hejsan,
vet inte om detta e d ratta forumet men undrar hur man kan embeda en .pls fil, jag testar med
<embed src="sokvagen_till.pls"></embed>
men d funkar inte??
2 svar · 259 visningar · startad av Gimbo
hejsan,
men d funkar inte??
<object type="audio/scpls" data="fil.pls"></object>
Borde funka. Kanske inte med IE iofs, har inte testat. (eller vad nu MIME-typen för .pls är...)
nope har testat att leka till hoger o vanster utan att fa det att funka
<object id="MediaPlayer" classid="CLSID:22d6f312-b0f6-11d0-94ab-0080c74c7e95" codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=6,4,5,715" align="baseline" border="0" width="100%" height="51" standby="Laddar Microsoft Windows Media Spelarens Komponenter..." data="http://bredbandsbolaget.no-ip.com:8000/listen.pls" type="application/x-oleobject">
<param name="FileName" value="http://bredbandsbolaget.no-ip.com:8000/listen.pls">
<param name="ShowControls" value="1">
<param name="ShowPositionControls" value="0">
<param name="ShowAudioControls" value="1">
<param name="ShowTracker" value="0">
<param name="ShowDisplay" value="0">
<param name="ShowStatusBar" value="1">
<param name="AutoSize" value="0">
<param name="ShowGotoBar" value="0">
<param name="ShowCaptioning" value="0">
<param name="AutoStart" value="1">
<param name="AnimationAtStart" value="0">
<param name="TransparentAtStart" value="0">
<param name="AllowScan" value="0">
<param name="EnableContextMenu" value="1">
<param name="ClickToPlay" value="0">
<param name="InvokeURLs" value="1">
<param name="DefaultFrame" value="datawindow">
<embed src="http://bredbandsbolaget.no-ip.com:8000/listen.pls" align="baseline" border="0" width="270" height="50" type="application/x-mplayer2" pluginspage="http://www.microsoft.com/isapi/redir.dll?prd=windows&sbp=mediaplayer&ar=media&sba=plugin&" name="MediaPlayer" showcontrols="1" showpositioncontrols="1" showaudiocontrols="1" showtracker="1" showdisplay="1" showstatusbar="1" autosize="0" showgotobar="1" showcaptioning="0" autostart="0" autorewind="0" animationatstart="1" transparentatstart="0" allowscan="0" enablecontextmenu="1" clicktoplay="0" invokeurls="1" defaultframe="datawindow">
</embed></object>
jag la in .pls filen sa att ni oxo kan testa
