Another possibility is that you used an element (e.g. 'ul') which requires a child element (e.g. 'li') that you did not include.
Du har missat en inledande tr-tagg.
2 svar · 178 visningar · startad av Nova
Hjälp en kock ska koka soppa inte pyssla med hemsidor känns det som, efter ett par timmars felsök ger en klant som jag upp.
Detta får jag som fel när jag försöker validera
end tag for "TABLE" which is not finished
</table>
Most likely, You nested tags and closed them in the wrong order. For example <p><em>...</p> is not acceptable, as <em> must be closed before <p>. Acceptable nesting is: <p><em>...</em></p>
Another possibility is that you used an element (e.g. 'ul') which requires a child element (e.g. 'li') that you did not include. Hence the parent element is "not finished", not complete.
Så här ser min kod ut
<table width="99%" >
While ((Repeat9__numRows <> 0) AND (NOT Rsrecinstruk.EOF))
<td width="43%" valign="top"><span class="style2"><strong><%=(Rsrecinstruk.Fields.Item("rec_namn1").Value)%></strong></span>
<span class="style6"><br><br>
Ingredienser<br>
<%=(Rsrecinstruk.Fields.Item("Portionsantal").Value)%> portioner</span><br><br>
<% Response.Write (tecken((Rsrecinstruk.Fields.Item("instr_2").Value))) %>
</td>
<td width="57%" valign="top"><img src="bilder/mat/<%=(sbild(Rsrecinstruk.Fields.Item("Bilderstor").Value))%>" alt="Receptbild">
<br>
<br>
<br>
<span class="style1"><strong>Tillagningstid: </strong><%=(Rsrecinstruk.Fields.Item("tid").Value)%></span> <br>
<% Response.Write (tecken((Rsrecinstruk.Fields.Item("instr_1").Value))) %>
<br>
<br>
Skapat <%= DoDateTime((Rsrecinstruk.Fields.Item("datum").Value), 1, 4105) %> av <A HREF="personal.asp?<%= Server.HTMLEncode(MM_keepNone) & MM_joinChar(MM_keepNone) & "Kontaktnr=" & Rsrecinstruk.Fields.Item("Kontaktnr").Value %>"><%=(Rsrecinstruk.Fields.Item("Namn").Value)%></A><br> </td>
</tr>
Repeat9__index=Repeat9__index+1
Repeat9__numRows=Repeat9__numRows-1
Rsrecinstruk.MoveNext()
Wend
%></table>
Felet ligger i att jag har två tabeller med olika texter från databasen, så när ena tabellen är tom är det text i den andra och de verkar man inte få?
