Hur ändra textstorleken på detta javascript?
2 svar · 259 visningar · startad av tuss
tussMedlem sedan aug. 200429 inlägg
Jag vill ha större teckenstorleken på detta rullande script. Jag kopierade hela sidan. Hoppas att nån vänlig själ kan hjälpa mig.
<html>
<title>Untitled Document</title>
<body bgcolor="#B0C4DE" text="#003366">
<script language="JavaScript1.2">
Cross browser Marquee script- © Dynamic Drive (https://www.dynamicdrive.com)
For full source code, 100's more DHTML scripts, and Terms Of Use, visit http://www.dynamicdrive.com
Credit MUST stay intact
//Specify the marquee's width (in pixels)
var marqueewidth="1005px"
//Specify the marquee's height
var marqueeheight="20px"
//Specify the marquee's marquee speed (larger is faster 1-10)
var marqueespeed=1
//configure background color:
var marqueebgcolor="#F1F1EB"
//Pause marquee onMousever (0=no. 1=yes)?
var pauseit=0
//Specify the marquee's content (don't delete <nobr> tag)
//Keep all content on ONE line, and backslash any single quotations (ie: that\'s great):
var marqueecontent='<nobr><font face="Verdana">Det är den här texten jag vill ska rulla men med ett större typsnitt</font></nobr>'
////NO NEED TO EDIT BELOW THIS LINE////////////
marqueespeed=(document.all)? marqueespeed : Math.max(1, marqueespeed-1) //slow speed down by 1 for NS
var copyspeed=marqueespeed
var pausespeed=(pauseit==0)? copyspeed: 0
var iedom=document.all||document.getElementById
if (iedom)
document.write('<span id="temp" style="visibility:hidden;position:absolute;top:-100px;left:-9000px">'+marqueecontent+'</span>')
var actualwidth=''
var cross_marquee, ns_marquee
function populate(){
if (iedom){
cross_marquee=document.getElementById? document.getElementById("iemarquee") : document.all.iemarquee
cross_marquee.style.left=parseInt(marqueewidth)+8+"px"
cross_marquee.innerHTML=marqueecontent
actualwidth=document.all? temp.offsetWidth : document.getElementById("temp").offsetWidth
else if (document.layers){
ns_marquee=document.ns_marquee.document.ns_marquee2
ns_marquee.left=parseInt(marqueewidth)+8
ns_marquee.document.write(marqueecontent)
ns_marquee.document.close()
actualwidth=ns_marquee.document.width
lefttime=setInterval("scrollmarquee()",20)
window.onload=populate
function scrollmarquee(){
if (iedom){
if (parseInt(cross_marquee.style.left)>(actualwidth*(-1)+8))
cross_marquee.style.left=parseInt(cross_marquee.style.left)-copyspeed+"px"
if (ns_marquee.left>(actualwidth*(-1)+8))
ns_marquee.left-=copyspeed
if (iedom||document.layers){
with (document){
document.write('<table border="0" cellspacing="0" cellpadding="0"><td>')
if (iedom){
write('<div style="position:relative;width:'+marqueewidth+';height:'+marqueeheight+';overflow:hidden">')
write('<div style="position:absolute;width:'+marqueewidth+';height:'+marqueeheight+';background-color:'+marqueebgcolor+'" onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed">')
write('<div id="iemarquee" style="position:absolute;left:0px;top:0px"></div>')
write('</div></div>')
write('<ilayer width='+marqueewidth+' height='+marqueeheight+' name="ns_marquee" bgColor='+marqueebgcolor+'>')
write('<layer name="ns_marquee2" left=0 top=0 onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed"></layer>')
write('</ilayer>')
document.write('</td></table>')
</html>
Tack på förhand! Tuss
HEJ!
Om du inte vill styla den, borde det väl fungera med en vanlig font size?
Usch, det där skriptet såg inge roligt ut... :o
Anyway, för att få texten större så ändrar du
var marqueecontent='<nobr><font face="Verdana">Det är den här texten ...
till
var marqueecontent='<nobr><font face="Verdana" [b]size="+1"[/b]>Det är den här texten ...
Men om jag vore du skulle jag faktiskt inte använda det här skriptet över huvud taget, då det finns betydligt bättre sätt att få rullande text som dessutom är tillgängligt utan javascript... :)
140 ms totalt · 3 externa anrop · v20260731065814-full.30151723
