Har problem med ett par skoluppgifter. Såhär lyder uppgifterna.
8. Use span to mark a few important words that should normally appear red but when the mouse pointer hovers above, one word should change both background and foreground colour, the other should be bold and increase in size by a factor 1.5.
9. Place a darkred square at the top left of the page. Then make stay there even if the page is scrolled.
10. Place two images over the text and partially over each other on the page. Then change the settings such that one image appears behind the text and the other in front of the text.
11. Use the "display"-attribute to create a header h2, where the paragraph text continues directly after the header text. Then make the in-line element code to a block element and using the Courier font for the text.
Jag har pillat med detta i ett par dagar, men det verkar som om att jag inte kommer hitta en lösning där jag gör det i css.....
Någom som har lust/vill hjälpa mig med detta?
