Fel på Global.asa
1 svar · 206 visningar · startad av aleborg
En kund får följande fel:
Microsoft JET Database Engine error '80004005'
'e:\www\admin\userXXX\html\data\forum.mdb' is not a valid path. Make sure that the path name is spelled correctly and that you are connected to the server on which the file resides.
/LM/W3SVC/408/ROOT/global.asa, line 21
på följande kod:
<script language=VBScript runat=Server>
Sub Session_OnStart
	Session.TimeOut = 30
	'Session("Sys.HideText") = "True"
	If Request.ServerVariables("HTTP_HOST") = "no.xxxxxxx.se" Then
		Session.LCID = 1044 ' Norge
		Session("Locale.ID") = "no"
	ElseIf Request.ServerVariables("HTTP_HOST") = "eu.xxxxxxx.se" Then
		Session.LCID = 1033 ' England (EU)
		Session("Locale.ID") = "eu"
	Else
		Session.LCID = 1053 ' Sverige
		Session("Locale.ID") = "se"
	'On Error Resume Next
	' Initiera databaskoppling
	Set Connection = Server.CreateObject("ADODB.Connection")
	Connection.Open Application("forum_db")
	' Skapa ett uppslagsverk med alla texter
	Set TextRecordset = Connection.Execute("SELECT * FROM site_texts")
	Set Session("Sys.Text") = CreateObject("Scripting.Dictionary")
	Dim TempText
	Dim PresentText
	Do Until TextRecordset.EOF = True
		TempText = TextRecordset("c" & Session.LCID)
		If IsNull(TempText) Or Len(TempText) < 1 Then
			PresentText = "" & TextRecordset("c" & Application("DefaultLCID"))
		Else
			PresentText = TempText
		End if
		If Session("Sys.HideText") = "True" Then PresentText = "50"
		Session("Sys.Text").Add TextRecordset("Theme") & "_" & _
		TextRecordset("Type") & "_" & _
		TextRecordset("Name"), PresentText
		TextRecordset.MoveNext
	Loop
	Set TempText = Nothing
	Set PresentText = Nothing
	TextRecordset.Close
	' Skapa ett uppslagsverk med alla telefoner
	Dim ManRecordset
	Dim PhonesRecordset
	Set Session("Phones.Phones") = CreateObject("Scripting.Dictionary")
	Set ManRecordset = Connection.Execute("SELECT ID, Namn FROM phones_manufacturers")
	Do Until ManRecordset.EOF = True
		Set PhonesRecordset = Connection.Execute("SELECT Modell, ID FROM phones_phones WHERE (Tillverkare = " & ManRecordset("ID") & ")")
			Do Until PhonesRecordset.EOF = True
				Session("Phones.Phones").Add UCase(ManRecordset("Namn") & " " & PhonesRecordset("Modell")), "id" & PhonesRecordset("ID")
				PhonesRecordset.MoveNext
			Loop
			PhonesRecordset.Close
		ManRecordset.MoveNext
	Loop
	ManRecordset.Close
	' Stäng allt
	Connection.Close
	Set ManRecordset = Nothing
	Set PhonesRecordset = Nothing
	Set TextRecordset = Nothing
	Set Connection = Nothing
End Sub
Sub Session_OnEnd
	Set Session("Sys.Text") = Nothing
	Set Session("Phones.Phones") = Nothing
End Sub
Sub Application_OnStart
	Application("DefaultLCID") = 1053
	Application("Sys.Version") = "4.0"
	Application("Sys.Copyright") = "<b>Secure Computing</b> 1999 - " & Year(Date)
	Application("mobilforum_db") = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("../data/forum.mdb")
End Sub
Sub Application_OnEnd
	Set Application("DefaultLCID") = Nothing
	Set Application("Sys.Version") = Nothing
	Set Application("Sys.Copyright") = Nothing
	Set Application("forum_db") = Nothing
End Sub
om han sen laddar upp Global.asa på nytt när felet uppstår så fungerar allt som det ska!?
Vad kan vara fel?
Rad 21: Connection.Open Application("forum_db")
Hittade felet, det uppstår när en besökare kommer till sidan direkt till en submapp, då blir sökvägen fel :)
126 ms — deklarationer (db)
125 ms — ändringar (db)
