Verdana, Arial, Helvetica, sans-serif" size="1" color="#999999">
set result4 = ExecuteSQL(this,"SELECT * FROM marketobjects WHERE name='anv' and marketid=" & request.QueryString("marketid"))
<a href="<%=result4("value")%>" target="_blank">
set result4 = ExecuteSQL(this,"SELECT * FROM marketobjects WHERE name='userterms' and marketid=" & request.QueryString("marketid"))
<%=result4("value")%></a>
| Copyright © 2003 Liko</font></font><b> <font color="#999999">
</font></b><font color="#999999"> </font></font></div></td>
</tr>
</table>
<script language="JavaScript1.2">
var delay=3000 //set delay between message change (in miliseconds)
var fcontent=new Array()
begintag='<font face="verdana" size=1 style="line-height:16px;"> ' //set opening tag, such as font declarations
closetag='</font>'
var fwidth=230 //set scroller width
var fheight=60 //set scroller height
///No need to edit below this line/////////////////
var ie4=document.all&&!document.getElementById
var ns4=document.layers
var DOM2=document.getElementById
var faderdelay=10
var index=10
if (DOM2)
faderdelay=4300
//function to change content
function changecontent(){
if (index>=fcontent.length)
index=0
if (DOM2){
document.getElementById("fscroller").style.color="rgb(0,0,0)"
document.getElementById("fscroller").innerHTML=begintag+fcontent[index]+closetag
colorfade()
else if (ie4)
document.all.fscroller.innerHTML=begintag+fcontent[index]+closetag
else if (ns4){
document.fscrollerns.document.fscrollerns_sub.document.write(begintag+fcontent[index]+closetag)
document.fscrollerns.document.fscrollerns_sub.document.close()
index++
setTimeout("changecontent()",delay+faderdelay)
frame=20;
hexa=181;
hexb=201;
hexc=159;
function colorfade() {
// 20 frames fading process
if(frame>4) {
hexa-=3; // increase color value
hexb-=3; // increase color value
hexc-=3; // increase color value
document.getElementById("fscroller").style.color="rgb("+hexa+","+hexb+","+hexc+")"; // Set color value.
frame--;
setTimeout("colorfade()",30);
else{
document.getElementById("fscroller").style.color="rgb(80,80,80)";
frame=30;
hexa=181;
hexb=201;
hexc=159;
if (ie4||DOM2)
document.write('<div id="fscroller" style="position:absolute; left:189px; top:8px; z-index:11;border:0px; width:'+fwidth+';height:'+fheight+';padding:2px"></div>')
window.onload=changecontent
<ilayer id="fscrollerns" width=&{fwidth}; height=&{fheight};><layer id="fscrollerns_sub" width=&{fwidth}; height=&{fheight}; left=0 top=0></layer></ilayer>
</body></html>
