Försöker att validera min sida via http://validator.w3.org men får följande fel:
No Character Encoding Found! Falling back to UTF-8.
I was not able to extract a character encoding labeling from any of the valid sources for such information. Without encoding information it is impossible to reliably validate the document. I'm falling back to the "UTF-8" encoding and will attempt to perform the validation, but this is likely to fail for all non-trivial documents.
och
Sorry, I am unable to validate this document because on lines 6-7, 43, 69, 74-75 it contained one or more bytes that I cannot interpret as utf-8 (in other words, the bytes found are not valid values in the specified Character Encoding). Please check both the content of the file and the character encoding indication.
Överst i min index fil har jag följande:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN""http://www.w3.org/TR/html4/loose.dtd">
