Har följande kod i en style tagg:
<style>
.blueText {
color: blue;
font-weight: bold;
.greenText {
color:green;
font-weight: bold;
.redText {
color:red;
font-weight: bold;
.blackText {
color:black;
font-weight: bold;
</style>
sen har jag i bodyn följande kod:
<td align="center">
strTot = objrs("TOTAL")
if strTot < 30 then
response.write "<span class=""blueText"">"&strTot&"</span>"
elseif strTot < 36 then
response.write "<span class=""greenText"">"&strTot&"</span>"
elseif strTot < 40 then
response.write "<span class=""redText"">"&strTot&"</span>"
elseif strTot > 39 then
response.write "<span class=""blackText"">"&strTot&"</span>"
End if
response.write vbCrLf & "</td>" & vbCrLf & "</tr>" & vbCrLf
prevDate = currDate
objrs.movenext
wend
if i=0 then 'empty recordset
response.write "<tr><td colspan=""19"">Det finns inga resultat!</td></tr>"
</table>
problemet är att alla resultat som är under 30 inte blir blåa men dom andra färgerna funkar som dom ska.
Någon som kan se varför?
För enkelhetens skull bifogar jag hela koden här:
Sub createNewTableStart(endPrevTable)
if endPrevTable then response.write vbCrLf & "</table>" & vbCrLf & "<br />" & vbCrLf
<b><%=objrs("Comp_Name") %></b>
<br>
<table border="1" style="border-collapse: collapse" bordercolor="1px solid #000000">
<tr bgcolor="#CDD5E4" style="font-weight: bold">
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=1" target="top10">1</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=2" target="top10">2</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=3" target="top10">3</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=4" target="top10">4</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=5" target="top10">5</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=6" target="top10">6</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=7" target="top10">7</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=8" target="top10">8</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=9" target="top10">9</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=10" target="top10">10</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=11" target="top10">11</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=12" target="top10">12</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=13" target="top10">13</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=14" target="top10">14</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=15" target="top10">15</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=16" target="top10">16</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=17" target="top10">17</a></td>
<td width="30" align="center"><a href="top10.asp?Show=Top10&Lane=18" target="top10">18</a></td>
<td width="30" align="center">Tot</td>
</tr>
End Sub
<html>
<title></title>
<style type="text/css">
td {
font-size: 11px;
font-family: verdana;
color: black;
a:hover {
text-decoration: none;
color: black;
a:visited {
color: black;
.blueText {
color: blue;
font-weight: bold;
.greenText {
color:green;
font-weight: bold;
.redText {
color:red;
font-weight: bold;
.blackText {
color:black;
font-weight: bold;
</style>
<link rel="stylesheet" type="text/css" href="css/table.css">
<body>
dim Conn, objrs, i, prevDate, currDate, strTot
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("db/xlr13x3sm.mdb")
Set objrs = Conn.Execute("SELECT tbl_player.Namn, tbl_player.Efternamn, tbl_res.AMT1, tbl_res.AMT2, tbl_res.AMT3, tbl_res.AMT4, tbl_res.AMT5, tbl_res.AMT6, tbl_res.AMT7, tbl_res.AMT8, tbl_res.AMT9, tbl_res.AMT10, tbl_res.AMT11, tbl_res.AMT12, tbl_res.AMT13, tbl_res.AMT14, tbl_res.AMT15, tbl_res.AMT16, tbl_res.AMT17, tbl_res.AMT18, tbl_res.TOTAL, tbl_res.Date, tbl_res.Comp_Name FROM tbl_player INNER JOIN tbl_res ON tbl_player.PlayerId=tbl_res.PlayerId WHERE tbl_res.Surface ='Filt' ORDER BY tbl_res.Date, tbl_res.Varv")
i=0
while not objrs.BOF and not objrs.EOF
currDate = objrs("Date")
if IsEmpty(prevDate) then 'first iteration
createNewTableStart(false)
elseif prevDate <> currDate then
createNewTableStart(true)
i = i + 1
If i Mod 2 = 0 Then
<tr bgcolor="#EEEEEE">
<% Else %>
<tr bgcolor="#FFFFFF">
<% End If %>
<td align="center"><%=objrs("AMT1")%></td>
<td align="center"><%=objrs("AMT2")%></td>
<td align="center"><%=objrs("AMT3")%></td>
<td align="center"><%=objrs("AMT4")%></td>
<td align="center"><%=objrs("AMT5")%></td>
<td align="center"><%=objrs("AMT6")%></td>
<td align="center"><%=objrs("AMT7")%></td>
<td align="center"><%=objrs("AMT8")%></td>
<td align="center"><%=objrs("AMT9")%></td>
<td align="center"><%=objrs("AMT10")%></td>
<td align="center"><%=objrs("AMT11")%></td>
<td align="center"><%=objrs("AMT12")%></td>
<td align="center"><%=objrs("AMT13")%></td>
<td align="center"><%=objrs("AMT14")%></td>
<td align="center"><%=objrs("AMT15")%></td>
<td align="center"><%=objrs("AMT16")%></td>
<td align="center"><%=objrs("AMT17")%></td>
<td align="center"><%=objrs("AMT18")%></td>
<td align="center">
if strTot < 30 then
End if
prevDate = currDate
objrs.movenext
wend
</table>
'close and kill recordset/connection objects
objrs.close
set objrs = nothing
Conn.close
set Conn = nothing
</html>
Tacksam för alla svar jag kan få i denna fråga
/S
