Varför blir det en liggande scroll?
HTML & CSS
13 svar · 655 visningar · startad av SimOnline
Medlem sedan juli 20031 132 inlägg
den här sidan får jag i Internet Explorer en liggande scroll längst ned på sidan. Med eldräven funkar allting utmärkt.
Får ni också en liggande scroll i IE?
Om ja, någon som vet vad det beror på?
Så här ser main.css ut:
body {
	margin: 0;
	padding: 0;
	background-color: #D2381B;
	font-family: Verdana, Geneva, Lucida, Arial, Helvetica, sans-serif;
	font-size: 0.7em;
#webpage {
	width: 600px;
	margin: 0px auto;
	background-image: url(images/webpage_bg.gif);
	background-repeat: repeat-y;
	background-position: center;
	#webpage_top {
		padding: 25px 40px 0px 60px;
		height: 150px;
		background: url(images/webpage_top.gif) no-repeat top center;
		text-align: left;
		color: #FFF;
		#webpage_top a {
			color: #FFF;
			text-decoration: none;
		#webpage_top a:hover {
			color: #FFF;
			text-decoration: underline;
		#webpage_top h1 {
			margin: 0;
			font-family: "Trebuchet MS", "Bitstream Vera Sans", Verdana, Lucida, Arial, Helvetica, Sans-serif;
			font-size: 3.5em;
			text-shadow: 0.2em 0.2em 0.2em #666;
	#webpage_content {
		margin: -40px 8px 0 55px;
		color: #3A5245;
		#content {
			padding: 15px;
			width: 300px;
			float: left;
			line-height: 1.3em;
			#content p {
			#content p.justify {
				text-align: justify;
			#content a {
				color: #D2381B;
			#content a:hover {
				color: #13934C;
			#content h2 {
				margin: 8px 0 30px 0;
				font-size: 2.2em;
			#content h3 {
				margin: 0;
				font-size: 1.2em;
			#content li {
				margin: 0 0 30px -39px;
				list-style: none;
				list-style-image: none;
			#content .datetime {
				color: #666;
				font-size: 0.9em;
		#sidebar {
			padding: 20px;
			width: 130px;
			float: left;
			font-size: 0.9em;
			line-height: 1.4em;
			#sidebar #navigation li {
				margin: 0 0 0 -35px;
				font-size: 1.1em;
				font-weight: bold;
			#sidebar a {
				color: #06C;
			#sidebar a:hover {
				color: #F60;
			#sidebar h3 {
				margin: 0 0 10px 0;
				font-size: 1.3em;
			#sidebar li {
				margin: 0 0 20px -35px;
				list-style: none;
	#webpage_bottom {
		clear: both;
		height: 40px;
		background: url(images/webpage_bottom.gif) no-repeat bottom center;
		text-align: center;
		font-size: 0.9em;
		color: #666;
		#webpage_bottom a {
			color: #06C;
		#webpage_bottom a:hover {
			color: #F60;
.img_left {
	display: box;
	margin: 5px 10px 5px 0;
	float: left;
.img_right {
	display: box;
	margin: 5px 0 5px 10px;
	float: right;
Tack på förhand :)
Hmm..
Det beror på att din .tk-adress innebär att .tk automatiskt ramar in din sida med framesetkoden
  <frameset rows="*,1" framespacing="0" border="0" frameborder="NO">
    <frame src="http://www.svetsochsmide.com/blog" name="dot_tk_frame_content" scrolling="auto" noresize>
  </frameset>
och att MSIE ger dig en sidscroll med den koden om du inte t.ex. kör med CSS-stilen "overflow-x:hidden" på body på din sida ;)
Hmm, det tycks stämma att .tk-ramen är orsaken, men det hjälpte inte att lägga in "overflow-x:hidden" i body... ?
Hmm...
Du kör xhtml och har en <!DOCYTYE som gör att MSIE tar upp sidan i "Standards" mode...
Blir det bättre om du sätter den "overflow-x:hidden" på html då ? *osäker*
Medlem sedan okt. 200415 inlägg
Jag testade att göra det också, men det hjälpte tyvärr inte. Ser att SimOnline fortfarande har samma problem. Inga andra ideér?
Tack.
Om det underlättar, tittar man på denna sidan som också kör med .tk domän så blir det inte så: https://www.knockoutgbg.tk
Någon som kan se varför?
Hmm..
Verkar kunna bero på valet av <!DOCTYPE...
maqs - du kär ju HTML4.. Vad händer om du byter till "deras" <!DOCTYPE ?
Ok, men hur får jag reda på vilken <!DOCTYPE dot.tk kör med? Eller vad skall jag skriva ist?
EDIT--> Men https://www.knockout.tk som jag nämnde ovan har precis samma: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
Och där visas ingen scrollbar?
Hmm..
Ledsen om jag var oklar - Jag utgår ifrån att du inte kan påverka den <!DOCTYPE som .tk lägger in i sitt frameset...
Jag undrar egentligen helt enkelt vad som händer om du kör med
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
som <!DOCTYPE på din sida ( http://gylling.1go.dk )
Orsaken att jag undrar är att den <!DOCTYPEn ställer in MSIE i "Quirks mode" (dvs den får MSIE att agera "bakåtkompatibelt") och att den du använder idag ställer MSIE i "Standards mode"... Ibland kan skillnaden i hanteringen av sidorna märkas - och jag har stött på skillnader i just hanteringen av rullningslister i MSIE för sidor laddas in i en <frame> eller en <iframe> tidigare...
Mer om olika moder: http://www.hut.fi/u/hsivonen/doctype.html
Hmm, ok. Vet inte om jag är ute och cyklar nu men följande är precis vad jag kör med nu: <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
Hmm..
När jag tittar på koden som just nu ligger på http://gylling.1go.dk hittar jag dokumenttypen
"http://www.w3.org/TR/html4/loose.dtd">
och det är inte samma som
Hehe, ok, var inte riktigt uppmärksam, sorry.
Hursomhelst gjorde det susen. Tack så mycket för hjälpen. :)
EDIT--> Förresten, tror du att det räcker att ha det så i index filen, eller måste jag ta bort den raden i alla (kommande) sidor tror du?
Hmm...
Du måste nog räkna med att ha samma <!DOCTYPE på alla dina sidor eftersom de alla kan tänkas hamna i .tk:s frameset ;)
Ok, tack än en gång. :)
270 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
127 ms — deklarationer (db)
126 ms — ändringar (db)
