strechad tabell?
5 svar · 234 visningar · startad av Gimbo
GimboMedlem sedan dec. 20001 626 inlägg
Hejsan har varldens skummaste problem...
med 2kolumner, i de finns en bakgrundbild pa en linje, nar jag besoker sidan ena gangen sa e linjerna utdragna ifran varandra dvs de sitter inte ihop, men sa fort jag klickar pa refresh sa fixar det sig o allt blir fint, ngn som haft detta problem???
Ingen kod - ingen hjälp. ;)
har en massa jsp kod i den oxo men har kommer ett os med kod:
    <table cellSpacing="0" cellPadding="0" width="100%" border="0" style="border-collapse: collapse" bordercolor="#111111">
      <tr>
        <td background="images/sub-BG-vert.gif" width="85">
        <img height="1" src="images/spacer.gif" width="70"></td>
        <td width="184">
        <img height="1" src="images/spacer.gif" width="182"></td>
        <td width="346">
        <img height="1" src="images/spacer.gif" width="100"></td>
      </tr>
      <tr>
        <img src="images/sub-arrow.gif" width="62" height="46" border="0">
        </td>
        <td class="newsheadline" width="184"><font face="Arial"><label for="Industries"><font face="arial" color="#DADADA" size="5"><% out.print(request.getParameter("itemId")); %></font>
        <!-- <font size="1">By Industries</font></label><font size="1"> </font>
        </font> <br>
<%//@ include file="selectMenuIndustries.jsp" %><br>
        <font face="Arial" size="1"><label for="Industries">By Application</label>
        </font> <br>
        <select id="busprod" style="WIDTH: 130px; font-size:8pt; font-family:Arial; background-color:#C5E2F9" name="busprod">
        <option value="30" selected>-- Select --</option>
        <option value="31">Automotive</option>
        <option value="32">Aviation</option>
        <option value="33">Energy</option>
        <option value="34">Healthcare</option>
        <option value="35">Retail</option>
        <option value="36">Transportation</option>
        </select><font face="arial" color="#DADADA" size="5"></font>
        </td>
        <td align="right" width="346">
        <table cellSpacing="0" cellPadding="0" width="123" border="0">
          <tr>
            <td></td>
          </tr>
          <tr>
            <td>
            <div align="right">
              <a onmouseover="MM_swapImage('Image8','','images/sub-BUT04H.gif',1)" onmouseout="MM_swapImgRestore()" href="infoMenu.asp">
              <img id="Image8" src="images/sub-BUT04.gif" border="0" name="Image8" width="123" height="18"></a></div>
            </td>
          </tr>
          <tr>
            <td>
            <div align="right">
              <a onmouseover="MM_swapImage('Image5','','images/sub-BUT06H.gif',1)" onmouseout="MM_swapImgRestore()" href="newsMenu.asp">
              <img id="Image5" src="images/sub-BUT06.gif" border="0" name="Image5" width="78" height="18"></a></div>
            </td>
          </tr>
          <tr>
            <td>
            <div align="right">
              <a onmouseover="MM_swapImage('Image7','','images/sub-BUT03H.gif',1)" onmouseout="MM_swapImgRestore()" href="specialMenu.asp">
              <img id="Image7" src="images/sub-BUT03.gif" border="0" name="Image7" width="101" height="18"></a></div>
            </td>
          </tr>
          <tr>
            <td>
            <div align="right">
              <a onmouseover="MM_swapImage('Image9','','images/sub-BUT05H.gif',1)" onmouseout="MM_swapImgRestore()" href="casestoryMenu.asp">
              <img id="Image9" src="images/sub-BUT05.gif" border="0" name="Image9" width="100" height="18"></a></div>
            </td>
          </tr>
          <tr>
            <td>&nbsp;</td>
          </tr>
        </table>
           <%@ include file="dbConnInfo.jsp" %>
    // get categoryName
   String c_sql     = "SELECT * FROM productCategory WHERE productCategoryID = '" + categoryId + "' AND companyID = '" + companyId + "'";
   //out.print("<BR>c_sql=" + c_sql);
   Statement c_stmt = con.createStatement(ResultSet.TYPE_SCROLL_SENSITIVE, ResultSet.CONCUR_UPDATABLE);
   ResultSet c_rs   = c_stmt.executeQuery(c_sql);
   while (c_rs.next()) {
      categoryName              =  c_rs.getString("name");
      //out.print("<BR>categoryName=" + categoryName);
      //i_smallDescription  =  c_rs.getString("smallDescription");
     // get Type Name
     try {
        String t_sql = "SELECT * FROM productType WHERE catalogID = '" + catalogId + "'" +
                       " AND companyID = '" + companyId + "'" +
                       " AND productCategoryID = '" + categoryId + "'" +
                       " AND productTypeID = '" + typeId + "'";
        //out.print("<BR>t_sql=" + t_sql);
	Statement t_stmt = con.createStatement(ResultSet.TYPE_SCROLL_SENSITIVE, ResultSet.CONCUR_UPDATABLE);
        ResultSet t_rs = t_stmt.executeQuery(t_sql);
        while (t_rs.next()) {
           typeName   =  t_rs.getString("name");
           //out.print("<BR>typeName=" + typeName);
           //shortDesc  =  rs.getString("smallDescription");
     catch(SQLException e) {
            System.out.println("Failed to get type Name execute t_sql SQL.");
 if(catalogId.length() > 0) {
     //out.print("<BR>catalogId.length()=" + catalogId.length());
      typeNav     = "DisplayProducts.jsp?typeId=" + typeId + "&categoryId=" + categoryId + "&catalogId=" + catalogId + "&companyId=" + companyId;
      categoryNav = "ListTypes.jsp?categoryId=" + categoryId + "&catalogId=" + catalogId + "&companyId=" + companyId;
      catalogNav  = "DisplayCategories.jsp?companyId=" + companyId + "&catalogId=" + catalogId; //
else {
     typeNav     = "DisplayProducts.jsp?typeId=" + typeId + "&categoryId=" + categoryId + "&catalogId=" + catalogId;
     categoryNav = "ListTypes.jsp?categoryId=" + categoryId + "&catalogId=" + catalogId;
     catalogNav  = "DisplayCategories.jsp?catalogId=" + catalogId;
if(companyId.equalsIgnoreCase("JABSCO") || companyId.equalsIgnoreCase("FLOJET")) { %>
   <font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#333333">
        <a href="<% out.print(catalogNav); %>"><% out.print(catalogId); %></a> / <a href="<% out.print(categoryNav); %>"><% out.print(categoryName); %></a>/ <a href="<% out.print(typeNav); %>"><% out.print(typeName); %></a>
    </font>
    <br> <br>
<% }else{ %>
    <a href="<% out.print(categoryNav); %>"><b><% out.print(categoryId); %></b></a> / <% out.print(typeName); %>
      </font>
    <br>
        <font size="1"><font face="Arial">By Market Segment</label></font> </font>
        </font> <br>
<%@ include file="selectMenuIndustries.jsp" %><br>
        <!-- <font face="Arial" size="1"><label for="Industries">By Application</label>
        </font> <br>
        </select> -->&nbsp;</td>
      </tr>
    </table>
jsp-koden är ointressant. Öppna sidan i din webbläsare och välj "Visa källa". Posta sedan den koden. :)
doggelitoMedlem sedan juni 20003 076 inlägg
tycker jag känner igen problemet!
kolla hur din webbläsare är inställd:
verktyg/internet alternativ/inställningar (under tillfälliga internet filer)
klicka i att sidan ska uppdateras varje gång.
detta gäller om felet är i ie förståss!
annars kan du ju alltid skriva om koden till css: :)
<td style="background-image: url(images/sub-BG-vert.gif);" width="85">
man tackar, jag korde med css metoden
135 ms totalt · 3 externa anrop · v20260731065814-full.0e50b1ef
