Nu har jag sett en finare än fade som jag har.
Typ http://208.46.28.168/photos%5Cfmx_slideshow_1_01.html
Och jag har koden som ser ut
pic_arr = ["flower_pink.jpg", "flower_yellow.jpg", "flower_purple.jpg", "flower_red.jpg", "flower_orange.jpg"];
color_arr = [0xf75eb0, 0xf6f818, 0xbb57c8, 0xdf1734, 0xfe9809];
// specify pic locations, alpha increment each frame, and
// number of frames to keep current picture displayed before
// transitioning to the next one
blank_mc.attachMovie("slideshow", "uuShow", 1, {
_x:0, _y:0, _visible:false, fps:12, nFrames:24, alphaIncr:10,
slides_arr:pic_arr, slideDepth:50, repeat:true});
// tell blank_mc to listen for events broadcast by uuShow
blank_mc.uuShow.addListener(blank_mc);
blank_mc.onSlideLoaded = function(i) {
(new Color(this._parent["dot"+i+"_mc"])).setRGB(color_arr[i]);
// trace('slide '+ i + ' loaded');
blank_mc.onAllSlidesLoaded = function() {
this.uuShow._visible = true;
this.uuShow.beginTransitions();
blank_mc.onShowOver = function() {
//set repeat:false in uuShow for this to be called
//trace('slideshow is over');
som jag fattar ingentingen alls hur jag ska sätta det till min fotoalbum.
slides_xml = new XML();
slides_xml.onLoad = startSlideShow;
slides_xml.load("fotoalbum.xml");
slides_xml.ignoreWhite = true;
function fade(clip:MovieClip){
mx.transitions.TransitionManager.start (clip,
{type:mx.transitions.Fade,
direction:0, duration:1, easing:mx.transitions.easing.Regular.easeInOut,
param1:empty, param2:empty});
function startSlideShow(success) {
if (success == true) {
rootNode = slides_xml.firstChild;
totalSlides = rootNode.childNodes.length;
firstSlideNode = rootNode.firstChild;
currentSlideNode = firstSlideNode;
currentIndex = 1;
updateSlide(firstSlideNode);
function updateSlide(newSlideNode) {
imagePath = newSlideNode.attributes.jpegURL;
slideText = newSlideNode.firstChild.nodeValue;
fade(visningKlipp);
loadMovie(imagePath, visningKlipp);
// Event handler for 'Next slide' button
next_btn.onRelease = function()
nextSlideNode = currentSlideNode.nextSibling;
if (nextSlideNode == null) {
break;
} else {
currentIndex++;
updateSlide(nextSlideNode);
currentSlideNode = nextSlideNode;
// Event handler for 'Previous slide' button
back_btn.onRelease = function() {
previousSlideNode = currentSlideNode.previousSibling;
if (previousSlideNode == null) {
break;
} else {
currentIndex--;
currentSlideNode = previousSlideNode;
updateSlide(previousSlideNode);
Är ju nybörjare :q
