Använder Imail mailserver och Dimac mailkomponent.. får följande felmeddelande två ggr på samma sida:
The message was undeliverable. All servers failed to receive the message
ClientLogging enabled: Client Remote Address: 212.116.80.103
.execute()
Trying server mail:mail.sluzzen.com
<- 220 X1 NT-ESMTP Server sluzzen.com (IMail 6.06 EVAL 1-1)
-> EHLO jymdis
<- 250-sluzzen.com says hello
250-SIZE 0
250-8BITMIME
250-DSN
250-ETRN
250 EXPN
-> MAIL FROM:
<- 250 ok
-> RCPT TO:
<- 550 not local host home.se, not a gateway
-> DATA
<- 503 must have sender and recipient first
Error: 503 must have sender and recipient first
.execute()
Den mycket enkla frågan, med vad jag tycker ett mycket svårare svar är, vad gör jag för fel?
Andreas Lännerberg
Jag hör till dom som betalar mina räkningar med glädje, men dom vill hellre ha betalt i pengar.
' Create the JMail message Object
set msg = Server.CreateOBject( "JMail.Message" )
' Set logging to true to ease any potential debugging
' And set silent to true as we wish to handle our errors ourself
msg.Logging = true
msg.silent = true
' Most mailservers require a valid email address
' for the sender
msg.From = "register@sluzzen.com"
msg.FromName = "Sluzzen Registrering"
' Next we have to add some recipients.
' The addRecipients method can be used multiple times.
' Also note how we skip the name the second time, it
' is as you see optional to provide a name.
msg.AddRecipient "jymdspionen@tjohoo.se"
' The subject of the message
msg.Subject = "Välkommen till Sluzzen Community"
' The body property is both read and write.
' If you want to append text to the body you can
' use JMail.Body = JMail.Body & "Hello world! "
' or you can use JMail.AppendText "Hello World! "
' which in many cases is easier to use.
' Note the use of vbCrLf to add linebreaks to our email
msg.Body = "Grattis!" & vbCrLf & vbCrLf & "Som nybliven medlem hos Sluzzen Community kan du chatta, irca och en massa annat." & vbCrLf & vbCrLf & " Din aktiveringskod: " & Recordset1("Aktiveringskod") & " (logga in med ditt nick och password, aktiveringsidan dyker upp!) Hälsningar Sluzzen Staff ( http://www.sluzzen.com )"
' There.. we have now succesfully created our message.
' Now we can either send the message or save it as a draft in a Database.
' To save the message you would typicly use the Message objects Text property
' to do something like this:
' SaveMessageDraft( msg.Text )
' Note that this function call is only an example. The function does not
' exist by default, you have to create it yourself.
' If i would like to send my message, you use the Send() method, which
' takes one parameter that should be your mailservers address
' To capture any errors which might occur, we wrap the call in an IF statement
if not msg.Send( "mail.sluzzen.com" ) then
Response.write "Ett fel har uppstått. Var vänlig att kontakta admin@sluzzen.com med följande felmeddelande:" & vbCrLf & vbCrLf & "<pre>" & msg.log & "</pre>"
set msg = nothing
Response.write "<font face='Verdana, Arial, Helvetica, sans-serif' size='1'>Meddelande skickat!"
set msg = nothing
response.redirect "utloggning.asp"
' And we're done! the message has been sent.
Så ser den ut =)
Andreas Lännerberg
Jag kan ju säga så mycket som att sidan har fungerat innan.. men jag var tvungen å lägga om mailservern så jag gissar att det är den det är fel inställningar eller nåt.. behöver man skapa ett konto eller liknande till Jmail?
/Jymdis
Andreas Lännerberg
248 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
