Jag håller på och trasslar med testfiler för att få till stånd en drop-down meny så småningom. Följande fil fungerar menyn i (utseendemässigt, länkarna går ingenstans), men (http://validator.w3.org/)
HTML-validatorn skrev:
Line 371, column 6: end tag for "HEAD" which is not finished
</head >
Most likely, You nested tags and closed them in the wrong order. For example <p><em>...</p> is not acceptable, as <em> must be closed before <p>. Acceptable nesting is: <p><em>...</em></p>
Another possibility is that you used an element (e.g. 'ul') which requires a child element (e.g. 'li') that you did not include. Hence the parent element is "not finished", not complete.
Men... jag förstår inte... Jag tycker inget av de föreslagna lösningarna stämmer? :q
//Koden
<html>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<meta name="robots" content="noindex">
<?php include_once("fishMerge.css");
sfHover = function() {
var sfEls = document.getElementById("nav").getElementsByTagName("LI");
for (var i=0; i<sfEls.length; i++) {
sfEls[i].onmouseover=function() {
this.className+=" sfhover";
sfEls[i].onmouseout=function() {
this.className=this.className.replace(new RegExp(" sfhover\\b"), "");
if (window.attachEvent) window.attachEvent("onload", sfHover);
<body>
<ul id="nav" class="medium">
<li><a class="menu " href="#">Home</a>
</li>
<li><a class="menu" href="#">News</a>
</li>
<li><a class="menu" href="#">Puzzles</a>
<ul class="sub">
<li><a class="menu" href="#">Quizzes</a></li>
<li><a class="menu" href="#">Crosswords</a></li>
<li><a class="menu" href="#">JigSaw</a></li>
<li><a class="menu" href="#">Logic</a></li>
</ul>
</li>
<li><a class="menu" href="#">Info</a>
<ul class="sub">
<li><a class="menu" href="#">FAQ</a></li>
<li><a class="menu" href="#">Terms of Use</a></li>
<li><a class="menu" href="#">Policies</a></li>
<li><a class="menu" href="#">About</a></li>
</ul>
</li>
<li><a class="menu" href="#">Members</a>
<ul class="sub">
<li><a class="menu" href="#">Member list</a></li>
<li><a class="menu" href="#">MyResults</a></li>
<li><a class="menu" href="#">MyRatings</a></li>
<li><a class="menu" href="#">MyCP</a></li>
</ul>
</li>
<li><a class="menu" href="#">Login/Reg</a>
<ul class="sub">
<li><a class="menu" href="#">Login/out</a></li>
<li><a class="menu" href="#">Register</a></li>
</ul>
</li>
<li><a class="menu" href="#">Interact</a>
<ul class="sub">
<li><a class="menu" href="#">Guestbook</a></li>
<li><a class="menu" href="#">Contact</a></li>
</ul>
</li>
<li><a class="menu " href="#">Links</a>
</li>
</ul><BR><BR><BR>
Vad beror felet på?
