crisse6Medlem sedan dec. 20002 526 inlägg Hej!
Vet ej vilket forum jag ska posta i, det ar HTML, Javascript och ASP inblandad sa.... hehe..... Iaf, vill placera en javascript meny under mina kara logga, men den hamnar pa toppen utanfor tabellen dar alla annan information ar.... varfor? sa har ser det ut nu:
<body bgcolor="white" text="black" link="blue" vlink="purple" alink="red">
<table align="center" cellpadding="0" cellspacing="0" width="800">
<tr>
<td width="800" height="93" background="pictures/top2.jpg" style="border-top-width:1; border-right-width:1; border-bottom-width:0; border-left-width:1; border-top-color:black; border-right-color:black; border-left-color:black; border-top-style:solid; border-right-style:solid; border-bottom-style:none; border-left-style:solid;">
<!--#include file="menu.asp" -->
</td>
</tr>
<tr>
<td style="border-top-width:0; border-right-width:1; border-bottom-width:1; border-left-width:1; border-right-color:black; border-bottom-color:black; border-left-color:black; border-top-style:none; border-right-style:solid; border-bottom-style:solid; border-left-style:solid;">
<p><font face="Verdana" size="2"><b><br></b></font></p>
strMenuID = request.querystring("menuID")
Select Case strMenuID
Case "8", "" %>
<!--#include file="inc_home.asp" -->
<% Case "1" '<- Include inc_ShowUsrInformation.asp%>
<!--#include file="test.asp" -->
<% Case "2" %>
<!--#include file="inc_PrivateGB.asp" -->
<% Case "4" '<- Include inc_PublicGB.asp%>
<!--#include file="inc_PublicGB.asp" -->
<% Case "5" %>
<!--#include file="inc_Buddies.asp" -->
<% Case "20" %>
<!--#include file="makeFriendStep2.asp" -->
<% Case "6" '<- Include inc_Mail.asp%>
<% Case "7" %>
<!--#include file="inc_SearchMembers.asp" -->
<% Case "9" '<- Include DestroySessions.asp %>
<% End Select %>
</td>
</tr>
</table>
Jesper TMedlem sedan nov. 20017 144 inlägg Det är för att du har position:absolute i dina divar för menyn. Du måste ändra till relatitive eller sätta tex top:100px så får kanske loggan plats ovanför. Relative har en nackdel eftersom att det kruxar sig i N.S.
crisse6Medlem sedan dec. 20002 526 inlägg hur menar du? hur ska det se ut? far ej ordning pa det!!!
crisse6Medlem sedan dec. 20002 526 inlägg jag sa ju det, far ej ordning pa det!! kan du visa hur tror du?
Jesper TMedlem sedan nov. 20017 144 inlägg Du får ändra i stylesheetet i filen meny.asp. Efter som att du inte bifogat någon kod ifrån meny.asp så blir det svårt att hjälpa dig.
P.s En annan rekomendation är att använda server.execute i stället för include-filer.
crisse6Medlem sedan dec. 20002 526 inlägg har ar stylesheetet:
<STYLE TYPE="text/css">
/* Don't remove this line: Script by Omid Rouhani from JavaScript.nu */
För varje meny ska du ha en "menyX-rad" och en "undermenyX-rad" i detta format:
#meny1 {position:absolute; visibility:hidden;}
#undermeny1 {position:absolute; visibility:hidden;}
Exempel:
* Ska du ha tre menyer, ändra inget nedan.
* Ska du bara ha två menyer, ta bort raderna nedan som börjar på #meny3 och #undermeny3.
* Ska du ha fyra menyer lägger du till två rader som börjar med #meny4 och #undermeny4.
* etc.
#meny2 {position:absolute; visibility:hidden;}
#undermeny2 {position:absolute; visibility:hidden;}
#meny3 {position:absolute; visibility:hidden;}
#undermeny3 {position:absolute; visibility:hidden;}
#meny4 {position:absolute; visibility:hidden;}
#undermeny4 {position:absolute; visibility:hidden;}
#meny5 {position:absolute; visibility:hidden;}
#undermeny5 {position:absolute; visibility:hidden;}
#meny6 {position:absolute; visibility:hidden;}
#undermeny6 {position:absolute; visibility:hidden;}
/* Nedan väljer du hur rubrikerna och länkarna ska se ut (t.ex. textfärg): */
/* Menyer vanligt: */ .menyRubrikClass {font-family:verdana; text-decoration:none; color:#E9EAD4; font-weight:normal; font-size:10; cursor:default}
/* Menyer då musen är på dem: */ .menyRubrikClass:hover {font-family:verdana; text-decoration:none; color:#E9EAD4; font-weight:normal; font-size:10; cursor:default}
/* Menyer då man besökt dem: */ .menyRubrikClass:visited {font-family:verdana; text-decoration:none; color:#E9EAD4; font-weight:normal; font-size:10; cursor:default}
/* Menyer då man trycker på dem: */ .menyRubrikClass:active {font-family:verdana; text-decoration:none; color:#E9EAD4; font-weight:normal; font-size:10; cursor:default}
/* Länkar vanligt: */ .menyLankClass {font-family:verdana; text-decoration:none; font-size:10; color:#E9EAD4;}
/* Länkar då musen är på dem: */ .menyLankClass:hover {font-family:verdana; text-decoration:none; font-size:10; color:#E9EAD4;}
/* Länkar då man besökt dem: */ .menyLankClass:visited {font-family:verdana; text-decoration:none; font-size:10; color:#E9EAD4;}
/* Länkar då man trycker på dem: */ .menyLankClass:active {font-family:verdana; text-decoration:none; font-size:10; color:#E9EAD4;}
</STYLE>
sen angaende server.execute..... kunde inte kora det forut da jag hade PWS..... men nu har jag IIS sa da ska det ju funka!
Jesper TMedlem sedan nov. 20017 144 inlägg Inte i stylesheetet utan i javascriptet så har du i början några rader där det står:
//***---Lagrets placering räknat från översta vänstra hörnet:
pixelNer=0;
Ändra nollan till tex bildens (loggans) höjd.
då kommer menyn att lägga sig rätt. Lätt va?
crisse6Medlem sedan dec. 20002 526 inlägg Okey.. later bra!
Vill papeka att du faktiskt sa stylesheetet och inte javascript :P
