Hjälp med en meny
HTML & CSS
2 svar · 1 043 visningar · startad av Asa
Medlem sedan dec. 20011 860 inlägg
Har en meny som funkar jättebra men vill att när man klickat på något i undermenyn so skall huvudmenyn till denna vara öppen så man ser den länk man klickat på.. alltså de andra menyvalen i just den undermenyn. Denna menyn är denna: http://www.cssplay.co.uk/menus/dl-clickslide.html
<style>
#positioner {position:relative; width:150px; height:160px; z-index:100;}
#holder {position:absolute; width:150px; overflow:hidden; background:#f0f0f0;}
dl.menu {width:300px; float:left; margin:-32700px -150px 0 0; background:url(clickslide/tab1.gif) no-repeat left bottom; margin-bottom:2px;}
dl.menu a {display:block; height:30px; color:#000; font:bold 11px/28px verdana, sans-serif; text-decoration:none;}
dl.menu dt {float:left; padding:0; margin:32700px 0 0 0; position:relative; z-index:50;}
dl.menu dt a.lefta {width:120px; float:left; padding-left:10px;}
dl.menu dt a.plusa {width:20px; float:left; background:url(clickslide/down.gif) no-repeat center center;}
dl.menu dt a.plusa b {position:absolute; left:-9999px;}
dl.menu dt a.lefta:hover,
dl.menu dt a.lefta:focus,
dl.menu dt a.lefta:active {color:#c00;}
dl.menu dt a.plusa:hover {background:url(clickslide/down2.gif) no-repeat center center;}
dl.menu dt a.plusa:focus,
dl.menu dt a.plusa:active
{margin-right:1px; background:url(clickslide/down2.gif) no-repeat center center; outline:0; position:relative; left:-9999px;}
dl.menu dd {float:left; padding:30px 0 0 0; margin:-30px 0 0 0; position:relative; z-index:10; background:url(clickslide/tab3.gif) no-repeat left top;}
dl.menu dd a {background:#fff; width:140px; padding:5px 0 5px 10px; border-bottom:1px solid #ccc; font-weight:normal; line-height:17px; height:auto;}
dl.menu dd a:hover,
dl.menu dd a:focus,
dl.menu dd a:active
{margin-right:1px; color:#c00; outline:0;}
</style>
<div id="positioner">
	<div id="holder">
		<dl class="menu">
			<dt>
				<a class="lefta" href="meny.html">Startsidan</a>
			</dt>
		</dl>
		<dl class="menu">
			<dt>
				<a class="lefta" href="javascript:void();">Om Företaget</a>
				<a class="plusa" href="javascript:void();"><b>+</b></a>
			</dt>
			<dd>
				<a href="meny.html">Historik</a>
				<a href="meny.html">Huvudinriktining</a>
				<a href="meny.html">Kontoret</a>
			</dd>
		</dl>
		<dl class="menu">
			<dt>
				<a class="lefta" href="javascript:void();">Nästa</a>
			</dt>
			<dd>
				<a href="meny.html">Ett</a>
				<a href="meny.html">Tvä</a>
				<a href="meny.html">Tre</a>
			</dd>
		</dl>
	<div style="clear: both;"> </div>
Ingen som kan hjälpa mig?
Medlem sedan mars 20021 152 inlägg
Iaf jag, kunde inte vara helt säker på vad du önskade, eftersom när länken klickats öppnas väl den länkade sidan. Jag stannade aldrig upp och funderade över vad jag missat i din fråga. :)
Vill du att den aktuella sidan ska visa undermenyn med den sidans länk så att man ser var man är i menyn? Då ska väl den aktuella sidans länk vara markerad också (kanske även inaktiverad)
Det är enkelt att lägga till. Men tänk på att den aktuella sidans öppna undermeny kommer inte att stängas när man aktiverar en annan undermeny (om man inte kodar om hela menyn). Så eventuellt sidinnehåll som täcks av att menyn är öppen kommer att fortsätta vara överlappat.
:OO
252 ms totalt · 4 externa anrop · v20260731065814-full.e96017d9
124 ms — deklarationer (db)
124 ms — ändringar (db)
