Menyer kluris
3 svar · 253 visningar · startad av JonWal
JonWalMedlem sedan nov. 200313 inlägg
Hej !
Vill få de tre dropplisterna på ramens övre kant topmargin=0
hUr göra ?
<?xml version="1.0" encoding="iso-8859-1"?>
<!DOCTYPE html
PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="sv" lang="sv">
<title>Banner</title>
<link href="/xxx.css" rel="stylesheet" type="text/css" />
<script language=javascript>
	function DoljVerktygMain()
	parent.huvudet.cols = "\*,0";
	function VisaVerktyg()
	 parent.huvudet.cols = "\*,225";
\</script\>
\</head\>
\<body background="/images/layout/bla_rut_bg.gif"\>
\<table\>
\<tr\>
	\<td\>
	\<Form name="1"\>
			\<select name="combokoncern" onChange="parent.main.location=this.options\[this.selectedIndex\].value; VisaVerktyg();" class="form1"\>
			\<option value="XXXX"\>Välj koncernhandbok\</option\>
			\</select\>
		\</Form\>
	\</td\>
	\<td\>
			\<Form name="omrade"\>
			\<select name="comboomrade" onChange="parent.main.location=this.options\[this.selectedIndex\].value; DoljVerktygMain();" class="form1" \>
			\<option value="XXX"\>Välj område&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;\</option\>
	\</select\>
	\</Form\>
	\</td\>
	\<td\>
			\<Form name="process"\>
			\<select name="comboprocess" onChange="parent.main.location=this.options\[this.selectedIndex\].value; DoljVerktygMain();" class="form1" \>
			\<option value="http://xXX"\>Välj process\</option\>
	\</select\>
	\</form\>
	\</td\>
			\<td style="text-align: center; height: 0px; padding: 8px; width: 70%; font-size: 85%"\>
			\<form\>
			\<input type="button" value="Åter startsidan" onClick="top.parent.main_frame.location='http://xxxx'"\>
			\</form\>
			\</td\>
	\</tr\>
\</table\>
\</body\>
</html>
ChoronzonMedlem sedan aug. 20011 346 inlägg
cellpadding=0, cellspacing=0 i tabellen, och style="padding:0;" i formen borde ge någon form av resultat...
Tack !
Tog även bort padding=8px och det löst sig ! :birp
JonWal »
Eftersom det inte går att skicka PM eller e-post till dig så skriver jag det här:
Läs igenom (och följ) forumtips/riktlinjer.
