OliverMedlem sedan okt. 200023 inlägg
Hi!
My newly built site is nearly ready and I have noticed something strange-or so I feel. The size of the site does not increase if the resolution is increasd, in other words the site does not grow with the screen as most sites do.
I asked the web bureau and they said this is because the functionality would not work otherwise!
Is this so?????
/Peter
Peter B
Erik JuhlinMedlem sedan maj 20007 625 inlägg
I think the only way to make the site "grow" with the web browser is to use Flash. Otherwise, it's hard to do that.
The important thing is that the site fits in the resolution 800x600 since many use that, but it is good if it also works in 640x480.
/Erik
MattiMedlem sedan dec. 19993 781 inlägg
You can achieve that effect with relative table sizes. Instead of using pixels you write "30%". The table should then always take up 30% of the screen size - but - usually it just looks fu**** up. ;)
matti.intelligens.nu
