document type does not allow element "meta" here
9 svar · 249 visningar · startad av Melea
MeleaMedlem sedan juli 20032 667 inlägg
Hejsan!
Har gjort ett försök att validera min första xhtml sida. Dessvärre får jag några små fel som jag inte förstår mig på.
Tar dem i ordning:
[b]Line 2, column 73: document type does not allow element "meta" here[/b]
...e" content="text/html; charset=iso-8859-1" />
[b]Line 47, column 130: document type does not allow element "input" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "pre", "address", "fieldset", "ins", "del" start-tag[/b]
...="889a516adff1c9496fef94b03e72f88e" />
[b]Line 49, column 59: document type does not allow element "img" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "address", "fieldset", "ins", "del" start-tag[/b]
<img src="img/flag_swe.gif" style="border: 0px;" alt="" />
[b]Line 50, column 104: the name and VI delimiter can be omitted from an attribute specification only if SHORTTAG YES is specified[/b]
...: transparant; border: 0px;" checked onclick="submit();" />
[b]Line 50, column 125: document type does not allow element "input" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "pre", "address", "fieldset", "ins", "del" start-tag[/b]
...: 0px;" checked onclick="submit();" />
[b]Line 52, column 58: document type does not allow element "img" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "address", "fieldset", "ins", "del" start-tag[/b]
<img src="img/flag_uk.gif" style="border: 0px;" alt="" />
[b]Line 53, column 117: document type does not allow element "input" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "pre", "address", "fieldset", "ins", "del" start-tag[/b]
... border: 0px;" onclick="submit();" />
Vad är det för snack om att jag måste ha "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "address", "fieldset", "ins", "del"?
Jaojao, hoppas på svar. :f
Jag hittade en lysande beskrivning av jarvklo i en annan post här på wF men det löste tyvärr inte alla mina problem.
Kan mycket väl varit så att jag missat hur man löste det men dessa återstår att validera:
[b]Line 51, column 59: document type does not allow element "img" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "address", "fieldset", "ins", "del" start-tag[/b]
[b]Line 52, column 104: the name and VI delimiter can be omitted from an attribute specification only if SHORTTAG YES is specified[/b]
[b]Line 52, column 125: document type does not allow element "input" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "pre", "address", "fieldset", "ins", "del" start-tag[/b]
[b]Line 54, column 58: document type does not allow element "img" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "address", "fieldset", "ins", "del" start-tag[/b]
[b]Line 55, column 117: document type does not allow element "input" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "pre", "address", "fieldset", "ins", "del" start-tag[/b]
Jag la alltså till
ini_set("arg_separator.output","&amp;");
ini_set("url_rewriter.tags","a=href,area=href,frame=src,input=src,fieldset=");
högst uppe på sidan samt ändrade lite småsaker jag missat i koden.
jarvkloMedlem sedan juli 20013 295 inlägg
Hmm...
Omöjligt att säga om du inte lägger upp en länk till sidan ;)
(men gör du det så löser vi dina problem i dett nafs ;) )
dectgapMedlem sedan sep. 20021 542 inlägg
När du försöker validera koden som XHTML 1.0 Strict, eller XHTML 1.1, måste dina inline-element (t ex <img> och <input>) ligga i ett blockelement, t ex <p>, under <form>.
Om du skriver (X)HTML Transitional behöver du inget extra blockelement.
checked ska skrivas checked="checked"
Vad det är för fel på meta-taggen är svårt att säga utan något sammanhang, men eftersom det står att meta-taggen ligger på rad 2 är det troligt att den ligger utanför <head>. Dina meta-taggar måste ligga inom <head>.
yazMedlem sedan maj 2002880 inlägg
charset=iso-8859-1 ska skrivas charset="iso-8859-1" med fnuttar runt attributvärdet. XHTML kräver fnuttar kring alla attributvärden.
fnutt=citationstecken :P ;)
EDIT: på line 52 >> transparent ska det vara. inte transparant.
yaz - Rad 2 är en <meta>-tagg dock - och där gäller inte ditt påpekande
inte? så det är rätt som det är skrivet där?
ahh, charset ingår inom content kanske..? :r
Har fått strikta order från min arbetsledare att inte visa sidan officiellt ännu pga. sidans innehåll (enligt han nya fräscha ideér ;))
Tack så mkt dectgap, det löste några av min av problem.
Hur gör man nu för att en <div> eller eller <p> inte ska skapa en massa radbrytningar? Kommer ihåg att jag sett kod för detta någonstans.
Meta-taggarna löste sig när jag la _alla_ inom <head>. :)
  margin:0; padding:0;
Om du inte behöver ta till storsläggan
display:inline
förståss ;)
Lysande. Det var display:inline jag letade efter :)
Tack för era snabba svar!
Genererad på 378 ms · cache AV · v20260730165559-full.f96bc7eb
