men sidan går inte genom validiatorn.
"I was not able to extract a character encoding labeling from any of the valid sources for such information. Without encoding information it is impossible to validate the document."
Hmm... hur har de tänkt sig att man ska använda länkar med variabler?
Line 10, column 41: cannot generate system identifier for general entity "strCategoryName"
...ref="productList.asp?intCategoryID=2&strCategoryName=Bärbara datorer">Bärba
Line 10, column 41: general entity "strCategoryName" not defined and no default entity (explain...).
Line 10, column 56: reference not terminated by REFC delimiter
...t.asp?intCategoryID=2&strCategoryName=Bärbara datorer">Bärbara datorer</a>
Line 10, column 56: reference to external entity in attribute value
Line 10, column 56: reference to entity "strCategoryName" for which no system identifier could be generated
Line 10, column 40: entity was defined here
<a href="productList.asp?intCategoryID=2&strCategoryName=Bärbara datorer">Bärb
Tänk på att du inte får ha mellanslag i en url. Ersätt dem med "%20".
286 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
