Fel vid html validering och länk?
HTML & CSS
3 svar · 250 visningar · startad av maqe
Medlem sedan dec. 2003824 inlägg
Hur kan det komma sig att validatorn inte godkänner en länk där man skickar med parametrar? Dessa fel får jag
Warning Line 136 column 70: cannot generate system identifier for general entity "p".
...ef="http://xout.smhi.se/gateway.php?u=MV-TUBENQ&p=beRNeVvj" target='1'>
An entity reference was found in the document, but there is no reference by that name defined. Often this is caused by misspelling the reference name, unencoded ampersands, or by leaving off the trailing semicolon (;). The most common cause of this error is unencoded ampersands in URLs as described by the WDG in "Ampersands in URLs".
Entity references start with an ampersand (&) and end with a semicolon (;). If you want to use a literal ampersand in your document you must encode it as "&" (even inside URLs!). Be careful to end entity references with a semicolon or your entity reference may get interpreted in connection with the following text. Also keep in mind that named entity references are case-sensitive; &Aelig; and æ are different characters.
If this error appears in some markup generated by PHP's session handling code, this article has explanations and solutions to your problem.
Note that in most documents, errors related to entity references will trigger up to 5 separate messages from the Validator. Usually these will all disappear when the original problem is fixed.
Error Line 136 column 70: general entity "p" not defined and no default entity.
This is usually a cascading error caused by a an undefined entity reference or use of an unencoded ampersand (&) in an URL or body text. See the previous message for further details.
Error Line 136 column 71: reference to entity "p" for which no system identifier could be generated.
...="http://xout.smhi.se/gateway.php?u=MV-TUBENQ&p=beRNeVvj" target='1'>
Info Line 136 column 69: entity was defined here.
...href="http://xout.smhi.se/gateway.php?u=MV-TUBENQ&p=beRNeVvj" target='1'>
Det kan ju inte vara rätt? Man måste väl få ha en länk där man skickar med parametrar eller?
Tänka sig, detta känner jag igen! ;)
Verkar som att dom inte godkänner & istället för & i querystringen tyvärr ... får fel att abbonemanget har gått ut när jag ändrar?
Glöm det där va jag som tänkte fel :)
125 ms — deklarationer (db)
126 ms — ändringar (db)
