tabellen rasar till hoger! :(
18 svar · 344 visningar · startad av crisse6
crisse6Medlem sedan dec. 20002 526 inlägg
Fan, okej, min tabell blir helt knasig.. vill lagga upp det sa att den ligger at vanster, men att det ska presenteras allt sa har:
Forum: Tradar: Inlagg: Moderator: .... osv...
ASP/VBScript 10 25 crisse6, anders
Men vet inte, kan ni kolla pa html koden? :D
[red]
Do Until rs.eof
If rs("catName") <> ref then
	response.write "<table width=""100%"" bgcolor=""#EFEFEF""><tr><td>"
	response.write rs("catName")
	response.write "</td></tr></table>"
	response.write "<table width=""100%"" bgcolor=""#F4F4F4""><tr><td width=""2%""></td>"
	response.write "<td width=""10%"">Forum</td>"
	response.write "<td width=""15%"">Antal trådar</td>"
	response.write "<td width=""15%"">Antal inlägg</td>"
	response.write "<td width=""15%"">Senaste inlägg</td>"
	response.write "<td width=""15%"">Moderatorer</td></tr></table>"
	forumIDref = ""
End IF
If rs("forumID") <> forumIDref then
  	response.write "<table width=""100%"" align=""left""><tr>"
  	response.write "<td width=""30%""><a href=""forum.asp?id="&rs("forumID")&""">"&rs("forumName")&"</a><br>"&rs("forumDesc")&"</td>"&_
  	"<td width=""5%"">"&rs("forumTopics")&"</td>"&_
	"<td width=""5%"">"&rs("forumAns")&"</td>"&_
  	"<td width=""15%"">"& Datetime(rs("forumLatestReply"))&"</td>"&_
  	"<td>"&rs("userName")
Else
  response.write ", " & rs("userName")
forumIDref = rs("forumID")
ref = rs("catName")
rs.movenext
loop
Response.Write("</td></tr></table>")
[/red]
TACK! :e
Tips: Skriv ut koden och klistra in ifrån källkoden istället. Jobbigt att gissa sig till med all ASP-kod.
okej ;)
[red]
<html>
<title>Forum</title>
<body>
<img src="gfx/logo.gif"><br><br>
<table width="100%" bgcolor="#EFEFEF"><tr><td>Angående sidan</td></tr></table><table width="100%" bgcolor="#F4F4F4"><tr><td width="2%"></td><td width="10%">Forum</td><td width="15%">Antal trådar</td><td width="15%">Antal inlägg</td><td width="15%">Senaste inlägg</td><td width="15%">Moderatorer</td></tr></table><table width="100%" align="left"><tr><td width="30%"><a href="forum.asp?id=2">Tips för sidan</a><br>Allmäna tips för hur sidan kan utvecklas...</td><td width="5%">0</td><td width="5%">0</td><td width="15%">5 feb  2002 00:00</td><td>anders<table width="100%" bgcolor="#EFEFEF"><tr><td>Webbrelaterat</td></tr></table><table width="100%" bgcolor="#F4F4F4"><tr><td width="2%"></td><td width="10%">Forum</td><td width="15%">Antal trådar</td><td width="15%">Antal inlägg</td><td width="15%">Senaste inlägg</td><td width="15%">Moderatorer</td></tr></table><table width="100%" align="left"><tr><td width="30%"><a href="forum.asp?id=4">Access/MySQL</a><br>De två mest vanliga databaserna vid ASP programmering...</td><td width="5%">0</td><td width="5%">0</td><td width="15%">7 feb  2002 00:00</td><td>fredrik, crisse6<table width="100%" align="left"><tr><td width="30%"><a href="forum.asp?id=3">SQL</a><br>Behöver du snacka med databaser?</td><td width="5%">0</td><td width="5%">0</td><td width="15%">6 feb  2003 00:00</td><td>anders, crisse6<table width="100%" align="left"><tr><td width="30%"><a href="forum.asp?id=1">ASP/VbScript</a><br>Allt som har med ASP/Vb att göra och relaterade tekniker...</td><td width="5%">0</td><td width="5%">0</td><td width="15%">2 feb  2002 00:00</td><td>fredrik, crisse6</td></tr></table></body></html>
[/red]
celiaMedlem sedan dec. 20012 532 inlägg
Re: tabellen rasar till hoger! :(
ref = rs("catName")
rs.movenext
loop
TACK! :e
Flytta upp det till före else så den tabellen får sina sluttaggar :) r) om du bara skriver ut användarnamnet kommer inte början på tabellen med.
snygg tabell det blev :P hehe, nej, du... det dar blev inte mycket battre, lagger sig ratt snyggt tills du upptacker att allt lagger sig pa bredden och det blir helt konstigt... hehe.... tack iaf ;)
Nehe, prova att ändra bredd i cellerna då så att de blir 100% tillsammans.
men det gor ju ingen skillnad? just nu sitter ju inte ens tabellen ihop... den flyger ju ivag...
Flyger iväg? sätt border=1 i tabellerna och posta en skärmdump så man ser vad du menar :)
Okej ;)
har ar den ;)
http://member.webforum.nu/1252/forum.jpg
Snygg border! ;) Du får inte med sluttaggarna (fetmarkerat):
<html>
<body>
  <tr>
  </tr>
</table>
  <tr>
  </tr>
</table>
  <tr>
    <td>anders
[b]</td></tr></table>[/b]
  <tr>
  </tr>
</table>
  <tr>
  </tr>
</table>
  <tr>
  <tr>
    <td>anders, crisse6
  <tr>
  </tr>
</table>
</body></html>
Hmm...... blir ju nastan samma :( Klistrade och korde som vanligt html dokument, den ligger lite battre nu, men det rasar at hoger fortfarande :(
hmm..... sa har ar det nu med koden (asp iofs).. den ligger ratt nu, men nar nasta kategori visas sa ligger den kvar pa samma rad som forumet i foregaende kategori (markerat med fet).... hehe.... :( Sa det blir sa har....
Skitsnack kategori
Cafe
Roliga historier... blaa bla... Webbrelaterat
PHP osv...
[red]
x = 0
Do Until rs.eof
	response.write "<td width=""15%"">Moderatorer</td></tr></table><br>"
	forumIDref = ""
	If x > 0 Then Response.Write("</td></tr></table><br>")
	x = x + 1
  	response.write "<table width=""100%""><tr>" &_
  	"<td>"& rs("userName")
Else
ref = rs("catName")
rs.movenext
Loop
[/red]
kallkoden:
<table width="100%" bgcolor="#EFEFEF"><tr><td>Angående sidan</td></tr></table><table width="100%" bgcolor="#F4F4F4"><tr><td width="2%"></td><td width="10%">Forum</td><td width="15%">Antal trådar</td><td width="15%">Antal inlägg</td><td width="15%">Senaste inlägg</td><td width="15%">Moderatorer</td></tr></table><br><table width="100%"><tr><td width="30%"><a href="forum.asp?id=2">Tips för sidan</a><br>Allmäna tips för hur sidan kan utvecklas...</td><td width="5%">0</td><td width="5%">0</td><td width="15%">5 feb  2002 00:00</td><td>anders<table width="100%" bgcolor="#EFEFEF"><tr><td>Webbrelaterat</td></tr></table><table width="100%" bgcolor="#F4F4F4"><tr><td width="2%"></td><td width="10%">Forum</td><td width="15%">Antal trådar</td><td width="15%">Antal inlägg</td><td width="15%">Senaste inlägg</td><td width="15%">Moderatorer</td></tr></table><br></td></tr></table><br><table width="100%"><tr><td width="30%"><a href="forum.asp?id=4">Access/MySQL</a><br>De två mest vanliga databaserna vid ASP programmering...</td><td width="5%">0</td><td width="5%">0</td><td width="15%">7 feb  2002 00:00</td><td>fredrik, crisse6</td></tr></table><br><table width="100%"><tr><td width="30%"><a href="forum.asp?id=3">SQL</a><br>Behöver du snacka med databaser?</td><td width="5%">0</td><td width="5%">0</td><td width="15%">6 feb  2003 00:00</td><td>anders, crisse6</td></tr></table><br><table width="100%"><tr><td width="30%"><a href="forum.asp?id=1">ASP/VbScript</a><br>Allt som har med ASP/Vb att göra och relaterade tekniker...</td><td width="5%">0</td><td width="5%">0</td><td width="15%">2 feb  2002 00:00</td><td>fredrik, crisse6</td></tr></table></body></html>
ankathMedlem sedan jan. 2003270 inlägg
Du kanske ska försöka avsluta den första tabellen. Annars skapas den andra tabellen inne i den första. Av vad jag har förstått efter att ha kastat en snabb blick på din asp-kod så är det här som detta uppstår:
	x = x + 1
  	[B]"<td>"& rs("userName")[/B]
Else
Det var det konstigaste! Kollade på koden i mozilla/ie6 och det blir precis som du säger. Det kan ha att göra med att bredden på cellerna inte är angiven överallt och att när den är det så är summan av en rad mindre än 100%. Fixa det och se till att avsluta rätt tabell på rätt ställe så borde det ordna sig :)
grejen ar ju att den funkar ju med <div> taggar, men vet inte? Ska man kanske anvanda det da? Och hur for att fa allt snyggt upplagt? Alltsa sa det star:
Forum: Antal tradar Antal inlagg.... osv...
ASP/VBScript 10 12
Hanger ni pa?
Halla?
snalla, ingen som vet? sitter har och kommer ingen vart, vet att ni finns dar era tabell-gurus :D
Vi har ju svarat på det flera gånger :OO Fungerar det med div, använd det. Fungerar det bättre med tabeller, använd det. Själv hade jag använt tabeller.
jo, men vart blir det fel liksom? hehe....
147 ms totalt · 3 externa anrop · v20260731065814-full.3ab8d573
144 ms — hämta tråd, inlägg och bilagor (db)
