kommentarsrutan öppnas vid fel tid
HTML & CSS
2 svar · 287 visningar · startad av WebbisNet
Medlem sedan feb. 20032 027 inlägg
När man går in på bloggen, sin egna eller andras så öppnas kommentarsrutan direkt, den ska bara öppnas när man klickar på länken
jag hittar inte felet
did=Request.QueryString("ID")
Set mainRS=objConn.Execute("Select * From tblUsers")
uid=request.querystring("uid")
Set diary=objConn.Execute("SELECT userID, username, picture, id, rubrik, agare, inlagg, insantDate, insantTime, clicks, tblUsers.vip "&_
"FROM tblUsers_Diary INNER JOIN tblUsers ON tblUsers_Diary.agare = tblUsers.userID where id = " & did & " order by id desc")
Set diary_Reply=objConn.Execute("SELECT userID, username, picture, id, agare, skickatAv, inlagg, insantDate, insantTime, tblUsers.vip "&_
"FROM tblUsers_Diary_Reply INNER JOIN tblUsers ON tblUsers_Diary_Reply.skickatAv = tblUsers.userID where id = " & did & " order by id desc")
set RS = objConn.Execute("SELECT * FROM tblUsers u INNER JOIN tblUsers_block b ON u.userID = b.vemArBlockad where vemArBlockad="& uid &" and vemBlockar = "& diary ("userID"))
Tstamp=Now()
objConn.Execute("UPDATE tblUsers SET TStamp = '"& Tstamp &"' WHERE userID = " & UserID &"")
if not request.querystring("userID") = Session("userID") then
SET objConn = connect()
varVisitor=UserID
varVisited=diary("userID")
varDID=request.querystring("ID")
varDate=Date()
varTime=Time()
	diary1 = "INSERT INTO tblUsers_DiaryVisitors"
	diary1 = diary1 & "(DID,visitor,visited,diaryDate,diaryTime) "
	diary1 = diary1 & "VALUES("& varDID &","& varVisitor &","& varVisited &",'"& varDate &"','"& varTime &"')"
	'response.write diary1
	'response.end
	objConn.Execute diary1
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN">
<html>
  <title>Läs bloggen</title>
   	<link type="text/css" rel="StyleSheet" href="/include/css/style.css">
		<script language="JavaScript" src="/include/scripts.js"></script>
<body class="bg">
<TABLE width="800" style="margin-left:0px; margin-top:0px;" border="0" cellpadding="0" cellspacing="0">
<TR valign=top>
<!-- Loggan börjar -->
<TD valign="top" align="left" style="<%=mainBGColor%>" colspan="6">
<table height="60" border="0" cellspacing="0" cellpadding="0">
  <tr>
    <td valign="top" align="center" height="30" width="308" class="rubrik" style="<%=mainBGColor%>">
<%=logotext%>
	</td>
    <td style="<%=mainBGColor%>" valign="top" width="16" rowspan="2">&nbsp;</td>
    <td style="<%=mainBGColor%>" valign="top" width="468" rowspan="2">
<%set vipCheck=objConn.Execute("SELECT * from tblUsers WHERE userID="& UserID)
IF vipCheck("vip") = "0" THEN
Response.Write Reklam
ELSE
Response.Write Extra
END IF%>
	</td>
  </tr>
  <tr>
    <td valign="top" align="center" style="<%=mainBGColor%>">
	<iframe style="<%=mainBGColor%>" height="30" width="300" src="/mail/newMail.asp" frameborder="0" scrolling="no"></iframe>
	</td>
  </tr>
</table>
<!--#include virtual="/menu.asp"-->
</TD>
<!-- Loggan slutar -->
</TR>
<TR>
[B][I]
<!-- Bloggen startar -->
<TD style="<%=mainBGColor%>" width="100%" height="100%" valign="top">
<p class="outset"> :: Läs blogg :: </p>
<table width="800">
	<tr>
<td>
<%If diary.eof then
Response.write "Bloggen är tom"
With Response
do until diary.eof%>
<%If not RS.EOF then
Response.Write "<span class=""brodtext"">Du har inte rättighet att skriva kommentar då du är blockad av en användare</span>"
else%>
<a class="rubrik_s" href="javascript:openAd()">Skriv kommentar till inlägg '<%=diary("rubrik")%>'</a>.
<hr>
function closeAd() {
document.getElementById("popad").style.display="none";
function openAd() {
document.getElementById("popad").style.display="block";
<div id="popad" style="<%=mainBGColor%> display:none;padding:5px;position: absolute; left: 50%; top: 40%;
margin-left:-180px; z-index: 101; height: 200px; width: 300px; no-repeat; border:1px black dotted ">
<div style="<%=mainBGColor%>;padding-bottom:13px;">
<a href="javascript:closeAd()" class="brodtext" style="float:right;">Stäng(x)</a><br/>
<span class="brodtext">Svara på inlägget till rubrik '<%=diary("rubrik")%>'</span>
<br />
<%if request.querystring("err") = 1 then%>
<span style="color:#FF0000;" class="brodtext"><b>Du kan inte posta en tom kommentar</b></span>
<%End If%>
<form action="diary_reply_Save.asp" method="post">
<input type="hidden" name="txtInlaggID" value="<%=request.querystring("ID")%>">
<input type="hidden" name="txtSkickatAv" value="<%=Session("userID")%>">
<input type="hidden" name="txtAgare" value="<%=Request.Querystring("agare")%>">
<textarea class="brodtext" name="txtSvara" style="width:290px; height: 100px;"></textarea>
<br>
<input class="button" type="submit" value="Skicka svar">
<%End If%>
</td>
</tr>
<tr>
	<td width="800" align="left" valign="top" class="presentation" style="background-color:#FFFFFF; border-weight:solid; border-width:1px; border-color:#000000;">
.Write "Skriven av <a class=""menu"" href=""/view.asp?userID= "& diary("userID") &" "">"& diary("username") &"</a> &nbsp;"
.Write " "& diary("insantDate") &" &nbsp;"& diary("insantTime") &" "
.Write "&nbsp;|&nbsp;"
.Write "<a class=""menu"" href=""/diary/?userID="& diary("userID") &"&name="& diary("username")&"&ID="& diary("id")&" "">Till bloggen ==></a><hr>"
.Write "<b>"& diary("rubrik") &"</b><br /><br />"
.Write ""& replace(diary("inlagg"),vbCrLf,"<br>")&""
diary.movenext: loop
End With
End If%>
<hr>
If diary_reply.eof then
Response.Write "<br>"
Response.write "<b>Inlägget har inga kommentarer</b>"
With Response
do until diary_reply.eof
.Write "<br>"
.Write "<b>Skriven av <a class=""menu"" href=""/view.asp?userID= "& diary_Reply("skickatAv") &" "">"& diary_reply("username") &"</a> &nbsp;</b>"
.Write "<b> "& diary_reply("insantDate") &" &nbsp;"& diary_reply("insantTime") &" <b>"
.Write "<br>"
.Write "<b>"& replace(diary_reply("inlagg"),vbCrLf,"")&" </b><br>"
diary_reply.movenext: loop
End With
End If%>
</td>
</tr>
</table>
</TD>
<!-- Bloggen slutar -->
[/I][/B]
</TR>
</TABLE>
</html>
Medlem sedan sep. 2003448 inlägg
javascript:openAd()
ska väll vara
javascript:openAd();
Detta har inget med ASP att göra (flyttat tråden till html, css)
vad innehåller variablen mainBGColor? du bryer CSS helt fel om du bara ha en färg: #fff, eller background: #fff
Då bli resultatet:
<div id="popad" style="[red]background:#fff [/red]display:none;padding:5px;position: absolute; left: 50%; top: 40%;
Skall vara:
<div id="popad" style="<%=mainBGColor%>;display:none;padding:5px;position: absolute; left: 50%; top: 40%;
Men du borde verkligen lägga in allt med design att göra i din CSS fil på #popad
Och du borde kunna felsöka det med den renderade datan som du få i ren HTML, eller ladda ner firefox med firebug, bli enklare att felsöka.
Det absolut enklaste för att hjälpa dig om detta inte stämmer är att ge den genererade HTML koden och ignorera allt med ASP koderna, då det egentligen inte är något ASP har med att göra.
127 ms — deklarationer (db)
121 ms — ändringar (db)
